Show Off Your Steel Wheels
Discussion in 'Wheels & Tires' started by DustStorm4x4, Dec 30, 2016.
  1. Feb 10, 2024 at 6:53 PM
    #961
    Swampdonkey02
    Swampdonkey02 New Member
    Zack
    2002 Toyota Tacoma double cab sr5
    Bilstein 5100s with ome 881 coils on middle setting up front, 5100s in rear with Ome adjustable shackles. 285 Goodyear boulders on 16 inch procomp wheels
    16x8 rough county steel wheels fit without any spacers whatsoever. Have 33 9.50 16 tsl sx2 tires mounted on them with no issues
  2. Feb 11, 2024 at 6:17 PM
    #962
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    As an olde school reference, here are some pix of the Hiluxes used at Helsinki's airport 8-10 years ago.
    Hay Lobos, SH10151, Scotfree and 2 others like this.
  3. Feb 15, 2024 at 9:35 AM
    #963
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Says it right in the post you quoted: "16x8 Rough Country" wheels.
    But to answer the other part, no GM wheels will not fit...the center bore hole of a GM wheel is typically like 78mm, when Tacomas need 106mm
  4. Feb 17, 2024 at 3:50 PM
    #964
    Peeing on jeeps
    Peeing on jeeps That Yankee Rebel
    Dennis
    West of the Chippewa River
    Not your Mall Crawler
    There only 16 x 8 w/ -12mm offset . steel. Rough Country
  5. Feb 18, 2024 at 5:58 AM
    #965
    jacket4256
    jacket4256 Member
    your talking about two different post the one I quoted is completely different.
    iwashmycar[QUOTED] likes this.
  6. Jun 19, 2024 at 6:52 PM
    #966
    .mr.e.
    .mr.e. Well-Known Member
    Ethan
    2021 Cement TRD Sport 4x4 DCSB 6MT
    Update pics — made a couple changes!
  7. Jun 29, 2024 at 7:12 PM
    #967
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    These are the steelies on my 07 Corolla. I sanded them steel wooled them and gave them an alcohol bath before 2 primer coats and then bronze. I touch them up every 2 years or so before a rotate and balance, removing weights and a quick sanding with 180 grit. They definitely get chipped and dull from the salt and pebbles from the winters here in Michigan. I thoroughly cover my tires with blue painters tape. I get a lot of compliments on them. This pic was not taken after a touch up. I asked the tire guys to put the weights back where they took them off because it usually takes the paint sometimes they don’t listen.
    If your daily driving with them on or playing hard you definitely will get to see what’s going on underneath that topcoat.
  8. Aug 10, 2024 at 5:50 AM
    #968
    Fireme
    Fireme Well-Known Member
    Bill
    St.JoMo
    2023 LR DCSBOR
    265/75-16 KO2, 16”trd beadlock, 23 OEM Pro Fox sus, OEM roof bar, seat spacer, sequencing mirror indicators, RC tri fold bed cover, weathertech mats. Homemade bam bed sleeping platform.
    Picked up a set of 17x7.5 at the not so local dealer for $100 w/ nuts,
    Found a set of old caps on eBay for $50,
    Probably gonna shoot them white and try to find some good used white letter KO2 for winter and put the Beads away. Wish my old 15x6 FJ60 wheels would clear the calipers. 1/4”Spacers?
    Camerasandcoffee and Scotfree like this.
  9. Aug 16, 2024 at 10:11 AM
    #969
    wenatcheekid
    wenatcheekid Well-Known Member
    Tyler
    Wenatchee, WA
    2008 Toyota Tacoma DSM acc cab BASE
    Bilstein 5100s, OME 885’s, Snorkel w/ Snorkel Upgrade precleaner, CMC, fender chop, SPC UCA’s, Deaver AAL, ECGS bushing, OME carrier bearing drop, SCS F5’s.
    Installed two days ago! Found the factory 2nd gen steelies on Craigslist, $75 for four of them. Mounted them on 255/85R16 Falken Wildpeak AT4W’s and got one for my spare.
    -Rorschach-, GRN305L, E4x4 and 9 others like this.
  10. Aug 16, 2024 at 10:43 PM
    #970
    yoda_toyota
    yoda_toyota Member
    David
    2023 Toyota Tacoma SR, Access-Cab, 4x2
    X-Trek 3rd Gen Tacoma Grille, 16x7 OEM 3rd Gen Tacoma (spare) Steelies
    Nice man good looking!! Gonna switch to this tire size when my suspension gets old and I do a 2” lift.
    wenatcheekid[QUOTED] likes this.
  11. Aug 16, 2024 at 10:50 PM
    #971
    wenatcheekid
    Tyler
    Wenatchee, WA
    From everything I’ve read you should be able to fit this tire size on factory offset wheels with no lift and no trimming in some cases.
  12. Sep 29, 2024 at 2:30 PM
    #972
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Were are you finding these?
  13. Oct 14, 2024 at 8:44 AM
    #973
    wenatcheekid
    Tyler
    Wenatchee, WA
  14. Nov 10, 2024 at 12:25 PM
    #974
    WrappedTaco
    WrappedTaco Well-Known Member
    J
    Ontario, Canada
    2003 Tacoma Regular Cab Prerunner
    3M Wrap 2 inch Bushwacker flares 2" Pro Comp AAL Bilstein 5100 rear 2" Spacers up front(for now) 31 x 10.5 / 15 tires PlastiDipped OEM 15" Steelies
  15. Nov 13, 2024 at 9:33 AM
    #975
    17TRDORMGM
    17TRDORMGM New Member
    Tom
    17 MGM Tacoma TRD OR
    3/2 level 285/70/17 0 offset
    Hi All! First post here and am new to Tacoma’s. Thinking of swapping to steelies and am wondering if anyone has tried these wheels?
    https://www.ebay.com/itm/175867709035
    They are 16x7 with a 5mm offset. Bore and bolt pattern are all Toyota.
    Thx in advance!
  16. Nov 14, 2024 at 12:14 PM
    #976
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    All the specs check out. Be advised they will not accept center caps, and need acorn nuts
    Fireme likes this.
  17. Nov 15, 2024 at 6:13 AM
    #977
    Fireme
    Bill
    St.JoMo
    2023 LR DCSBOR
    I’m sure liking these winter wheels, they look better and better the dirtier they get!
  18. Nov 15, 2024 at 6:37 AM
    #978
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    I like those better than the SR steelies I run on mine in the winter.
  19. Nov 15, 2024 at 9:02 AM
    #979
    trexgrrr
    trexgrrr Well-Known Member
    Sweet color combo! I’m also digging the RWL
  20. Nov 21, 2024 at 4:03 AM
    #980
    Scotfree
    2021 sr 4x4 2.7
    Where is that center cap from?
