Show Off Your Steel Wheels
Discussion in 'Wheels & Tires' started by DustStorm4x4, Dec 30, 2016.
  1. Nov 21, 2024 at 4:16 AM
    #981
    OLDTRAP
    OLDTRAP Well-Known Member
    2021 TRD OR
    Stock
    These are great looking. What brand?
  2. Nov 21, 2024 at 5:38 AM
    #982
    Fireme
    Fireme Well-Known Member
    Bill
    St.JoMo
    2023 LR DCSBOR
    265/75-16 KO2, 16”trd beadlock, 23 OEM Pro Fox sus, OEM roof bar, seat spacer, sequencing mirror indicators, RC tri fold bed cover, weathertech mats. Homemade bam bed sleeping platform.
    From eBay, there are several that fit steel wheels from the 80’s up, o believe they even came on the fj cruisers 17” steelies. The 16” spares steelies will not accommodate these snap in caps.
  3. Dec 4, 2024 at 4:41 AM
    #983
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Do these hold up better as far as rusting,the stock type black lug nuts chip and rust fairly quick?
  4. Dec 4, 2024 at 4:50 AM
    #984
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    Saw this Tpms was recommended Denso 550-0103
    But it’s all over the map so want to double check.
  5. Dec 4, 2024 at 5:27 AM
    #985
    JCsunshine89
    JCsunshine89 Member
    Jack
    1996 Tacoma
    I want to get my wheels repainted. Is this an expensive project? I’m guessing the oem color is Tacoma silver?
  6. Dec 5, 2024 at 7:19 AM
    #986
    SomeTacoDude
    SomeTacoDude Well-Known Member
    I have a magnetic gray metallic taco with a white smart cap shell I can put on it. I also have two sets of rims. The ones that came with the SR5 Edition, and some FJ steelies I got off of eBay. So I had been thinking about Rhino Lining the shell black because I'm not really thrilled with the way it looks on the truck. But seeing some of the MGM tacos on here got me thinking. So I used a photo editor to paint my black steel rims white. I was expecting it to look dumb, I don't know why but that was my expectation. But I kind of like the way it looks. Would be open to some honest opinions from those here.PXL_20230923_184523968~3.jpg
    Camerasandcoffee, atc250r and Fireme like this.
  7. Dec 5, 2024 at 9:09 AM
    #987
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    Actually not bad but would color match the topper.
  8. Dec 5, 2024 at 9:24 AM
    #988
    Fireme
    Bill
    St.JoMo
    2023 LR DCSBOR
    Not bad at all, I found a magnetic gray cap for $250, at some point I’ll probably wrap it or plastic dip it, but as little as I use it it’s fine for camping trips! I did the white steels for winter, and like em!
    69 Jim, PondScum, Scotfree and 3 others like this.
  9. Dec 9, 2024 at 2:36 PM
    #989
    hoytshooter1
    hoytshooter1 Well-Known Member
    Cave Creek, AZ
    2020 DCSB
    ICON's Method's w/265-70-17 (Gone) '16SR5 Wheels with 255-85-16 Falken MT's AZ pinstriping
    Personally, don't like. You have too many colors in play now with the black accents and now all the white.. Maybe try whiting out the black stuff on the computer?
  10. Dec 9, 2024 at 3:56 PM
    #990
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    Can’t stand toppers a different color.
    So much I passed on used for 800-1200 and spent 3200 for it color matching.
  11. Feb 8, 2025 at 4:56 AM
    #991
    SomeTacoDude
    None of that matters at this point. I had bought these rims and tires to run during hunting season. So I put them on at the beginning of deer season, and after driving on them the last three or four months it became apparent I would have to regear if I were going to keep them, and I'm just not ready to do that. Any grade steeper than level ground was 4th gear, any kind of significant grade was third gear and almost 6,000 RPMs. Pulling the ATV and the trailer the whole trip was basically third gear.
  12. Feb 22, 2025 at 7:28 AM
    #992
    Tonto ATX
    Tonto ATX Member
    2005 Silver Tacoma Access Cab TRD Off-Road
    2nd Gen. with 17" FJ steelies, purchased from Wheels Express. Powder coated Bengal Silver. Wrapped in 275/70/17 Cooper S/T Maxx. Tried both the silver plastic hub cap, part number 4260B-04010, and the black metal hub cap, part number 42603-35610. I favored the plastic color matched caps. Requires acorn style lug nuts, part number 90942-01021. Also installed are the Apex Design's Rapid Precision Valves. I did experienced clearance issue with the brake calipers, the wheels were just grazing the edge of them. After reading up on other peoples experience with clearance and their fixes, I chose to lightly grind the calipers until the wheels were no longer touching. It's been 8 months and no issues. Yes, I will preemptively say that for some that would be a big no-no to do that, but I did. Also to note, there is a 15lb - 20lb increase in weight per wheel/tire combo from stock.
    24E28C0B-D1D7-4B3D-A37D-FBA910678150_1_105_c.jpg 547352B9-9866-4694-8D08-7CD394D2F959_1_105_c.jpg F5790F93-1875-4CF6-B3B8-9A62452CB3DD_1_105_c.jpg 9073EAB3-B060-4D7F-B67E-288C05981046_1_105_c.jpg 6A1FA9A4-A798-40B5-8571-A8FBC01CED86_1_105_c.jpg
    Scotfree, moon22, TimberTiger and 3 others like this.
  13. Feb 23, 2025 at 3:52 AM
    #993
    Camerasandcoffee
    Camerasandcoffee 900hp short of 1000hp
    Jonathan
    Racine WI.
    2019 Trd Sport
    Relentless Fab hybrid bumper, 2.5” Dobinsons IMS lift, RCI skids and sliders, block heater. Painted FJ Steelies. Was trying to keep it stock, now slowly building for the Wisconsin trails.
    Those look really good color matched to the truck. I hadn't heard about interference with the calipers before. Would a thin wheel spacer have solved that problem?
  14. Feb 23, 2025 at 5:01 AM
    #994
    Fireme
    Bill
    St.JoMo
    2023 LR DCSBOR
    I never had clearance issues on a 3rd gen with 17x7.5 fj steels
  15. Feb 23, 2025 at 11:23 AM
    #995
    Tonto ATX
    Tonto ATX Member
    Yes, I suppose spacers would have also solved the problem. At the time I did this I didn't want to add another piece of hardware and complexity to the equation, plus I was being slightly impatient. I had my grinder on hand at that moment, and not spacers. I have read multiple accounts of people doing this adjustment without issue, and have not seen any cautionary tales which helped to inform my judgement. Long term if it was a mistake, I will share that experience.
  16. Feb 26, 2025 at 2:48 AM
    #996
    Operator8
    Operator8 Well-Known Member
    Woodland Park, CO
    2005 White Tacoma TRD OR
    SAS INW
    This was a couple years ago:
    So I got a used set of 33's Dick Cepek Extreme Country 285/75R16's to put on the truck while I got a new set of 35" tires mounted and balanced. Added some Plastidip as the Pro Comp Rock Crawler Series 51 wheels were just black.
    1st time out on a local trail. Rainbow Falls
  17. Mar 4, 2025 at 7:07 PM
    #997
    mambojohn
    mambojohn Active Member
    SoCal
    2020 TRD OR Prerunner
    New to the thread — How much does it usually cost to get a set of steelies powder coated? Based in SoCal if prices vary regionally
  18. Mar 4, 2025 at 7:13 PM
    #998
    mauctopa
    mauctopa Well-Known Member
    Anyone want 6 band new non oem steelies for 250? SoCal 92203 oh and 1 oem wheel and tire (was my spare)
    Scotfree likes this.
  19. Mar 17, 2025 at 8:49 AM
    #999
    Ngneer
    Ngneer Well-Known Member
    Nice
  20. Mar 17, 2025 at 11:00 AM
    #1000
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    What rims are these, actually like the chrome!
