Show off your wheel/tire setup!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gr0ver, Jul 27, 2016.
  1. Aug 3, 2019 at 11:12 PM
    #2721
    Ckerper
    Ckerper Well-Known Member
    SLC
    QS 2019 Tacoma TRD OR
    Are you able to put a bike on the pad with the rack on?
  2. Aug 4, 2019 at 1:24 PM
    #2722
    Foggy Noggin
    Foggy Noggin Well-Known Member
    Puyallup
    2019 Tacoma TRD Off-Road
    Yeah. Kinda tricky to wiggle it in but yes.
  3. Aug 4, 2019 at 2:11 PM
    #2723
    Ckerper
    SLC
    I wanted to run a similar setup but didn’t know if it was possible. Thanks
  4. Aug 4, 2019 at 2:38 PM
    #2724
    Snakedoctor
    Snakedoctor Well-Known Member
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Mandatory tint, in-channel visors, and 265/75R16 MT Toyos.
    I’ve got the me too set up.
    What products can I use to get the tires black again? They’ve gotten the golden brown color from various dirt and brake dust. Tried Greased lightning but didn’t seem to help very much.
    Also a good form of tire wet? I like to pretty the truck up every now and again and I was told to avoid the spray on but the sponge type applicators suck for the aggressive sidewall.
    arnette64 likes this.
  5. Aug 5, 2019 at 11:03 AM
    #2725
    Undertow
    Undertow Well-Known Member
    CT
    2020 Cement DC OR 6MT
    Stock
    All tires turn brown whether or not you off road. Its the nature of the rubber compound expelling chemicals over time. You can try a wheel and tire cleaner - it'll foam up nice and visually you'll be excited to see all that brown foam running off the tires but DO NOT be fooled - you're tires won't return to their new appearance. You'll just get some of the surface contaminants off and therefore you have to use a tire shine - here's a top tip:
    • Get a spray on tire shine from Mother's or Meguiar's, doesn't matter (I agree on the gels not getting into the aggressive parts of an A/T sidewall).
    • Spray it on as you normally would.
    • Then, go back over with a microfiber towel and wipe the entire face of the tire. You may need to work a few areas a bit more than others, but overall this should be a fairly straightforward exercise.
    • Not only will this remove any areas where you went a bit heavy/light and help with a more uniform look, but it will also promote a more matte black and organic appearance.
  6. Sep 4, 2019 at 2:17 PM
    #2726
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
  7. Sep 4, 2019 at 5:06 PM
    #2727
    Recondite
    Recondite Well-Known Member
    NCWA
    2018 MGM DCLB TRD OR
    What running boards are those?
  8. Sep 4, 2019 at 6:23 PM
    #2728
    dirkupson
    dirkupson Active Member
    2020 Toyota dclb trd off road
    2.5 fox shocks ,trd 4runner wheels , toyo tires
    Do they run anywhere?
  9. Sep 4, 2019 at 6:30 PM
    #2729
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    Nothing so far...
  10. Sep 4, 2019 at 6:37 PM
    #2730
    Luke812
    Luke812 Well-Known Member
    Brake Buster and a Tuff shine brush for wheels and rubber. Spray, scrub rinse several times and that brown will clean right up. I use AMMO Mudd for tire shine, but Carpro Perl works great, too. I use Adam's foam applicators for the tire shine, but you're right. Kind of a PITA with even a mildly aggresive AT tire to apply.
  11. Sep 4, 2019 at 6:49 PM
    #2731
    dirkupson
    Is your truck stock height?
  12. Sep 4, 2019 at 6:59 PM
    #2732
    J_Anthony_
    J_Anthony_ Well-Known Member
    RangerIsTheBestTruck.Duh.
    Naomi, Lana
  13. Sep 4, 2019 at 10:21 PM
    #2733
    maximum
    maximum Well-Known Member
    SCS SR8 17X8.5 265/70/17 Hankook Dynapro
    CementTacoPA likes this.
  14. Sep 5, 2019 at 7:23 AM
    #2734
    TT005
    TT005 Well-Known Member
    NC
    2023 SR5 DCSB 4X4
    Nothing special, but I’m pretty excited about this setup. TRD Off Road purchased with Southeast Toyota optioned Goodyear Wrangler Duratrac All-Terrain 265/70R16 tires.
    A33AA47A-A753-403C-8927-D792360DE348.jpg 56164B38-6B67-4632-B3DC-DC18B04B7CD1.jpg 35E56EC8-4814-4FCE-96AE-C00CDEF38B1E.jpg 86CCB8C6-5B6F-4996-BBE9-91317F824D3E.jpg
    radclerk1, Tora, knightacoma and 4 others like this.
  15. Sep 5, 2019 at 8:37 AM
    #2735
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    265/70/17 k02 BFG “all terrain*” and OEM 4Runner pro rims
    *Disclaimer: all terrain does not include mud or snow
  16. Sep 6, 2019 at 9:04 AM
    #2736
    ArizonaNativ
    ArizonaNativ Well-Known Member
    Tucson
    That’s a good looking tire and whee size. What’s your lift and how much trimming did you do?
  17. Sep 6, 2019 at 9:11 AM
    #2737
    TrailYeti
    TrailYeti Well-Known Member
    Portland, Oregon
    05 TRD OR on SCS F5’s & 315/75r16’s
    3” lift and a TON of cutting, trimming and BFH’ing. Still need to cut more off front flares. Was rubbing in this picture.
  18. Sep 7, 2019 at 11:04 PM
    #2738
    toker808
    toker808 Active Member
    2019 TRD Sport 4x4
    Kinda old but where did you rub? On the mud flaps?
  19. Sep 8, 2019 at 4:53 AM
    #2739
    Gregw138
    Gregw138 Well-Known Member
    Greg
    NY
    2019 TRD Off Road DCSB 2016 Lexus ES350 2009 Lexus ES350
    WAY TOO MANY
    Black Rhino Bantams 16X8 -10
    Goodyear Duratracs 265/75/16E5965FB8-72DA-4D9C-A9B0-85CC4E4B4782.jpg
  20. Sep 8, 2019 at 5:32 AM
    #2740
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    More then welcome to post but not sure if you were aware this is a thread in the 3gen forum.
    Looks good btw! Kinda miss my 2gen.
