Show off your wheel/tire setup!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gr0ver, Jul 27, 2016.
  1. Apr 1, 2021 at 7:30 AM
    #3201
    SpaceTrim
    SpaceTrim Well-Known Member
    SD
    1998, 2011, 2015, 2018 Tacoma DCSB OR MT
    For sure! Dry in garage and it will look good until you back it out!
  2. Apr 1, 2021 at 11:12 AM
    #3202
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Nothing looks cleaner than black..... for the first 15 seconds after you wipe it down. :D
  3. Apr 2, 2021 at 4:55 PM
    #3203
    SCTACO831
    SCTACO831 Active Member
    Santa Cruz, CA
    2021 TRD Off Road DCLB
    265/70/17 Falken Wildpeak & 17x9 +1 Offset Fuel Nitro Wheels & Stock Suspension
    TT005, VR812 and rblalliance like this.
  4. Apr 2, 2021 at 7:58 PM
    #3204
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Did I post on here yet, this photo?
  5. Apr 4, 2021 at 5:26 PM
    #3205
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    Vors VE37 17x8.5 wrapped in Kenda Klever 33x10.5r17
    Lift is Icon RXT setting two with B110's, Bilestein 5100 OME887, Full skids sagging the front to about 2.5" of lift
  6. Apr 5, 2021 at 12:58 PM
    #3206
    TayTay Ankles
    TayTay Ankles Well-Known Member
    I think that actually looks pretty good. About to pull the trigger on those wheels but they are +4 offset. with the lift I'm about to get, I was advised that it will rub unless I get the spacers. I just don't want my wheels to stick out further than the fenders. Do you have any pics of your fender line? Also, what size tires are those?
  7. Apr 5, 2021 at 1:32 PM
    #3207
    COS_TACO
    COS_TACO Well-Known Member
    Colorado
    2018 SR5 ACLB V6 4x4
    What size tires were you planning to run (for which you were told they would rub). I've been eyeing these wheels too (the TRD 4runner wheels which have +4 offset). I've searched a lot on this site and from what I can find, 265/70/17 shouldn't rub on stock height. (maybe slight rub on front mud guards? or at full lock with some bounce?). Someone please correct me if I am wrong.
  8. Apr 5, 2021 at 5:58 PM
    #3208
    DanMan611
    DanMan611 Well-Known Member
    Dan
    Hellertown, PA
    2021 DCSB TRD OR 6MT 4X4
    Here is a picture of the 4Runner Pro wheels (17x7, +4mm offset) on my 2021 TRD OffRoad with Pirelli Scorpion All Terrain Plus tires (265/70-17). The sidewalls poke out just a bit, but the tread is covered by the fenders. No rubbing at all for my truck with stock suspension - although I removed the OEM mudflaps before I put them on, just to be safe.
  9. Apr 5, 2021 at 9:45 PM
    #3209
    TayTay Ankles
    That looks awesome! Great photo man. I may have to get different wheels then because of what this shop is telling me.
    So the setup I was planning on going with is the Eibach pro truck lift stage one at the second clip setting (roughly 2.5) in front, 1.5 toytech block in back, I was advised to get a UCA since the lift is above 2 inches, all paired with a 275/70/17 KO2. They said I should go with a wheel that's close to a -4 offest or greater so I wouldn't rub on the SPC UCA.
    I then thought of a wildpeakat3 265/75/16 to fill the wheel well a bit but I wasn't set on 16s.
    DanMan, you plan on doing any sort of lift or leveling kit?
    CosTaco, yeah I haven't seen anyone on here rub with that tire on stock setting. I almost considered doing it because trying to deal with a lift has been a bit of a headache.
    COS_TACO[QUOTED] likes this.
  10. Apr 5, 2021 at 9:56 PM
    #3210
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Kmc 535, 33x10.5 Kenda Klever Rt. Old photo but the wheels are now rock rashed to piss, downfall of narrow tiresPSX_20210303_185215.jpg
    rblalliance, COS_TACO and AStinkyBumb like this.
  11. Apr 5, 2021 at 10:05 PM
    #3211
    HashTag_Overland
    HashTag_Overland Active Member
    2021 Tacoma DCLB 4x4 TRD Sports
    New to this forum. Here is my first upgrade to my 2021 Tacoma.
    Enkie 17x9 0 offset with 265/70/17 - no lift... yet :)
    SpaceTrim and DanMan611 like this.
  12. Apr 6, 2021 at 4:18 AM
    #3212
    DanMan611
    Dan
    Hellertown, PA
    Nope, no need for any kind of lift for me.
    COS_TACO likes this.
  13. Apr 6, 2021 at 6:44 AM
    #3213
    TayTay Ankles
    Do you have any other pics? Full side body and fender line pics? Those are Stealth 6's right? -25 offset? I'm looking at either those or the BR6 at -12 offset.
    It also depends if and when SCS gets their wheels back in stock.
  14. Apr 6, 2021 at 6:46 AM
    #3214
    TayTay Ankles
    Are those 285s KOs with those BR6s? Any Spacers?
  15. Apr 6, 2021 at 8:44 AM
    #3215
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    Icon Rebounds 17x8.5 0 offset
    Cooper XLT 285/75/17
    putt1333, NinGee87 and rblalliance like this.
  16. Apr 6, 2021 at 8:50 AM
    #3216
    TayTay Ankles
    Do you have any wheel spacers on there?
  17. Apr 6, 2021 at 9:34 AM
    #3217
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Nada
    TayTay Ankles[QUOTED] likes this.
  18. Apr 6, 2021 at 10:44 AM
    #3218
    TayTay Ankles
    what size tires? So those are sport wheels with +30 offset and then you put 1.25 spidertrax on them correct? That alone makes your wheels poke out that much? What size tires do you have?
    I'm asking because I'm doing an Eibach 2.5 in lift with SPC UCAs and they told me that I my sport wheels would rub on the uca even with the spacers.
    Do you have aftermarket UCAS?
  19. Apr 6, 2021 at 11:02 AM
    #3219
    TayTay Ankles
    no rubbing? Did you have to do a cmc or spacer?
  20. Apr 6, 2021 at 9:40 PM
    #3220
    Chip_311
    Chip_311 Well-Known Member
    Brian
    NJ
    2017 DCSB OR
    BFG KO2s Pro Grille Pro Skidplate Pro Fox Suspension DShackles F & R CaliRaised LED Bumper Baja designs S2pro / S1 CaliRasied Off-road Sliders Waterport R4T Arm Skids RCI Skids Weather tech Visor Front Camera SCS Wheels Rear Bumper Covers Maxtrax Recovery Meso Gas Hole/Turn Signals Pop n Lock Kit Extended Rear Breather Expedition Essentials TPAM Midland USA Comms Clazzio Leathers Victory 4x4 Mollie Garmin Tandem Mountain Hatch Bestop2 Thule Evo Rack
    Yes stealth 6 265/75r16 ko2
