Show off your wood working skills.
Discussion in 'Sports, Hobbies & Interests' started by Streetsurfz727, Sep 2, 2012.
  1. Oct 10, 2014 at 10:25 AM
    #101
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Make a header out of plywood ?
  2. Oct 10, 2014 at 10:31 AM
    #102
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That's my thinking, more dimensionally stable. I want to rip 8" strips of plywood, screw it to the top of the studs on either side, support the ends, then cut off the studs. Right now, I'm thinking 3 layers of 3/4" plywood glued and screwed to either side of the studs would be more than enough but just want some sort of load chart to check my thinking. The span is 10' and it only supports the floor above (house is balloon framed so none of the roof load goes through what I'm messing with).
  3. Oct 10, 2014 at 9:30 PM
    #103
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Here are a few of mine.
    - A 9 foot tall cabinet for the garage. (painted pine with unpainted tempered panels)
    - Other garage cabinets. (MDF painted to look like mahogany with flat black pine trim)
    - Some tables. Kids game table (checkered) is maple. Hall table (under mirror) is anigre. Narrow high top is yellow pine. Butcher block style dining table is unknown wood. I got the top cheap and just did some minor repairs and stained it. Legs of it are painted maple.
    - Pair of book cases. (sapelle & maple)
    - Library (mahogany & maple) It's currently 8 ft tall and 9 ft wide. Eventually I'll add another 2ft on top and then mirror them on the opposite wall of the room.
    - A mirror frame. (maple with mahogany trim)
    - A gun cabinet (red gum). Originally had all hidden hardware and secret lock. Door was too heavy for hidden hinges though so now has more traditional hinges and keyed lock.
  4. Oct 10, 2014 at 9:32 PM
    #104
    OZ-T
    Peter North
    British Columbia
    Why not just install a regular dimensional lumber header ?
  5. Oct 11, 2014 at 8:18 AM
    #105
    ttttrd
    ttttrd Member
    Central Washington
    14 Tacoma Dbl Cab TRD
    WeatherTech mats, LED lights for: bed, interior & exterior, Wet Okole heated seat covers, Gentex Auto-dimming mirror, Bloodwood custom gear shift knob, AVS hood Aeroskin, Fog light mod, Bed compartment combo locks
    Wood turner here. This is a mortar/pestle I made for my pharmacist daughter-in-law.
  6. Oct 11, 2014 at 9:59 AM
    #106
    Pugga
    Massachusetts
    I figured plywood on edge would be stiffer and the dimensional lumber around here is junk. They tend to warp a lot.
  7. Oct 11, 2014 at 10:11 AM
    #107
    OZ-T
    Peter North
    British Columbia
    8' plywood isn't going to be as effective for a 10' span
    You could also consider LVL
  8. Oct 11, 2014 at 8:21 PM
    #108
    Pugga
    Massachusetts
    Even if you glue and screw 3 pieces? I figured if I stagger the joints it would work. I can use dimensional lumber, just figured the plywood would be stiffer and less prone to sagging as long as I use enough of it. I'm basically going to make a built up lvl, sort of.
  9. Oct 11, 2014 at 8:22 PM
    #109
    OZ-T
    Peter North
    British Columbia
    Well , I don't know of a table for built up plywood beams , if it was me I would go with a kiln dried dimensional header or an LVL
  10. Oct 11, 2014 at 8:25 PM
    #110
    Pugga
    Massachusetts
    Thanks for the input, I'll look into lvls or see if I can find a better lumber yard around me. The ones I've found so far aren't very good. They cut everything really green, dry it fast, then it all sits outside.
  11. Oct 11, 2014 at 8:26 PM
    #111
    OZ-T
    Peter North
    British Columbia
    See if you can get kiln dried Fir or bite the bullet and go LVL
  12. Oct 11, 2014 at 8:29 PM
    #112
    Pugga
    Massachusetts
    Will do. Thanks for the help.
  13. Oct 11, 2014 at 9:00 PM
    #113
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Bought a Kreg K5 and some clamps. DIY here I come..
    Hopefully.
  14. Oct 11, 2014 at 9:20 PM
    #114
    Pugga
    Massachusetts
    The Kreg jigs are awesome! I love mine, very easy to use.
  15. Oct 12, 2014 at 10:15 AM
    #115
    T4RFTMFW
    Hoping to put it to good use, trying to think of a small first time project so we get acquainted. :D
  16. Oct 12, 2014 at 11:25 AM
    #116
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    I travel to Wilmington nc about twice a year. But try woodnet or lumberjocks forums.
  17. Jul 21, 2015 at 4:49 PM
    #117
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
  18. Jul 21, 2015 at 4:53 PM
    #118
    tomwilson74
    Tom
    West Virginia
  19. Jul 21, 2015 at 7:03 PM
    #119
    krap22
    krap22 Well-Known Member
  20. Jul 21, 2015 at 11:35 PM
    #120
    scocar
    scocar Patron of the Farts
    Nice to see someone still knows how to brace a gate correctly. I swear to god, even a moron has a 50% chance of getting it right, and most of the time I see it wrong. Sadly, at houses I buy, too.
    scottalot likes this.
