Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Oct 11, 2015 at 5:30 PM
    #2981
    Phoenix autoworks
    Phoenix autoworks Stock but fun!!!
    Josh
    North Phoenix
    95.5 Tacoma 4x4 3.4 manual
    Stock but I use it anyway!!!
    I tow these!!!
  2. Oct 12, 2015 at 11:54 PM
    #2982
    Black n blue
    Black n blue Active Member
    Oahu
    06 TRD SPORT LONG QUAD
    886 OME SUSPENSION BUSHWACKER FLARES DEMELLO OFFROAD 3 HOOP ACRO LIGHTS
    I'm moving from colorado to South Carolina i have a 2006 longbed quad cab with the 4.0. would i be able to tow a 70 challenger (3400lbs) on a trailer that distance. i plan on installing an aftermarket transmission cooler and keeping it in 4th with average speeds of 70mph. what else should i be doing to prevent problems?
  3. Oct 13, 2015 at 12:10 AM
    #2983
    Phoenix autoworks
    Josh
    North Phoenix
    I'd get a tranny flush, oil change, tire rotation, spin balance, and equally aired up tires. If you can afford It something like an add a leaf, helper spring, or high pressure bump stop. Park the car on the trailer nose first. If you put the engine in the back of the trailer axles, it will sway. The truck can handle the weight, make sure the hitch can. Have it inspected at u-haul if you need to. I've seen lighter loads lost with bigger trucks cuz of cheap hitches towing more than rated to.
  4. Oct 13, 2015 at 12:15 AM
    #2984
    Black n blue
    Oahu
    i currently have an add a leaf the previous owner had a topper on it and installed the addaleafs to even the ride hight out and it has the factory tow package. i had the transmission and differentials flushed when i bought the truck about 15000 miles ago should i flush it again?
  5. Oct 13, 2015 at 12:18 AM
    #2985
    Phoenix autoworks
    Josh
    North Phoenix
    Nah your good to go other than last min tire rotation,bal,air up. If you go over 3500-4000 lbs get a trailer brake controller if you don't have one already, or make sure trailer has surge brakes.
  6. Oct 13, 2015 at 12:24 AM
    #2986
    Black n blue
    Oahu
    i was researching the trailer brakes. ill be renting the trailer, most likely uhaul, i can't seem to find if the trailers have brakes or not.
  7. Oct 13, 2015 at 12:27 AM
    #2987
    Phoenix autoworks
    Josh
    North Phoenix
    Flatbed double axles do. Single axle car dollies don't. They might not rent to you, they have strict policies. I needed my 3/4 ton to tow a vw golf. Said half ton was to small.
  8. Oct 13, 2015 at 12:30 AM
    #2988
    Black n blue
    Oahu
    ridiculous, i guess ill have to take dads chevy custom to pick up the trailer then. i didn't think about that.
  9. Oct 13, 2015 at 12:34 AM
    #2989
    Phoenix autoworks
    Josh
    North Phoenix
    Ask first. I know a few who have gotten trailers from rookie cashiers. But be warned.
  10. Oct 13, 2015 at 12:35 AM
    #2990
    Black n blue
    Oahu
    the website just quoted me $411 for 6 days. and it required me to list whats towing and being towed
  11. Oct 13, 2015 at 12:37 AM
    #2991
    Phoenix autoworks
    Josh
    North Phoenix
    Does it qualify to tow that car online?
  12. Oct 13, 2015 at 1:15 PM
    #2992
    Black n blue
    Oahu
    yea on uhauls website
  13. Oct 13, 2015 at 1:42 PM
    #2993
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Budget rents car trailers as well, might as well check and see what they would charge you. As for adding a trans cooler if you have a factory hitch you already have a trans cooler as standard equipment.
  14. Oct 14, 2015 at 8:59 PM
    #2994
    Black n blue
    Oahu
    factory trans cooler eh? ill have to look i didn't think about that. I'm currently in guam on deployment but ill have to look when i get back to Hawaii where the truck is. do i need to put a bigger trans cooler in it? i always though it was just a combined trans cooler and radiator.
  15. Oct 15, 2015 at 3:22 AM
    #2995
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    IMO, seems a bit fast to be towing that weight. I tow at 65 on the speedo, which is about 63mph. Better stopping, better gas mileage, and lower rpm's. Your call, good luck. Be safe.
  16. Oct 15, 2015 at 6:45 AM
    #2996
    NotRed
    NotRed Well-Known Member
    In California towing is limited to 55 mph (legally).
  17. Oct 16, 2015 at 10:49 AM
    #2997
    arnette64
    arnette64 Well-Known Member
    Amos, QC (Canada)
    2016 Inferno TRD Sport Double Cab 4X4
    '16 Inferno TRD sport DC
    Kodiak 26qs, 4254 lbs unload.
    Complete OME suspension with dakars.
    rlj251 and ancient11 like this.
  18. Oct 16, 2015 at 11:04 AM
    #2998
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    It's interesting in Michigan. Single axle is limited to 70 but anything dual axle is automatically 55.
  19. Oct 19, 2015 at 8:52 PM
    #2999
    Tbell18
    Tbell18 Well-Known Member
    iowa
    2009 Tacoma Trd Sport dclb
    see build...but not a whole lot
    jet ski (~1300lbs)
    ski nautique (~4000lbs)
    16' enclosed trailer (varying weights)
    tommyboy1234 and arnette64 like this.
  20. Oct 26, 2015 at 6:15 PM
    #3000
    Chitoson
    Chitoson Well-Known Member
    MA
    12 SR5 DCSB - 23 TRDOR DCSB
    My little boat, the "Kitty Galore".
    68dave likes this.
