Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Sep 17, 2016 at 4:19 PM
    #3361
    Wild Crow
    Wild Crow Well-Known Member
    James
    Anywhere is home
    2014 Baja
    20160917_190920.jpg 3500 lbs fully loaded ( that's 40 gallons of water, a full wine cabinet, and food.... don't forget food ) for a weeks vacation. I get betwwen 11 and 13 mpg flipping between 4th and OD ( depending on condition)
    Marty65, Nickel and Cuffs like this.
  2. Sep 17, 2016 at 5:01 PM
    #3362
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    check your owners manual, I bet it says NEVER use OD for towing. OD's on virtually all transmissions are weaker than the 'regular' gears, even towing easy constant speed on the level puts double the load on the drive train as non-towing. you need to run a higher RPM in a lower gear when towing.
  3. Sep 17, 2016 at 5:03 PM
    #3363
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Ya I dont sniff 5th gear when Im towing
  4. Sep 17, 2016 at 5:44 PM
    #3364
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    5th gear is cool in the turd gen per manual. 8.8 rear end and 5th gear towing might as well be a super duty:D
  5. Sep 17, 2016 at 6:28 PM
    #3365
    maxpower29
    Jordan
    Nova Scotia, Canada
    I dont have to really worry about it because mine wont even reach the 5th gear lol
  6. Sep 18, 2016 at 7:28 PM
    #3366
    Wild Crow
    James
    Anywhere is home
    2014 Baja
    We're sorry. The position with the job code "Mother" is currently filled. We will keep your application on file for one year. If the postion opens in that time we will call you in for an interview. Thank you
    Seriously though. Relax. It'll be OK. It's not your truck to worry about. I can and will use OD on flat ground.
    If the torque converter will stay locked and the transmission temperature stays cool, I'll flick it into OD. As soon as the converter unlocks (or even preemptively if a change in terrain is coming up) It's back into 4th. Is the same system I've used with my 2003 Tundra towing the same trailer. It hasn't complained about it even with 250,000 miles on the clock even with its earlier ( and also "weak" OD gear) A 340
    I bought the truck. It didn't buy me. I'll use it and drive it. If I break it I'll fix it.
    Nickel, NMroamer and NotRed like this.
  7. Sep 19, 2016 at 9:32 AM
    #3367
    Wild Crow
    James
    Anywhere is home
    2014 Baja
    Here's a nice shot of the teardrop after dark during Riverfest.FullSizeRender.jpg
  8. Sep 19, 2016 at 11:48 AM
    #3368
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    Tell me about your awnings!
    Wild Crow[QUOTED] likes this.
  9. Sep 19, 2016 at 5:56 PM
    #3369
    tacomatime
    tacomatime Well-Known Member
    Florida
    2018 TRD Sport DCLB 4x4
    3" leveling front, and 2" rear Rough Country. BF Goodrich 305/65/17 KO2
    I am not sure what the tractor weighes. I would say around 200lbs or so.
    I have no doubt that the v6 can tow the ATV and the 3200lb camper. If the truck is rated for over 5000lb for towing, I wouldn't worry about it.
  10. Sep 20, 2016 at 3:10 PM
    #3370
    Wild Crow
    James
    Anywhere is home
    2014 Baja
    Um, what do you want to know? They hang off the side of the trailer to keep us dry in the rain. They can double as a changing room. Or how did we make them? Well, we is more she since Beth designed and built them. I apologize preemptively for muddying up this thread with build details. Here is the excerpt from our build thread on the Expedition Portal:
    In the meantime.....it was awning time! Originally we were going to just purchase a Fiamma or ARB or similar awning and hang it off the side. The more we thought about it the more we didn't like the looks of the when closed (it would ruin the lines - and look out of place on the traditional style of our trailer).
    What to do, what to do?
    Build our own of course!
    A little Sunbrella fabric, some Sunbrella awning thread, a little Keder welt, a few tent pole repair kits,and some awning rail and voila! Awnings! Well, not quite that easy, but it all came together quite well. Did I mention that my wife is a genius, superb designer, and she sews too?
    This shows the roll of Sunbrella fabric, thread, Keder welt, grommets, nylon strapping and tent pole kit
    Closeup (sample)of the awning rail.
    and this is an example of the Keder welt. Sewn to your fabric of choice this allows you to slide the awning into the rail with ease.
    While I won't say it was simple, I was amazed at how simple Beth made it look. The awning was sized to fit squarely over each door to provide us with some sort of shelter as we ingress and egress (um, that's enter and exit - or climb in and out as the case may be). The tent poles were cut so they were slightly long and formed a nice arched rainfly, exactly like the ones on our Cabelas tents we've camped in for years. A tie was sewn in the center to hold the poles in place, and the nylon webbing was used to make the pockets for the pole ends to catch into - otherwise they'd bust through the awning doncha know!
    Closeup of the nylon pocket, and the rubber grommet - which captures the upright pole, without which the awning is just an interesting door hanging on the side of the trailer
    The end of the upright is a nice fancy hook, which hooks through the grommet. This should keep the wind from blowing the awning off the upright.
    This shot is a nice example of how it slides together. You can see the awning, with attached Keder welt, and how the welt slides into the awning rail.
    This is the finished product. You'll have to imagine that the uprights are actually connected to the running boards on the trailer with some Bimini hardware.
    When not attached the awning and poles will live in a duffel bag in the basement (EDIT! This proved to be a bad idea - the tubing held water from rain and it was enough to make anything fabric in the basement wet. We have since installed pvc tubing to store all the poles in keeping everything else in the basement dry), and all you will see on the trailer is the awning rail above the doors. The clamps will be replaced with screws, so you won't see those either!
    Here you can see the side walls we added later to give us a dry changing room on each side
    And here is the side wall rolled down. This was the Overland Expo from last October. If any of you went you know it rained a little. We used every awning we have in the trailer to stay relatively dry.
    mbroughton02 and Toyko Joe like this.
  11. Sep 20, 2016 at 4:45 PM
    #3371
    Cuffs
    Fantastic! Guess I should have just messaged you... Sorry everyone!
    And your wife IS a genius!
  12. Sep 23, 2016 at 10:19 AM
    #3372
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    Ready to pull out for one last time this season.
    Hikergal and Cuffs like this.
  13. Sep 24, 2016 at 5:45 AM
    #3373
    Doug2000
    Doug2000 Well-Known Member
    London, Ontario, Canada
    2017 Tundra 5.7L
    I'm towing a similar trailer, a 2007 Escape 17b Fibreglass. I found after I changed to a K&N drop in air filter, at 70mph, in OD, the truck didn't hunt for gears. It's like it gave it 2 extra horse at 2500 RPM.
    If I was told the filter made a performance difference, I wouldn't have believed it. I only bought for the lifetime warranty. I don't drive on dusty roads, so that wasn't a concern.
    Hikergal likes this.
  14. Sep 24, 2016 at 7:55 AM
    #3374
    Cycledoc
    Cycledoc Member
    I tow a 19 foot airstream. Dry weight is 3600 estimate with water and personal effects about 4500lbs. Does well on the flat; lugs a bit on hills--going over North Cascades in 3rd gear on steeper stretches. Mileage between 14 and 16 depending on terrain. I use the manual option on the automatic, rarely in 5th gear. Toyota advertises this as rated for over 6500 lbs but frankly I wouldn't be comfortable pulling more than the above. I'm an old guy, rarely if ever over 65 mph on the flat, and usually around 60 mph. Transmission behaved strangely (searching for right gear) until I had it "flashed" with a software upgrade at the 5000 mile service. Seems better now.
    Hikergal and Wild Crow like this.
  15. Sep 24, 2016 at 10:49 AM
    #3375
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    gear hunting under load is a sure sign you need to downshift it. but heck, I downshift my old mercedes (and volvos before that) when their old hydraulic (non-electronic) 4-speeds hunted just going up a grade running light. on those 4-speed, 3rd gear going up a grade is just a happier place for everything, and I usually leave it in 3rd going down too, for the additional engine braking.
  16. Sep 24, 2016 at 10:57 AM
    #3376
    Cycledoc
    Cycledoc Member
    The gear hunting was without the trailer and was quite annoying. When under load, i.e. pulling the traileer, I use the manual auto (I think it' stormed S mode)to change gears as needed and of course down shift for engine braking as well. The flashing of the transmission software appears to have improved the problem when in the fully automatic mode and not pulling the trailer.
  17. Sep 24, 2016 at 11:23 AM
    #3377
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    pulled it 450 miles to the beach last week. 3 kayaks, 1 paddle board (room for 2), paddles for each, 1 surfboard, 4 fishing rods, and a 33'' spare tire for the trailer.
    first leg of the trip also had some smaller car wheels/tires on the tongue to drop off at my uncles along the way.
    Jmad1997, 33harman, arnette64 and 2 others like this.
  18. Sep 24, 2016 at 12:13 PM
    #3378
    Doug2000
    2017 Tundra 5.7L
    2007 Escape 17b, 2400lbs, 13 mpg
  19. Sep 24, 2016 at 6:37 PM
    #3379
    br636
    br636 Active Member
    Brian
    2016 Black Tacoma TRD OR
    Towed this today. The rental company said the combination was 6000 lbs but from what I can tell it was more like 4-4500.
  20. Sep 25, 2016 at 8:48 PM
    #3380
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Jayco 21' with a 2.7 auto. Pulls great and will maintain 70mph on the interstate. Best part is the mpg varies between 14.5 to 16mpg.
