Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Jan 23, 2017 at 9:25 PM
    #3481
    Inferno_OR
    Inferno_OR Well-Known Member
    Nate
    '16 TRD OR - Inferno DoubleCab
    stock....for now
    16' uhaul w/ ramps. tacoma did great!!
  2. Jan 30, 2017 at 6:26 AM
    #3482
    ScrapmanIndustries
    ScrapmanIndustries Well-Known Member
    98 reg. cab tacoma, 17 access cab tacoma
    This aint the heaviest load ive had but i use my 4 bangers as a scrap wagon. If you know how to stack they can be more profitable than the bigger trucks.
    Nickel and theredofshaw like this.
  3. Feb 3, 2017 at 7:36 AM
    #3483
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
  4. Feb 3, 2017 at 5:56 PM
    #3484
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    old pic but just had to post
    MeFryRice and stickyTaco like this.
  5. Feb 4, 2017 at 4:00 PM
    #3485
    ScrapmanIndustries
    Not towing but loaded both of em so heavy they're riding on the frames. The silver ones been to the scrap yards like 10 times now and hasnt even hit 1k on the odometer. Hopefully the composite beds can withstand this type of abuse. If it does im really starting to like it. image.jpg
  6. Feb 5, 2017 at 8:02 AM
    #3486
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    It's a great camper you have and I nice set up. I tow a similar camper, same weight with my 2013, Can I make one suggestion that will make towing 10 times easier and less stressful. Add a set of Firestone Ride Rite air bags with the on board compressor, (around $350 in parts), kit is very easy to install. What a big difference in towing. Good luck and happy camping
  7. Feb 5, 2017 at 8:39 AM
    #3487
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    This past fall:
    Free wood burns hotter.
  8. Feb 5, 2017 at 4:50 PM
    #3488
    ScrapmanIndustries
    Is that the v6?
  9. Feb 6, 2017 at 4:01 AM
    #3489
    taczilla
    Marc
    2016 RAM Rebel
    Yes.
  10. Feb 6, 2017 at 4:55 AM
    #3490
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    Pit stop in the Humbolts/Avenue of the Giants on our way to the IRG teardrop gathering last year. Yeah I know, I put on Firestone ride rites a month later...
    donny, Wild Crow, NotRed and 2 others like this.
  11. Feb 10, 2017 at 8:46 PM
    #3491
    Locimota
    Locimota New Member
    DSCN4238.jpg 4k miles 10mpg, equalizer hitch no problems.
  12. Feb 10, 2017 at 8:51 PM
    #3492
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    What model is that? It looks like the perfect size.
  13. Feb 10, 2017 at 9:00 PM
    #3493
    Locimota
    Locimota New Member
    2015 Jayco Jay Flight SLX Baja Edition 145RB
    Toyota Truck likes this.
  14. Feb 10, 2017 at 9:00 PM
    #3494
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    wild stab says thats a 145RB, with the reversed axles to lift it up a bit ('baja kit' ?).
  15. Feb 11, 2017 at 10:18 AM
    #3495
    Jorgy1
    Jorgy1 Well-Known Member
    2019 MGM Tundra CrewMax 4x4
  16. Feb 16, 2017 at 9:45 AM
    #3496
    GJefe4x4
    GJefe4x4 Member
    South East LA
    2012 Tacoma TRD LB 4x4
    20 ft pontoon. A little over 27 ft total trailer length.
    Jorgy1 and Lord Humongous like this.
  17. Feb 20, 2017 at 10:31 AM
    #3497
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    2005 fleetwood bayside Cp 3200lbs dry 19.1ft long
    Nickel likes this.
  18. Feb 22, 2017 at 6:59 AM
    #3498
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    I thought this might be a good place to ask. Has anyone mounted a tv in their travel trailer? I'm thinking about putting one in our jayco 195rb. I've done it countless times with standard construction but this lightweight trailer has me concerned.
  19. Feb 22, 2017 at 7:14 AM
    #3499
    anonemoose
    Bill
    Big Pine, Calif
    Just a heads up. If you are thinking about adding a solar panel to your setup, SolarBlvd has their 120w flexible panel on sale for $119, normally $276. They are light weight and less susceptible to damage then hard crystalline panels.
    Solar Cynergy 120 Watt 12 Volt semi-flexible solar panel has an impermeable lamination coats the entire module, allowing it to contour and flex against curved areas, eliminating any need for custom mounts. The panel can be affixed by adhesive stick or glue mounting ease of installation. The thin, lightweight module can also be affixed to or sewn into canvas, including bimini tops.
    Ideal for RV boat or tight spaces or crowded areas that are typically off limits for traditional glass and aluminum models. Suitable for marine use: the laminate coating on the exterior of the panel makes it impervious to saltwater splashing, rain, and other weather elements. Completely waterproof Junction box. sealed and waterproof junction box makes it waterproof for rain splashing. Light weight 82 % lighter than aluminum glass solar modules Durable surface is less than 1/8" / 2.5mm thick Quick Connectors: 1.4 meters of flex fitted with S-S connectors for quick and easy set up. 20 year limited warranty. Grommets included.
    https://www.solarblvd.com/product_info.php?cPath=1_269&products_id=3082
    Nickel likes this.
  20. Feb 22, 2017 at 7:50 AM
    #3500
    Jorgy1
    I have tried a few tv's over the years in light weight rv's without good luck. The units I have had bad luck with were the ones with the integrated DVD players. Seemed like the perfect rv tv as you can use it for just movies when your off the grid, but the DVD mechanism couldn't take the road vibrations I guess
