Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Aug 1, 2018 at 4:41 PM
    #4501
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    It towed great. Actually better than the Rockwood Roo 233S that has a 4300 dry weight. I think that has to do with the way the weight is distributed though. But yeah, my truck does great now that I have modified almost everything to do it. A tundra would have been cheaper, but I love my INACOMA. As for passes, no problem. I can run any pass I have come up on at about 65. Just have to be able to afford the fuel to do it. Got a whoopping 7mpg towing from Pocatello, ID to Missoula, MT and back. With both trailers in wind both ways. And get 13mpg not towing in any condition over 60mph. Under 60mph it goes up towing and not towing. But again, I have spent more money building this truck to do it, than a new tundra would have costed me, with trade in. LOL
  2. Aug 2, 2018 at 9:22 AM
    #4502
    SpokoTaco
    SpokoTaco Well-Known Member
    Justin
    2014 Black Tacoma OR AC
    6" RC suspension lift, 285 Nittos
    With the towing package towing the trailer over a pass, it will be fine, but just expect to almost be able to watch your gas gauge go down as your scaling up passes; as well as being aware of near fill up areas for gas
  3. Aug 2, 2018 at 9:38 AM
    #4503
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    And watch your trans temps skyrocket. Those long passes unlock the torque converter and build heat. I was running the factory trans cooler and an aux cooler in series and still had to let the transmission cool on a few of the passes. If your not monitoring the temps it would be very easy to do damage.
    mr.trd likes this.
  4. Aug 2, 2018 at 9:48 AM
    #4504
    SpokoTaco
    Justin
    With the towing package comes an upgraded trans cooler. do you have that, or just standard? Also, watching RPM's this past weekend, it'll sit right around 4-4500 rpms on uphill but never seemed to break up past that.
  5. Aug 2, 2018 at 10:28 AM
    #4505
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    All tacoma's with the tow package come with the same cooler. Without the tow package the trans cooler is in the radiator. I had the cooler in the rad plus the tow package Toyota cooler and another aftermarket cooler in series. When the outside temps were warm and on the steeper long grades the temps would start to climb as soon as the torque converter unlocked. I would have to pull over occasionally to allow the temps to fall before continuing.
    I now in a 18 with the manual trans. No worrying if I'm damaging the trans.
    SpokoTaco[QUOTED] likes this.
  6. Aug 2, 2018 at 10:38 AM
    #4506
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    No. Manual transmissions don't generate heat the way automatics do, because there's no active pumping of fluid for the purpose of carrying a load. The gears themselves carry all of the load from the engine, so the oil is only there for a lubricant. Most of the heat from an automatic comes from the torque converter, which a manual transmission lacks.
  7. Aug 2, 2018 at 4:29 PM
    #4507
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    If you are running those RPM's yes the truck can do it but your torque convertor is not locked up and you are generating heat faster than you can cool it. I also have two external coolers and it won't keep up. That is why I put 4.88's in the truck. I no longer have the trans unlocking. But top speed is very low.
    Ruggybuggy[QUOTED] likes this.
  8. Aug 2, 2018 at 8:21 PM
    #4508
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    my tacoma doesn't have an automatic... why would it unlock if it wasn't about to shift, or its already in a gear too low to lock?
    (my F250 4-speed slushbox will only lock in 3rd and 4th, but thats good for all speeds above about 40MPH even up the steepest grades).
  9. Aug 2, 2018 at 9:43 PM
    #4509
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    If you have a manual nothing unlocks. It only applies to automatic transmissions that have a torque converter.
  10. Aug 2, 2018 at 10:16 PM
    #4510
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    sorry, i worded that poorly. i was asking, when does the tacoma automatic unlock when you're towing over mountains and stuff ? I don't know because I've not driven an auto tacoma. i know when my ford locks and unlocks.
  11. Aug 2, 2018 at 10:24 PM
    #4511
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Anytime you get your foot into it. You can feel that its locked based on rpm and as soon as you step on it and it downshifts to 4th the torque converter stay unlocked if you have your foot into it. Easy up on the throttle and it will lock but its impossible on the long steep grades to keep it locked.
  12. Aug 2, 2018 at 10:30 PM
    #4512
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    hmm, what if you manually downshift ahead of time at a point where you can coast on the throttle for a couple seconds? thats what I do with my ford .... I'll shift at the bottom of the hill before it starts to climb, let it engage the TC lock while basically coasting, THEN apply power up the grade...
    If I do find myself in 3rd after an auto downshift under heavy throttle, I back off on the pedal for a couple seconds, and watch the RPM drop to the locked-in-3rd rate, then step on the power pedal again.
  13. Aug 2, 2018 at 10:31 PM
    #4513
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    thats what I do with my stick shift tacoma, too. shift into 4th or even 3rd at the bottom of a steep grade, keep the rpms in the happy zone.
  14. Aug 2, 2018 at 11:11 PM
    #4514
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    The problem is that on long steep grades it stays unlocked and starts building heat. On smaller steep grades I wasn't having a issue. As soon as the toque converter lock my trans temps fell like a stone.
  15. Aug 3, 2018 at 6:43 AM
    #4515
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Your best answer is to get it in the right gear for the speed before you can let heat build up from hunting. If you're going to be going 65-ish up a steep grade, 3rd (2nd gen 5-speed auto) is actually fine, and keeping it spinning at 4,500 rpm is a lot better on the engine than lugging it around in D while trying to avoid it from down shifting.
    Towing is a lot like driving a performance car. Everything will work best when you keep the engine near its peak power. Engine braking, acceleration, transmission wear, everything. This is true for the auto and manual... If you were to try and lug up a hill in a high gear in the manual (lets say 6th or 5th) you're putting a ton of torque into the torque converter and it's just going to be abusive. In all cases it's just best to put your engine in its happy place between 3,500 and redline.
  16. Aug 3, 2018 at 6:54 AM
    #4516
    Noelie84
    Noel
    Wales, Maine
    FTFY. Manual transmissions don't have torque converters.
  17. Aug 3, 2018 at 7:08 AM
    #4517
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Anyone here trailer a Polaris rzr 2 or 4 seater? How’s your Tacoma handle it?
  18. Aug 3, 2018 at 7:13 AM
    #4518
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    If your running 4500 rpm on steep grade the torque converter will be unlocked. It doesn't matter how you drive it. On steep grades the torque converter will be unlocked and your generating lots of heat. If the grade is long enough heat will build past 220°. I believe the light comes on at 240 but at the point trans fluid is deteriorating quickly.
    2lazy2 likes this.
  19. Aug 3, 2018 at 7:17 AM
    #4519
    Noelie84
    Noel
    Wales, Maine
    Agreed. The light denotes an emergency is about to occur. So if the light comes on, definitely pull over ASASP, make a sandwich, and let it cool off. And then have the transmission fluid changed at the earliest convenience, because it's pretty much shot once you cook it.
  20. Aug 3, 2018 at 7:44 AM
    #4520
    snowmanwithahat
    Huh, yeah, not sure why I typed torque converter... but yeah, a clutch is really just a 1:1 torque converter anyway. It converts torque to equal (or less when slipping) torque on the output side...
    torque converters in automatics just happen to be nothing more than hydraulic turbines with a specialized purpose.
    My point is still valid though. Hang out at your engine's happy place when it comes to power, and you'll cause less issues with all components, whether its an auto or manual. There's a reason why people driving manuals put them in a high gear while driving slow to check for slipping clutches. The torque required to move the truck at slower speeds with a high gear (numerically low ratio) is extremely high, and that's when you'll feel a slipping clutch if its going bad.
    Higher RPM with proper gear selection is far better than trying to play games and let these lug along like they're a diesel in a high gear and maintain low RPM.
    I'm not saying just floor it to hold it at a higher RPM either... But it is totally valid to maintain 35mph at 4,500 RPM up a steep grade in 2nd where you could have done it at 3,000 RPM in 3rd. It's going to be easier on the driveline than lugging it in a gear that might induce slipping on a clutch, or hunting on an automatic.
