Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Sep 7, 2018 at 4:37 PM
    #4641
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Cool trailer, do you have a build thread or some more pictures of your trailer?
    k8md likes this.
  2. Sep 7, 2018 at 8:53 PM
    #4642
    Karasu
    Karasu Member
    99 Tacoma 4WD Ext Cab V6
    Great info, thanks!
    Phoenix2000[QUOTED] likes this.
  3. Sep 7, 2018 at 9:01 PM
    #4643
    Karasu
    Karasu Member
  4. Sep 7, 2018 at 9:11 PM
    #4644
    Karasu
    Karasu Member
    I used a Hayden Automotive 679 Rapid-Cool Plate and Fin Transmission Cooler. Got it on Amazon. If you list a 99 Tacoma V6 their screening system will say something to the effect that "this does not fit your vehicle", but it does. I think the default Hayden product is one size smaller (I forget what the item # is) and that's the one that will show up if you do an Amazon search for a transmission cooler with a Gen 1 truck listed as in your "garage". Read somewhere (maybe here!) that this one, being a bit bigger, does a noticeably better job of cooling. I (actually a master mechanic neighbor of mine) didn't go in-line, but put this on a separate loop. My info (not necessarily valid) is that the factory one does little and that there is some slight risk of the barrier rusting through between the coolant and the transmission fluid in the stock radiator, which would be... bad ;-) Note that even though installation instructions say you can leave radiator in place to install these, my buddy just pulled the radiator for easier access. No big deal to him, would have been a semi major pain in the butt to me. Figured it wouldn't hurt to replace the coolant anyway. I have no trans temp gauge so can't report on effectiveness.
    gunn_runner likes this.
  5. Sep 7, 2018 at 9:21 PM
    #4645
    Karasu
    Karasu Member
    Forgot to add: you'll probably need to buy more trans fluid capable tubing if you go with this kit. I think their kit includes good tubing but not enough to install "non in-line" with stock cooler.
  6. Sep 7, 2018 at 9:29 PM
    #4646
    Jay1313g
    Jay1313g Well-Known Member
    Jay
    Arlington, TN
    2018 SR5 DblCab 2WD
    2017 TRD Off Road pulling a 2011 Jayco 2006 that would probably tip the scales at ~2,500+ pounds.
    The gas mileage and towing increased with the latest ECM TSB applied that fixed the shifting.
    This was running ~70 mph on I-40 West from Memphis in to Arkansas for almost 250 miles. I did try to draft 18 wheelers whenever I could.
    NotRed and ColoradoTJ like this.
  7. Sep 9, 2018 at 1:06 PM
    #4647
    bigbear1612
    bigbear1612 Well-Known Member
    Gary
    2018 Toyota Tacoma TRD 4X4 silver sky metallic
    Ride Rite airbags with onboard compressor, Trail Ridge towing mirrors, 28,000 gwv external transmission cooler, Roll n Lock bed cover.
    I am a newbe here and I have a 2018 Tacoma TRD 4x4 with the tow package and automatic trailer sway control. I am planning to tow an ultra lite 18 ft travel trailer, dry weight 3350 lbs wet 4400 lbs. I will have a new weight distributing hitch with sway control. I think the truck should have no problem towing the trailer, any suggestions would be appreciated.
  8. Sep 9, 2018 at 4:57 PM
    #4648
    Tantaco37
    Tantaco37 Yes those are Cheech and Chong yard gnomes!
    Western Kentucky
    Had a 2017 TRD Off-road, now a GMC AT4
    Had these A.R.E. Overland Truck cap, Cover King Tactical seat covers, OME BP-51 full suspension and dakars, SPC adjustable UCA's, Husky Floor Mats, Mobtown Off-road sliders, Cali Raised light bar and ditch lights and bed stiffeners, mobtown off-road front ifs skid, uniden bearcat CB Amd firestick. Now a super fancy stock truck!
    Ohh I agree but I needed it and towed it less than 5 miles. Sucked ass and I drove with the hazards on and went no faster than 35. But I didn’t have a choice and no full size truck to use either
    k8md likes this.
  9. Sep 9, 2018 at 5:06 PM
    #4649
    Tantaco37
    Western Kentucky
    Hey now, know need to call me a dipshit. I did what I had to do for a very specified reason. I new what what I was doing even with my heavy leaf pack and adjustable suspension for heavy loads it was too much. But it’s my fucking truck, if it broke I’d take care of it. But don’t call me a dipshit. U don’t even know me.
    jdr43 and tacoRenner like this.
  10. Sep 10, 2018 at 9:20 AM
    #4650
    Genypig
    Genypig Well-Known Member
    Yev
    2018 Tacoma TRD OR
    I may have a few photos, but I believe that I lost most of them some time ago. :(
  11. Sep 10, 2018 at 2:35 PM
    #4651
    Chayse
    Chayse Well-Known Member
    ABQ, NM
    2015 Tacoma Sport
    3" Procomp lift, 33" BFG's, TRD exhaust, and cold air intake.
  12. Sep 10, 2018 at 6:55 PM
    #4652
    evan164
    evan164 Well-Known Member
    Evan
    Louisiana
    05 Prerunner SR5
    Added a trailer hitch and the 4 pin connector
    I’ve read that a manual transmission is bad for towing...so I chose to ignore that advice and tow this.
    It was on a hill and I promptly got stuck...we had to take the gator off and pull it up the hill. My poor little prerunner did great on the road though.
  13. Sep 10, 2018 at 7:34 PM
    #4653
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    I have towed 1000s and 1000s of miles with my Tacoma with a 6-speed, no issues whatsoever. most of those miles we were pulling a 3500 lb Casita, then I towed a 4500 lb Escape 21 from Dallas to Reno to the west coast.
    I think your issue in that photo above is your tires more than your transmission. put a good set of a decent A/T tire on there and I bet you wouldn't have gotten stuck.
    NotRed and evan164 like this.
  14. Sep 10, 2018 at 7:44 PM
    #4654
    evan164
    Evan
    Louisiana
    05 Prerunner SR5
    Yeah I wondered about that. It wasn’t a deep rut, just slick. So, i’m sure it was driver error and tires.
  15. Sep 10, 2018 at 10:07 PM
    #4655
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    my recently acquired 2002 f250 4x4 has crappy chinese highway tires, its got no freekin traction whatsoever on wet or loose stuff. my tacoma had fresh BFG A/T KO2's and all kinda bite on all kinda surfaces.
  16. Sep 10, 2018 at 10:39 PM
    #4656
    TacoTrooper
    TacoTrooper Well-Known Member
    James
    Vancouver, Canada
    2013 TRD Double Cab 6-spd manual
    2013 TRD Sport DCSB 6-spd manual
    Nice!! Truck and Trailer!
  17. Sep 10, 2018 at 10:53 PM
    #4657
    Chayse
    ABQ, NM
    2015 Tacoma Sport
    Thanks man!
  18. Sep 10, 2018 at 11:15 PM
    #4658
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    this was my camp after initial unload setup Wednesday-Sunday at CalStar 2018, Lake San Antonio, in south Monterey County, California... days were 100F, we were up til 4-5am each night stargazing. I didn't get a picture of the rig hitched this time, but it was same as it always is. the big drum on the lounger is the upper part of my 20" f/5 telescope.
    oldlefty likes this.
  19. Sep 10, 2018 at 11:18 PM
    #4659
    Nunya Bizness
    I only ever tow beotches that park in my spot!
    But Id like to tow a new Hideout soon also.
  20. Sep 11, 2018 at 4:39 AM
    #4660
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Which ones? Vee Rubber, Ohstu, Americus, Black Lion?
