Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Jul 23, 2019 at 4:10 PM
    #4981
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    Had to take the old girl for some TLC service work.
    jpereira2 likes this.
  2. Jul 24, 2019 at 6:41 PM
    #4982
    Epoch
    Epoch Active Member
    2018 Quicksand Tacoma TRD Off-Road
    The reason I chose to upgrade, a 2020 Rockwood Roo 23BDS (not my image, I haven’t picked it up yet). While technical possible to tow with the Tacoma it was best to get a larger truck to tow it and the toys.
  3. Jul 26, 2019 at 4:38 AM
    #4983
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Brought a tractor to work with it today.
    evan164 and Muldoon like this.
  4. Jul 28, 2019 at 9:30 PM
    #4984
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
  5. Jul 30, 2019 at 10:59 PM
    #4985
    HomerTRD
    HomerTRD Well-Known Member
    Alan
    Indiana
    2019 TRD OR
    All stock
    So far just my little utility trailer, but I would like to get a small camper trailer one day.
  6. Jul 31, 2019 at 12:52 PM
    #4986
    justrfb
    justrfb Active Member
    Rich
    2018 Black Tocoma TRD Off Road
    Hello All.
    Been a while... Looking at a Jayco Jay Flight 26 BH. We have a 2018 TRD OR. Thought "no problem" at first, then got scared, then thought "no-way" this morning and now looking at this post, I am thinking "sure". What do you think please?...
    4805 unloaded dry weight
    525 dry hitch weight
    29' tip to tail
    Be gentle please...
    Thanks.
    Justrfb
  7. Jul 31, 2019 at 1:09 PM
    #4987
    UncleBoone
    UncleBoone Well-Known Member
    Rich
    Taos, NM
    2018 Cement DCLB OffRoad
    This may be technically within the specs of your truck but I think it would be pushing the limit. We tow a 22ft Airstream that has a dry weight of 3600, a GVWR of 4500 and hitch weight of 394. Our trailer is also narrower than most at 7'3'' wide which makes the air move around it a lot better. Our 2018 DCLB OffRoad tows it very well with a good weight distribution hitch and brake controller but I don't think I would want to do much more. I heard once that a good general rule is to stay at 80% of your max towing capacity, I don't know where it came from but I have always tried to follow this rule and it has served me well. Just my 2 cents.
  8. Jul 31, 2019 at 1:35 PM
    #4988
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Based on the specs quoted you would be able to easily tow the trailer as is.
    However, I don’t think you would be happy doing it once you got loaded for camping. Your loaded trailer weight would put you over 5000# which would require a weight distribution hitch (pg 178 owner’s manual) adding another 100# to your tongue weight. Might even go over the 640# max tongue weight, limiting your truck payload to perhaps only driver, passenger and a few groceries.
    I’m basing my own good towing feeling on my situation: 3250# trailer/400# tongue weight, 20 ft., single torsion axle. My 2018 off road does my job well.
    Also, what @UncleBoone said about the 80% of max.
  9. Jul 31, 2019 at 1:50 PM
    #4989
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Depends on where you live in the country. If you're from a pancake state, you'd probably be ok. But if you live in the hill country, you're going to find yourself in the slow lane with your hazards going on a regular basis.
    Once you load that beast up for camping you'll probably be tickling 7k (depending on water capacity you may even be over). Assuming V6/Auto, your truck is only rated for 6400. Even with careful loading to balance the tongue weight, she'll be struggling.
  10. Jul 31, 2019 at 7:19 PM
    #4990
    Muldoon
    Robert
    Northeast Ohio
    I’ve never towed a camper but I feel like it could be a bit stressful at that weight. I’ve put many many miles on pulling an 5x8 enclosed trailer weighing 3000-3500, and a fair amount of miles pulling my open 16’ trailer at 5000-6500 (or more...)
    The heavier weight in the open trailer pulls better than the enclosed with less weight, that drag from the enclosed makes all the difference in feel and mpg. So I imagine a camper pulling more like the enclosed trailer...and feel like at that weight it could be a bit unenjoyable. I strongly recommend some way of monitoring your transmission temperature, most use a scan gauge/ ultragauge...also tow in 4th. Some way of beefing up the rear suspension would be good.
  11. Aug 1, 2019 at 5:48 AM
    #4991
    justrfb
    Rich
    Thank you for all of your replies and suggestions... I have "started conversations" with a few people who have similar camper setups and hope for their answers. I did get the Scan-Gauge for Christmas. Great tool. Thank you all.
    Sincerely,
    Rich
  12. Aug 2, 2019 at 6:13 PM
    #4992
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Nothing major
    Taco wannabe likes this.
  13. Aug 10, 2019 at 4:11 PM
    #4993
    bigbear1612
    bigbear1612 Well-Known Member
    Gary
    2018 Toyota Tacoma TRD 4X4 silver sky metallic
    Ride Rite airbags with onboard compressor, Trail Ridge towing mirrors, 28,000 gwv external transmission cooler, Roll n Lock bed cover.
    I tow a 2019 Keystone Bullet Crossfire 1800RB. max GVWR 4400 lbs. Pulled it over Wolfcreek Pass outside Durango Colorado (15.500 ft) in 2nd gear at 35 mph. I still had plenty of power and never went into 1st gear. I have a scan gauge and the tranny only got to 217 degrees. I have a brake controller WD hitch and Firestone Ride Rites on the Taco. Pulls perfect, I could have gone a bit larger on the TT but I like the way it tows, and 14 mpg average, towing.vDUgonT6QwKEzpzGoOIA8g.jpg
    BassAckwards likes this.
  14. Aug 10, 2019 at 11:27 PM
    #4994
    tow-coma
    tow-coma Well-Known Member
    Third gear towing uphill into a 30mph headwind but 5th and 6th gear on the flats with no wind. Did about 100 miles at 20mpg overall. Was driving between 55 and 60mph
    Holding a yard sale at our house and picked up a bunch of stuff from Mother in laws
    I got a new phone since the last time I towed and couldn't find my set up file in my drive folder. Threw this screen together in a few minutes before I left.
  15. Aug 11, 2019 at 1:56 PM
    #4995
    Sputlegin
    Sputlegin Well-Known Member
    2018 TRD Pro
    I tow a 2014 Keystone Bullet 230BHS with my 2018 short bed auto.
    4,400lbs Dry (As delivered) & round about 6,000lbs with truck accessories, full tank of fuel, camp gear, family & water tanks empty. When we take the trailer we only stay in serviced sites, dump before we leave and keep only a small amount in the fresh water tank for the drive home. If we're outside of serviced areas it's rooftop tent time!
    I use a standard Reese brake controller, WD hitch and sway control. Difficult to see in the photo but the trailer is perfectly level (ground is not) and the rear suspension on the truck is not compressed majorly on stock suspension. A bit of time to set up like this makes a world of difference.
    This tows great through our constantly windy ever changing elevations here in Newfoundland Canada! I keep between 90km/h to 95km/h (55mph - 60mph). I use S4 and shift manually to S3 when needed. I find controlling the shift keeps the transmission from cycling between 3rd & 4th constantly when on a bit of an incline.
    I average about 27L/100Kms (9mpg). Keep in mind we have no flat roads! I'm using more fuel due to the roof rack, oversize LT 10 ply tires and the higher Pro suspension.
    I have a lot of experience towing a variety of cargo with a variety of trucks. I won't say this is the best tow vehicle out there but as long as you plan ahead, stay within your limits and spend some time setting up the hitch, it is quite a comfortable tow!
    Cheers all!
  16. Aug 12, 2019 at 5:19 PM
    #4996
    gotime242
    gotime242 Active Member
    18' Renegade Nomad - pulls it great.
    airsavage and POOLGUY like this.
  17. Aug 20, 2019 at 7:52 PM
    #4997
    Raeburn
    Raeburn Well-Known Member
    2017 ORDCSB
    Tow 5700lbs regularly. No problem, though boats are more aerodynamic than travel trailers so they don't get affected by cross winds or head winds. Usually get around 11 mpg
  18. Aug 23, 2019 at 12:31 AM
    #4998
    GJefe4x4
    GJefe4x4 Member
    South East LA
    2012 Tacoma TRD LB 4x4
    Towed this to the lake last weekend.
  19. Aug 23, 2019 at 12:38 AM
    #4999
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    4643C1A0-2FA9-44BB-9FAA-E6FB0B529FC0.jpg 5BF29981-2478-40C7-A0B0-0455FCE91919.jpg Truck does well with it. Launch is only like a mile from the house
    Coolerman likes this.
  20. Aug 23, 2019 at 11:54 AM
    #5000
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
