Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Sep 21, 2021 at 7:26 AM
    #5541
    SLeeper512
    SLeeper512 Well-Known Member
    Sam
    2021 SR5 DCLB Tacoma white with red topper with tow pkg
    Had to use machined spacers to offset the Tacoma rim offset. A few other places were only willing to put on heavier axle and/or lift, but not the Tacoma rims.
    Was pleasantly surprised that towing mileage is fairly similar. I was expecting a fair hit due to the extra 6”
    brtnstrns likes this.
  2. Sep 23, 2021 at 1:17 PM
    #5542
    jaapsheep
    jaapsheep Well-Known Member
    Janice
    canada
    2023 Blue Crush TRD off road access cab
    went for the blackout package this time
    so made it home safely last week, discovered that with a headwind, the trailer empty has enough wind resistance that I barely touched the brakes and only used 4th downhills as steep as 8%, at highway speeds (90ish km/h). Have yet to tow with a load, which will put me in the range of your trailer weight. Just ordered a weight distribution hitch, as I weighed the tongue weight and had over 400 pounds empty, and with a few sheep in there up to 600 if they moved forward of the axels. Empty it barely moved on the highway, even in some pretty strong crosswinds. I took out all the horse dividers and bulkhead wall, and replaced it with a lighter gate panel which is all I need to keep the sheep from doing laps back there.
  3. Sep 24, 2021 at 9:54 AM
    #5543
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    Spring or torsion axle? I have contemplated swapping to a torsion or adding shocks to my camper. Thing sways back and forth like hell with the springs. Has SOA, that probably doesnt help.
  4. Sep 24, 2021 at 9:14 PM
    #5544
    SLeeper512
    Sam
    Torsion axle with shocks. I used to run 62'ish... with it lifted now up to a whopping 65... but seems more stable when I occasionally have to speed up.
    I do use an Andersen WDH (weight distribution hitch) more for sway and bounce reduction... can't honestly say how much it helps with the sway, but very limited testing running with and without on moderately rough roads seems to help a moderate amount with the bounce.
    SOA???
  5. Sep 27, 2021 at 7:34 AM
    #5545
    Zacowacko
    Zack
    SW, OK
    SOA = Spring over Axle.
    I have the WDH with chains, but it has the shitty brake type sway control, that your supposed to bolt or weld to the frame of the trailer. Just havent dropped the money for one of the bar type WDH's, been too cheap. Dont really get any sway, just the trailer rocking side to side. Figure shocks could help and probably a proper WDH. Really want to go all torsion axle, but wife says i need to stop spending $'s :bananadead:
    SLeeper512[QUOTED] likes this.
  6. Sep 27, 2021 at 10:00 AM
    #5546
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Play the “safety” card. Usually trumps dollars when getting pushback. :D
    Bratworx and SLeeper512 like this.
  7. Oct 2, 2021 at 8:29 AM
    #5547
    jaapsheep
    Janice
    canada
    got a WDH for the horse trailer but discovered it's way too low. This is a Curt. Have the Tru-track Curt on order, should solve the clearance problem.DSCF3764.jpg
    4x4Taco2012 likes this.
  8. Oct 6, 2021 at 3:00 PM
    #5548
    jayrome
    jayrome Well-Known Member
    2020 Tacoma TRD Off Road - DCLB
    King 2.5 Front Ext Travel Coilovers with Adjusters and SPC UCAs King 2.5 Rear Ext Travel with Adjusters 17" Method NV Wheels BF Goodrich K02 275/70/17 RCI Steel 3 Pc. Skids and Diff Cover All Pro Rock Sliders Victory Strike Front Winch Bumper with Warn Evo 10K Twin ARB Compressor with Rago Mount Wifey Air System
    22ft Jayco Jayflight SLX
    4400lbs dry
    Did our second 3 week trip this summer, this time towing the trailer, family of four, 2 kayaks, and 2 e-bikes through the Eastern Sierras.
    Started at Whitney Portal campground in order to summit Mt. Whitney, before heading through 4 more campgrounds working our way up to Lake Tahoe and back down to Rock Creek Lake
  9. Oct 6, 2021 at 3:00 PM
    #5549
    jayrome
  10. Oct 6, 2021 at 3:01 PM
    #5550
    jayrome
  11. Oct 6, 2021 at 3:05 PM
    #5551
    jayrome
    Summer of 2020 we did 3500 miles (3 weeks) with the Jayco from San Diego, through Zion, Yellowstone, Couer d'Alene, Washington, Oregon and the Eastern Sierras
    Still had 33s back then, but didn't yet have the Kings. I had a Falcon Sport Tow Haul Suspension kit and I still have my stock rims/tires, so I put those on for the trip
    4x4Taco2012, POOLGUY and Bratworx like this.
  12. Oct 7, 2021 at 5:52 AM
    #5552
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    Wow, that's quite a trip! Beautiful pics. How did the truck handle that load in that terrain?
  13. Oct 9, 2021 at 9:44 AM
    #5553
    CaptQuinn
    CaptQuinn Well-Known Member
    Quinn
    Alaska to Oregon
    '13 Sprucie Sport
    Dakar EL095R :Front Coils-2885 :Shocks-90000
    This 2019 Keystone Passport just followed me home. The truck is still squatting a bit (as expected) even after recently adding the OME EL095R leaf packs. Even though we're ~800 lbs under the GCVWR (not positive of accurate tongue weight at this point), I feel like this is my comfort limit. Just finished a 750 mile RT up into NE Washington state and she did it but it was about all she could do! Still, stoked to have a TT...Taco with TT.jpg
  14. Oct 9, 2021 at 6:48 PM
    #5554
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    what model TT?
  15. Oct 9, 2021 at 11:39 PM
    #5555
    CaptQuinn
    Quinn
    Alaska to Oregon
    '13 Sprucie Sport
    It's the Ultra-lite 195RB. I believe it's 21+ feet LOA and dry weight is ~3400+ lbs dry weight. I'm not home at the moment so I don't have all the real numbers...
  16. Oct 10, 2021 at 9:09 AM
    #5556
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    5 x 10 suretrac all aluminum trailer
    CaptQuinn likes this.
  17. Oct 19, 2021 at 8:31 AM
    #5557
    SoftwareNinja
    SoftwareNinja "I just call it car-camping"
    Phillip
    Boston, MA
    2005 Tacoma Access Cab TRD
    Avid Offroad Front Bar, Avid Offroad Tailgate Reinforcement, Cali Raised bed stiffeners, Softopper, Baja Designs LP9's, Redarc brake controller, Stoptech Stainless Brake Lines, Joying 9" Head Unit, BROG Seat panels, Builtright Industries Bed Rack, Power Tank, Fox 2.0 Coilovers, RXT Leaf Springs, Archive Garage.
    Posted in the "other" thread, but not sure who watches what. This is what we tow/camp in/lived out of for 7 weeks this year while our offices were closed:
  18. Oct 22, 2021 at 6:54 AM
    #5558
    Zacowacko
    Zack
    SW, OK
    Curious too how it did with that load towing up those inclines.
  19. Oct 22, 2021 at 9:28 PM
    #5559
    ILICKTACOS90
    ILICKTACOS90 Well-Known Member
    The Reverse Engineer
    Middle of nowhere, Montana!
    2019 TRD 6spd; 1984 Hilux; 2002 Cummins
    Custom, only one ever designed and built interiors, heavily welded frame, all sharp metal turned bed rack and a roof top I made for $75. Power pedal, injen intake system, cat delete, summit racing brake proportioning valve controlled on the fly, slightly adjusted or perhaps unrecognizable ECM, built in under bed storage, high clearance rear built with 1/4" on a 6011 1/8" rod at 120 amps, 360 degrees of led light, a PA and CB, on board air, on board propane (to cook food), on board fridge made from an old red bull fridge found on some guys man cave built into the storage cubby under the back seat, imported tranny and clutch from a good friend over in Europe to replace this aisin junk we get, combined 32 gallons fuel capacity, 18 5 gallons of water storage, built in gun locker under RTT, and all it cost was to hear the wife ramble on about upset neighbors at 2 in the morning every night since I bought that damn truck..
    Old 2 horse with 2 young horses. Pulls good but takes a while to get out of 4th gear.
  20. Oct 23, 2021 at 8:50 AM
    #5560
    jayrome
    It's not great, but the taco has taken that camper all over the West.
    I'm scheduled to re-gear to 5.29s in early November, which should help out quite a bit.
    The worst experience I've had was getting it to where you are seeing it in that photo, at Whitney Portal Campground. Was fine going up the slow grade from Lone Pine toward where the road makes a right up to the first (and only switchback) to climb to 8500 feet where the campground and trailhead for Whitney are located.
    Right as we approached that bend we saw a sign that said "trailers not recommended" and a turn off into some sort of camp area. My wife exclaimed "trailers aren't recommended" and "is that the campground?". I knew it wasn't, but it caused me to let up on the gas just enough to lose our momentum and as the road bent to the right to begin the climb, the taco slowed and I had to keep downshifting until I was in 1st and pretty quickly we were doing like maybe 2mph. I was waiting for the Tacoma to gasp and just quit. There was nothing there.
    Tried to act like everything was fine for my wife's benefit, but was thinking to myself "where the hell are we going to camp tonight?". We had reservations at the portal campground and I was scheduled to climb Whitney with a few buddies in about 24 hours!
    I crept along, knowing that the further I went, the longer I would have to back this thing up to get down. I zig-zagged slightly, hoping to get any advantage at all. For just a moment the grade lessened slightly and I took my shot to rev 1st gear up to 4500-5000 rpms and kept it there the entire way up to the portal campground. The floor boards were hot by the time we got there.
    Almost burned up the trailer brakes getting down too :E
    Wild Crow, AMMO461 and SLeeper512 like this.
