Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Mar 24, 2012 at 1:50 PM
    #1081
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    No wheeling for the Runner as of now. The engine had over 200,000 miles on it and the timing chain decided to break on the freeway. This was me taking it in to get a completely rebuilt engine. She runs great now!! :)
    The Uhaul trailer worked great actually! It was just a bitch trying to get in on the trailer with only 1 person, 1 truck, and facing up a hill
  2. Mar 24, 2012 at 1:55 PM
    #1082
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    I'm modifying a trailer to be my dedicated wheeler trailer right now. I've done some comparisons of the Uhaul trailers and I think I'm going to be stealing some ideas from them.
  3. Mar 24, 2012 at 10:26 PM
    #1083
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    how is a 2 axle easier to back up?
    Its the tire resistance and with a 2 axle trailer its usually longer. so when you start backing up with 2 axle its easier to see and quicker to correct, and with 4 tires the trailer need more of a "push" for the truck to get out of line, and single axle trailer sort of have a mind of their own when it comes to backing up, and while its not just a steady hand, its trickier with a single in gravel, or sand, hell packing up in a parking lot and your doing fine and one tire runs over rock and that can cause it so swing out.
  4. Mar 25, 2012 at 9:26 PM
    #1084
    Woodstocktaco
    Woodstocktaco Well-Known Member
    Woodstock, GA
    09 SR5 ORDC 4X4
    3" OME lift, 885 coils, Dakar rears, diff drop
    I've found over the years that dual axle trailers are just less "twitchy" when backing. As you said, single axle trailers seem to get off line easier & want to jack knife - while a dual axle seems to hold the line better.
    I wasn't talking physics - just my experience, maybe it's just me that feels that way?:confused:
  5. Mar 25, 2012 at 9:52 PM
    #1085
    mortifer
    mortifer .
    San Jose, CA
    06 X-Runner
    I'm new here and eager to join in on the fun....
    Here's about all I ever tow, a 6x10 trailer with 3 dirtbikes.
    Trailers dry weight 1300lbs + 1000lbs of 3 bikes and supplies.
    If needed, I'll add a 4th and 5th inside the bed to get as many people to the park as I can. :)
    With the big brake kit and V6, it's no problem.
  6. Mar 26, 2012 at 8:57 AM
    #1086
    07SpeedwaySport
    07SpeedwaySport Senior MoFo'ing Member
    Fairfax, VA
    06 DCSB TRD OR--now silver
    tint.
    Tongue looks low? Maybe just the camera angle?
    I would try for better weight distrobution. Maybe load it backwards next time? Or don't drive as far forward as you did with the 4runner?
  7. Mar 26, 2012 at 9:34 AM
    #1087
    tx_shooter
    Moving the 4Runner about 1.5' back would of made a big difference I bet. Also, if the Tacoma doesn't have the TSB leafs then it is going to bottom out pretty easy also. That is why I got the leafs and Firestone bags for my truck.
  8. Mar 26, 2012 at 9:43 AM
    #1088
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Yeah I've never towed anything before and don't know much about it so the 4'' drop ball is what I was recommended by a local towing shop for that Uhaul trailer. He said I would need cause of my truck...??
    You can't really move the runner back any because of the design of the trailer. The way it holds the cars on are straps in the front that force you to pull it all the way forward.
  9. Mar 26, 2012 at 10:04 AM
    #1089
    tx_shooter
    The drop hitch is probably fine; the issue was leafs. Since your truck is 4x4 you probably don't want the towing leafs.
  10. Mar 26, 2012 at 11:36 AM
    #1090
    07SpeedwaySport
    Fairfax, VA
    tint.
    I am going to say that the lower the drop, the more weight you have on the tongue, which means more weight on the springs. (Think leverage) but this might play as big a part as I imagine because you have two axles, but it should still play a part.
    4 inches seems excessive. There is a calculation that can/should be done, I just don't know it. And loading the 4runner backwards puts weight of the motor on the rear of the trailer, away from the tongue.
    Edit- found my old thread:
    http://www.tacomaworld.com/forum/towing/133399-do-i-drop-my-ball-how-far.html
    and more precisely, this from a member: http://www.etrailer.com/faq-ballmount.aspx
  11. Mar 27, 2012 at 1:51 PM
    #1091
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    my uncle used to tell me that with a 2 axle trailer, when loaded right the equilazers should be about leval.
  12. Mar 28, 2012 at 8:57 AM
    #1092
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    First pic is towing my 12 foot trailer with 2 Grizzly 600 ATV's. Second pic is 3 yards of bark in a 1900 pound dump trailer. Nothing too serious, about what this truck is meant to do.
  13. Mar 28, 2012 at 11:39 AM
    #1093
    07SpeedwaySport
    Fairfax, VA
    tint.
    Crap like this:
  14. Apr 1, 2012 at 10:22 PM
    #1094
    whitetacoma1
    whitetacoma1 White Tacoma 4X4
    Dan
    Alberta
    2009 and 1997 tacoma 4x4
    3" toytec Lift front OME 885s and AAL in the back
    where did you get your mirrors?
  15. Apr 2, 2012 at 7:00 AM
    #1095
    kd8bao
    kd8bao Well-Known Member
    Henry
    Cleveland
    2000 Excursion 7.3L - Ex '11 Taco DCSB
  16. Apr 2, 2012 at 7:28 AM
    #1096
    Blade-Runner
    Blade-Runner Well-Known Member
    Kevin
    Las Vegas, NV
    08 TRD Sport Prerunner
    Performance: - TRD Supercharger - URD 2.85 Pulley - APR X-1 - Doug Thorley long tube headers - Magnaflow CAT back - Toytec 3" lift Audio: - Damplifier Pro, doors (x2), rear wall, floor, kick panel & firewall - JL 13TW5 - Polk Audio db6501 - Polk Audio db5251 - Alpine PDX 1.600 & 4.100 - Pioneer AVH-P4200DVD
    ^^^^ Bad link
  17. Apr 2, 2012 at 1:06 PM
    #1097
    kd8bao
    Henry
    Cleveland
  18. Apr 2, 2012 at 5:24 PM
    #1098
    psychotron
    psychotron Member
    Ron
    Grande Prairie Alberta
    07 tacoma TRD offroad
    6" pro comp lift, 33/12.5/17 tires
    I packed up most of my belongings (sold off the bigger stuff) into a 10' x 6' trailer and towed it 4000km across Canada. Not sure what the total weight ended up being but the trailer itself is 1100lbs and there was a big difference once the trailer was loaded. Still pulled nice though. For the small fortune I spent on gas I could have bought new rims and tires that I desperately want. :(
  19. Apr 6, 2012 at 3:10 AM
    #1099
    BBY2KS2K
    BBY2KS2K Jon Stewart / Stephen Colbert 2016
    Lake Stevens, WA
    2005 PreRunner DC
    16x7.5 TRD Bronze "beadlock" wheels without the beadlocks w/ 265 70 16 Bridgestone Revo II tires (non-winter) 16x8 KMC Enduro w/ 265 70 16 Bridgestone Blizzak DMV-1 tires (winter) McGard Spline Drive lugs and locks, Satoshi Grill, BLHM, blacked out badges, Aries side steps, Smittybilt light bar with PIAA 540 plasma ion fogs, Aero-Turbine muffler
    Just picked up a 1973 Apache Ramada yesterday. :)
  20. Apr 11, 2012 at 5:44 PM
    #1100
    BrewDawg
    BrewDawg Active Member
    costal and rocky mountains Canada
    silver streak access
    Nice....classic Apache !!! ,Dude She's a Beast! Flip the axel and get bigger wheels or make a skid plate cuz if your gonna be taken her off the grid the back of her is gonna take a shit kickn!
