Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Apr 12, 2012 at 8:03 AM
    #1101
    BBY2KS2K
    BBY2KS2K Jon Stewart / Stephen Colbert 2016
    Lake Stevens, WA
    2005 PreRunner DC
    16x7.5 TRD Bronze "beadlock" wheels without the beadlocks w/ 265 70 16 Bridgestone Revo II tires (non-winter) 16x8 KMC Enduro w/ 265 70 16 Bridgestone Blizzak DMV-1 tires (winter) McGard Spline Drive lugs and locks, Satoshi Grill, BLHM, blacked out badges, Aries side steps, Smittybilt light bar with PIAA 540 plasma ion fogs, Aero-Turbine muffler
    BrewDawg, I learned about that within the first 15 minutes of ownership. On the way home, I stopped at the licensing place to do the title transfer. The entrance to the parking lot is a little steep and I just barely dragged the rear gear box on the asphalt. Scared the shit out of some landscaping guy working close by. :D
  2. Apr 12, 2012 at 7:13 PM
    #1102
    moblarkus
    moblarkus Well-Known Member
    Mark
    British Columbia, Canada
    '06 Black Sand Pearl TRD Off-Road
    Satoshi grille, All-pro bumper, Allpro UCA's, Walker Evans coilovers, 10" Lightforce Blitz, PIAA 510's,Magnaflow cat-back, K&N CAI, Revtec rear blocks. TSB leafs, Firestone Ride-Rite air springs, Hopkins Agility brake controller.
    [​IMG][​IMG]
    Towed my 5000 lb travel trailer almost a thousand kms, 600 miles over BC mountain roads. 4th all the way, couldn't tell you the milage but those are 33's.
    Like a boss!
  3. Apr 13, 2012 at 8:54 PM
    #1103
    BrewDawg
    BrewDawg Active Member
    costal and rocky mountains Canada
    silver streak access
    Hey Boss,,, nice work!! Braggin rights no-dout! Thats a Pimp RIG! :canada:
  4. Apr 15, 2012 at 11:12 AM
    #1104
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
  5. Apr 15, 2012 at 11:26 AM
    #1105
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    I'm curious what speed/rpm you run when towing? When I'm towing my 4Runner on a trailer I tend to keep it around 60~65 mph and 2500 rpm. I'm still on stock size tires though.
    That is just bad ass! Nice trailer.
  6. Apr 15, 2012 at 3:55 PM
    #1106
    moblarkus
    Mark
    I was running around 2500 on flats around 100 KPH, a little over 60 MPH, without pushing too hard in 4th with the AT. On long hills 3000-3300 in 3rd, or 2nd on a good grade holding anywhere from 60-80 KPH. 1.61 kms to a mile.
  7. Apr 15, 2012 at 4:01 PM
    #1107
    moblarkus
    Mark
    Nice trailer!
  8. Apr 15, 2012 at 6:26 PM
    #1108
    tx_shooter
    Sounds about like what I'm doing when towing. Good to hear I'm not pushing any it any harder than the next guy. :D
  9. Apr 15, 2012 at 6:33 PM
    #1109
    moblarkus
    Mark
    Truck was built to work. Work it. As a side note, the temp needle never once climbed higher, and it runs better, musta burned all the crap out of it!
  10. Apr 15, 2012 at 6:46 PM
    #1110
    tx_shooter
    All the towing I have done before was with a 3/4 ton V8; so this is my first "little truck" to work with. So far I'm pretty happy with the way it handles working.
  11. Apr 15, 2012 at 8:34 PM
    #1111
    kd8bao
    kd8bao Well-Known Member
    Henry
    Cleveland
    2000 Excursion 7.3L - Ex '11 Taco DCSB
    Thanks. Taking it out this coming weekend.
  12. Apr 16, 2012 at 10:56 AM
    #1112
    wormfood
    wormfood Well-Known Member
    David
    Missouri
    2011 Tacoma TRD
    TRD Super Charger, UWS, All Pro expedition leaf spring pac, Icon stage 4 suspension, B.A.M.F LCA Skid plates, TC weld-on upper coil bucket tower gussets, TC weld-on spindle gussets with sway bar mounts. RTT, Thule Roof Rack, Thule, Leitner Active Cargo System, Warn Zeon 10 Winch, All Pro Front Bumper, All Pro Apex Sliders, Nilight - 60005C-A 20Inch 126W Spot Flood Combo Led Light Bar.
  13. Apr 16, 2012 at 11:31 AM
    #1113
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
  14. Apr 16, 2012 at 11:39 AM
    #1114
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    last thing i towed was my brother's 96' tacoma.....
    think i can tow a small trailer with 2 horses about 900-1000lbs?
  15. Apr 16, 2012 at 11:53 AM
    #1115
    tx_shooter
    With horses/livestock it is the shifting weigjt that gets people into trouble.
  16. Apr 16, 2012 at 12:41 PM
    #1116
    AsianAnts
    AnT
    oooo .... also, my truck is a 4x2...
  17. Apr 16, 2012 at 5:07 PM
    #1117
    tx_shooter
    That won't make any difference when towing. The big thing will be how well it handles the trailer weight. I have air bags that help my truck support the weight of my trailer/4Runner so it handles pretty good. If you have the stock 3 pack leafs then you might want to reconsider or pick a slower/less packed route.
    I hauled horses and cattle a lot in high school with my 3/4 ton and the shifting around always got my attention. It makes it like you are pulling a load in a good crosswind; but without the predictability.
  18. Apr 16, 2012 at 8:51 PM
    #1118
    AsianAnts
    AnT
    i have the rear TSB done.. but that will prolly only help just a tad bit?
  19. Apr 17, 2012 at 4:13 AM
    #1119
    tx_shooter
    It is a lot better than the stock leafs. Just take it easy on the acceleration, double your braking distance, and slow down for turns; you have to remember there are horses back there trying to stand up. If they trailer well it will be a lot easier for you; if they have never trailered before it can be interesting.
  20. Apr 23, 2012 at 11:20 AM
    #1120
    randyp5763
    randyp5763 Member
    Missouri
    11 Tacoma Off Road
    Wow, what does all that weigh? I'm looking at buying a Yamaha 242 boat and it comes under the max with room to spare for fuel, the kids, toys etc... How well does it pull, stop and all that other fun stuff? Any recomendations as far as towing a boat before I make the jump in doing so? So many other questions, I'll just stop now. Thanks!
