Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Sep 20, 2012 at 8:58 AM
    #1281
    tractng
    tractng Well-Known Member
    Very nice. What is the spec on the trailer?
  2. Sep 20, 2012 at 1:38 PM
    #1282
    tacochips
    tacochips Member
  3. Sep 20, 2012 at 5:01 PM
    #1283
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Did you mod something on the rear susp for towing that monster?
  4. Sep 21, 2012 at 7:46 AM
    #1284
    hgfontana
    hgfontana Well-Known Member
    Hernan
    Resda, Ca
    12 Tundra CrewCab 4x4
    It is a Carson Toy Hauler, FL162 Link. I add to this trailer a roof AC and a Honda 3000is generator in the tongue.
    I have done the TSB in the rear suspension and Firestone Air Bags.
  5. Sep 21, 2012 at 12:44 PM
    #1285
    kd8bao
    kd8bao Well-Known Member
    Henry
    Cleveland
    2000 Excursion 7.3L - Ex '11 Taco DCSB
    Are the airbags worth it? I am towing a 6K trailer with WD and dual cam sway controller. When set up I am level all the way down. I get some good rear bounce on the back roads. Just wondering since we are about the same tongue weight. Also, I have the same brake controller and I had an internal error code the one day. Called Cequent and they said the board may have gone bad so they sent me a new one no questions asked. So something to keep in mind. ImageUploadedByTapatalk1348256690.748220.jpg
  6. Sep 21, 2012 at 4:58 PM
    #1286
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    I'll vouch for the Firestones. I tow my '87 4Runner quite often and the air bags really helped stop that bouncing bs. I have the TSB leafs also; but the air bags made the biggest difference. As my buddy put it one day; "It tows like a big truck" now with the bags.
  7. Sep 21, 2012 at 7:54 PM
    #1287
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
  8. Sep 21, 2012 at 10:35 PM
    #1288
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Have you had the TSB done? Surprised its not squatting more. Nice looking trailer, by the way!
  9. Sep 22, 2012 at 4:08 AM
    #1289
    J Gibson
    J Gibson Well-Known Member
    J
    Knoxville, TN
    '12 DCSB,4wd,TRD Sport, tow pkg, MGM
    katzkin leather, toyota step bars, pro grill, advent overhead DVD player, cargo extender, bed mat, husky liners, impulse digital brake controller, avs bugflector, tinted windows, Firestone ride-rite air bags, ARE camper top with tool doors, ScangaugeII, ProEFX tow mirrors, ImMrYo rearview mirror lift bracket, Salex glove box and console organizers, 2020 Tacoma Pro styled wheels, 265/70 r17 Michelin MS2 tires, LED map lights, drivers seat extended and raised, ram ball tech deck installed, blacked out badges, tinted taillights, upgraded climate control knobs, ultimate headlight upgrade with Osram superbrights and wiring harness along wit OEM pro headlight housings.
    I would buy them again. They aren't necessary, but they sure make it more comfortable. Plus sometimes I carry more stuff in my truck bed than others. Like some times I need my 4300watt generator for dry camping at racetracks etc. but not if I am going to a campground, so I can adjust the air pressure in the bags based on my load.
  10. Sep 22, 2012 at 8:46 AM
    #1290
    05TacoDblCab
    05TacoDblCab Member
    Who can guess what's on the trailer?
  11. Sep 22, 2012 at 8:49 AM
    #1291
    tx_shooter
    Looks like a 1st Gen taco.
  12. Sep 22, 2012 at 10:54 AM
    #1292
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Absolutely, get the air bags, they help a lot.
  13. Sep 22, 2012 at 10:59 AM
    #1293
    ajohnson
    Andy
    Charlotte, NC
    1st gen Pickup
  14. Sep 22, 2012 at 1:09 PM
    #1294
    05TacoDblCab
    05TacoDblCab Member
    Bags are almost a necessity if you got stock springs (even with aal) and tow anything with any real weight. I put 30psi in each bag when haul anything over 3k lbs. 20psi for anything else and 15psi empty. It firms everything up and keeps everything sitting level. I would buy them over again.
    And you guessed it man its a 1st gen pickup.
  15. Sep 22, 2012 at 1:20 PM
    #1295
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    I want bags so bad and the firestone kit is so affordable but I want an onboard compressor and tank with an easy access control either in cab or outside. And that makes it so much more expensive.
  16. Sep 22, 2012 at 6:05 PM
    #1296
    05TacoDblCab
    05TacoDblCab Member
    Yeah I don't have the tanks or gauges on mine. I use one of those battery jumpers that has an air pump on it. Doesn't take as much time as you would think to do it manually.
  17. Sep 22, 2012 at 7:11 PM
    #1297
    A_Ninja_Racer
    Tampa, FL
    What about maintenance on the bags? Is there anything you can do to help the longevity of the bags?
  18. Sep 22, 2012 at 7:23 PM
    #1298
    05TacoDblCab
    05TacoDblCab Member
    I just check them periodically because the lines are those self locking connectors that you just push the lines into the fittings which tend to leak over time. But besides that I keep the bags clean from grit and debris so the rubber doesn't wear grooves or what have you. Besides that I havnt heard about doing anything else and the manuel I don't think said anything really.
  19. Sep 22, 2012 at 7:26 PM
    #1299
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    wrong look at the mirrors, not taco. also front fender dose not look like 1st gen taco.
    i’m going to go with this.
  20. Sep 23, 2012 at 3:51 AM
    #1300
    Dogfish
    Dogfish Well-Known Member
    NJ
    2012 Taco sport
    Just picked it up yesterday. The Tacoma did great, except for the gas mileage lol. I took a quick pic at rest stop on the turn pike.
