Show us what you tow.
Discussion in 'Towing' started by BBQ BOY, Feb 17, 2009.
  1. Jun 10, 2009 at 8:37 AM
    #141
    mvega1969
    mvega1969 Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    Hey your setup looks like mine, I tow something different but I never before see I truck so much like mine, of course GREAT setup!!!.
    My setup:
    What I tow...
    kydreamers and Tarus 9mm like this.
  2. Jun 10, 2009 at 11:55 AM
    #142
    steve r
    steve r Well-Known Member
    buford ga
    06 tacoma
    Painted wheels to match truck
  3. Jun 10, 2009 at 3:02 PM
    #143
    jneedham
    jneedham DARK NIGHT
    Texas
    06 tacoma 4x4
    6" procomp on 35" toyo M/T and 20" XD spy's
    i have an 06 tacoma with 6" lift and 35's and i pull a 21 ft center console boat that weighs around 3500 Ibs would that be an issue?
  4. Jun 10, 2009 at 3:07 PM
    #144
    jneedham
    jneedham DARK NIGHT
    Texas
    06 tacoma 4x4
    Nice!!!
  5. Jun 10, 2009 at 3:08 PM
    #145
    jneedham
    jneedham DARK NIGHT
    Texas
    06 tacoma 4x4
    do you think that 3500 Ibs might be to heavy for my truck?
  6. Jun 10, 2009 at 6:20 PM
    #146
    commtrd
    commtrd commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    I very much suspect that towing a 3500# boat with a truck running 35" tires will be an issue. At best it will get horrible gas mileage and at worst it will not do the truck any good. A truck set up with oversize tires will either look cool or be used for offroad, but if you want to tow heavy with it the truck will perform much better set up differently. A 6" lift and 35" tires will not work very well for towing other than light loads. Tacomas are light-duty trucks, not meant for loads a full-size truck would be suited for, especially set up in a way which puts the drivetrain at a disadvantage.
  7. Jun 10, 2009 at 7:07 PM
    #147
    jneedham
    jneedham DARK NIGHT
    Texas
    06 tacoma 4x4
    should I downgrade to a 33 tire or get it regeared?
  8. Jun 10, 2009 at 8:10 PM
    #148
    commtrd
    commtrd commtrd
    Corpus Christi TX
    How does the truck pull your boat now? If you're OK with it the way it is, then fine. Probably it is not pulling the boat near as well as it could with the proper size tires on it or re-geared quite a bit lower. Trucks set up for serious offroading are typically not going to work near as well as a truck set up for towing. And vice-versa. But a truck with a mild lift and [resaonable] tires will pull OK as long as you know it is not a full-size truck and try to drive it that way. My truck is a 4wd with 265/70/R17 tires and a 6-spd manual (geared lower than the automatics) and a V6. It pulls my boat (around 2100 pounds with full gas tank etc.) very well except it still struggles up steep grades and I have to get in fourth gear to get up those inclines. It may be rated for 5600 pounds but I feel like if I tried to tow those kind of loads with this truck it would tear it up. I did not get this truck to tow heavy so it's OK. The manual trans truck does seem to tow my boat a lot better than the '07 with auto did. That truck was not a 4wd but was a long-bed DC pre-runner. It gets better mileage towing than the auto did...unfortunately the auto got a lot better mileage unloaded than my new one does.
  9. Jun 10, 2009 at 8:28 PM
    #149
    commtrd
    commtrd commtrd
    Corpus Christi TX
  10. Jun 10, 2009 at 8:32 PM
    #150
    commtrd
    commtrd commtrd
    Corpus Christi TX
    Looking at what some guys here tow with their trucks, my boat does not seem to be that much of a load!
  11. Jun 11, 2009 at 6:18 AM
    #151
    dougmays
    dougmays Well-Known Member
    Doug
    Gainesville, FL
    2007 SR5 Tacoma 4WD/Tow Pkg Black
    Westin Bull Bar, Firestone Destination AT 255/70/16
    i've had no problems towing "heavier" loads. just maintain a safe and gas economical speed and you should be ok. also be aware of your gears when your towing. if your truck is revving high or searching for gears...downshift. never tow in D.
  12. Jun 11, 2009 at 1:12 PM
    #152
    jneedham
    jneedham DARK NIGHT
    Texas
    06 tacoma 4x4
    Ok yea i figured id just pull it in 3rd or 4th and it would be ok... Nice boat!
  13. Jun 11, 2009 at 6:17 PM
    #153
    dougmays
    Doug
    Gainesville, FL
  14. Jun 12, 2009 at 8:29 PM
    #154
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    Not towing more like hauling. Who said a mini can't haul?
    50lbs each......
    Pavlik1988 likes this.
  15. Jun 14, 2009 at 10:13 AM
    #155
    shrimperman
    shrimperman Member
    Heres what i tow ,,with no problems..I know it is back there but im comfortable towing it.
  16. Jun 15, 2009 at 8:16 AM
    #156
    mxranger
    mxranger New Member
    Here is our rig, bike,wash water,power washer,trailer ready for weekend and Tacoma does just fine, good hitch and brake controller, no sway control and not needed.
    12mpg (don't care about gas mileage, nice to be not sleeping on ground or being at dusty track without a shower.............)
    (first time posting pic..............:confused:)
  17. Jun 22, 2009 at 3:46 PM
    #157
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    Bought this recently - planning on taking the engine (1.6 diesel) out and putting it in a Samurai. Needless to say the Taco pulled it fine.
  18. Jun 23, 2009 at 6:25 PM
    #158
    TodaGuy
    TodaGuy Well-Known Member
    Oregon
    Almost Murdered 09 Taco
    Revtek 3" spacer in front 1" block w/ 2" AAL in rear. Blacked out grill, debadged (almost all done), Magnaflow muffler, black Konig Countersteer Off Road rims, 285/75/16 Toyo Open Country M/Ts.
    Just pulled a Mastercraft x15 today. Boat prob weighs close to if not over the max limit of the tacos capacity.
    PICS:)
    Pentangler likes this.
  19. Jun 23, 2009 at 8:24 PM
    #159
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    nice. Whose boat?
  20. Jun 23, 2009 at 8:29 PM
    #160
    TodaGuy
    Oregon
    GF's dads boat. We just de-winterized it and wanted to make sure everything was good to go for this weekends camping trip to the cove.
