SHOW US WHAT'S ON YOUR ROOF RACK
Discussion in '2nd Gen. Tacomas (2005-2015)' started by julian parzival, Jul 17, 2012.
  1. Sep 11, 2012 at 12:40 AM
    #61
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    sub. i’m wanting one kinda like XMADCOWX. than build custom cross bars that i can take on and off, that will have snowboard rack on it. (they will have round tubing cut in half and that will wrap around the side tubes, and held held by 4 bolts on each side. (kinda like the stock FJ rack’s cross bars are) also for a led light bar.
  2. Dec 11, 2012 at 5:34 PM
    #62
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    SWeeeeT Rides! all three of them!
  3. Jan 12, 2017 at 8:03 PM
    #63
    Getoutthere
    Getoutthere Well-Known Member
    Seth
    Grand Haven Michigan
    2007 white Tacoma trd offroad
    Total chaos upper control arms. Stealth custom wheels. KO2’s
    :yes:
