Show us your BOAT!!!
Discussion in 'Boating & Fishing' started by chris4x4, Jun 29, 2008.
  1. Jul 27, 2018 at 11:02 AM
    #1181
    GSPdog7
    GSPdog7 Well-Known Member
    Allen
    Central VA
    2015 Silver Sky Metallic TRD Off-road
    Nice jet boat! What river is that?
  2. Aug 14, 2018 at 3:07 PM
    #1182
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    JL8Jeff said:
    I put the fishing boat in the water for the season today.
    This is on the Delaware River in the Washington's Crossing area. The river is probably at least 4' higher than this right now thanks to all the rain we keep getting. The boat is a Lowe 1652 jet tunnel hull with a Merc 60/45 jet outboard.
    Intrepid, Kinsail48 and ecoterragaia like this.
  3. Aug 14, 2018 at 4:44 PM
    #1183
    GSPdog7
    Allen
    Central VA
    Ah nice man! That river must be rolling like ours here in VA! I’ve got a 1754 grizzly with a tiller 60/40. Need to flip her and put in a tunnel and console up front like yours! Keep it skinny!
  4. Aug 14, 2018 at 5:50 PM
    #1184
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    Yeah, the river is at least 7' above normal for this time of the year. The console was actually mounted farther back when I got the boat. The previous owner was running a 40 hp long shaft prop motor and didn't even realize it was a jet tunnel! I sold that motor for almost the same money I paid for the 60/45 short shaft jet motor. I moved the console forward and put the battery under the console to keep the weight forward. Here's a picture of the river from back in April when we had a lot of rain. It's almost the same now with lots of debris floating down.
    Kinsail48 likes this.
  5. Aug 22, 2018 at 10:59 AM
    #1185
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    a friend has a GM 5.0 inboard engine on his boat that wont idle. It does fine at 1500+RPM just wont idle. Im thinking either a idle jet/orifice is plugged or possibly fuel pump? But I'd think fuel pump wouldnt work at any speed? I did notice there wasnt any fuel that come out of the line when I disconnected the carb. Is that normal or should there have been a little trickle come out? Its a carbuerated NON fuel injected.
  6. Aug 22, 2018 at 11:15 AM
    #1186
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Strange. The not running at an idle but at higher RPM's leads me to think that its a bad idle circuit and that the idle orifices are plugged. But no fuel in the line is a mystery, because that should mean it wouldn't run at higher rpms (when it needs more fuel) instead.
    The first thing I'd normally do to try and correct the idle issue would be to pull the carb, tear it down, and give it a thorough cleaning (blowing all of the orifices out, the needles, all of it). But the lack of fuel in the line is interesting. Is there no fuel in it immediately after the boat has been running, or if it's been shut down for a while? Because if it's empty when the motor's cold that might just mean that the line is draining back down around the pump (not uncommon when they get a little wear on them). But if it's empty immediately after a shutdown then that's a bigger problem.
    wilcam47[QUOTED] likes this.
  7. Aug 22, 2018 at 7:15 PM
    #1187
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    What carb does he have on that motor? It could be a vacuum leak somewhere that is throwing off the mixture at idle.
  8. Aug 23, 2018 at 8:32 PM
    #1188
    wilcam47
    Will
    Bourbon state
    I loosened the line pretty soon after a shutdown, to check the filter right before going into the carb. I thought it was a little odd nothing dripped out. I did get a rebuild kit for it as in typical fashion when you take it apart usually mess up a gasket. Im going to tear it down and clean everything and put the rebuild kit in. Im thinking its a combo of things, dirty carb and maybe a weak fuel pump. I didnt get to look at the fuel pump but its showing an electrical type external fuel pump so it looks easy to change.
    Im thinking clogged idle jet also. I looked for anything like a a vacuum hose but theres really nothing on this carb. The pcv valve goes somewhere else and soon as you take that off it does kill the engine. I'll have to get more in depth into it next week. Thanks for the help.
  9. Aug 24, 2018 at 4:23 AM
    #1189
    Noelie84
    Noel
    Wales, Maine
    Then it sounds like the pump is about done. It's probably got enough internal wear that it's not pumping enough fuel at an idle. Most inboard boat motors are set up to idle at around 600rpm or so, and if the pump's only pumping at 25% efficiency or whatever then the engine just isn't getting enough fuel until you increase the number of cycles the pump runs in a minute.
  10. Aug 24, 2018 at 5:44 AM
    #1190
    Fishnwiz
    Fishnwiz Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    Waiting out the rain
  11. Aug 24, 2018 at 5:53 AM
    #1191
    Noelie84
    Noel
    Wales, Maine
    Lamesauce. Nothing like a downpour while you're trying to boat.
  12. Aug 24, 2018 at 5:20 PM
    #1192
    wilcam47
    Will
    Bourbon state
    My only question is low pump pressure going to affect a carb? its not efi or throttle body. Pretty basic system.
  13. Aug 24, 2018 at 5:38 PM
    #1193
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    556576202.jpg Will be finished in 2 weeks or so. :headbang:
  14. Aug 24, 2018 at 6:04 PM
    #1194
    SpoilsofWar
    SpoilsofWar Well-Known Member
    Wilmington NC
    2014 DCLB 4x4 TRD Sport Super Charged
  15. Aug 24, 2018 at 6:23 PM
    #1195
    g35man
    League City, TX
    2012 MGM DC 4x4 OR
    Love the sea foam!
  16. Aug 24, 2018 at 6:37 PM
    #1196
    AustinPizzini
    AustinPizzini Well-Known Member
    Austin
    Huntersville NC
    006 ACLB SR5 ON KINGS
    285/75/16 Micky Thompson Baja MTZ P3, king 2.5 Resi coilovers, spiderTrax, cbi hood brackets, caliraised led pods, caliraised led bar in lower valance, UWS tool box, blacked out emblems, 18% tint, lots of audio stuffs
    596CDEDE-E514-4ADA-B3F1-3F34F7653941.jpg My 1995 javelin 400t with a johnson 225 2stroke lots of bass have been caught on this old girl. I named her Jolene the javelin the day I bought her when I was 19B4394DD8-A34A-4FFF-A8AC-0DD428E88D7A.jpg 5B6634F3-D035-4A30-98DE-059DC8EB79EC.jpg 699B3397-0044-44AE-B869-ED985131B122.jpg
    g35man likes this.
  17. Aug 25, 2018 at 5:00 AM
    #1197
    Noelie84
    Noel
    Wales, Maine
    It'd be more of a supply issue than a pressure issue. If the carb isn't pumping enough to keep the bowl full then it won't idle right. Kind of like running an impeller-style low efficiency pump at 100 rpm instead of 1000; you don't get much out of it.
  18. Aug 26, 2018 at 3:50 PM
    #1198
    wilcam47
    Will
    Bourbon state
    a neighbor and myself were talking about this...Im also leaning to a weak fuel pump. Im going over to check it out tomorrow. See what I can come up with I didnt take a look at what type of fuel pump it has so it will be interesting.
  19. Aug 27, 2018 at 5:09 PM
    #1199
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Nellie handling the weather well this weekend! On our “relaxing” cruising day, we got blasted with 28mph sustained winds gusting consistently to 35 along with 3ft waves that we had to beat up wind through to get back to the marina. Don’t really have any pics of the white caps or big waves that broke over the bow and sprayed us in the cockpit, only the nice downwind run we had prior (I forgot to pull the motor all the way up in the first pic, we werent running it lol)
    D6562B20-80DA-428E-94B4-195352ED242D.jpg D7CCFEA4-BF01-42D0-8969-EF3A6BE228C4.jpg
    Intrepid likes this.
  20. Aug 27, 2018 at 7:51 PM
    #1200
    StayinStock
    StayinStock Skittles; fruity yet taste like chicken
    Bob
    Missouri
    2018 OR
    Some
