Show us your BOAT!!!
Discussion in 'Boating & Fishing' started by chris4x4, Jun 29, 2008.
  1. Oct 14, 2018 at 2:33 PM
    #1221
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    This is my boat 17 foot 200 Hp Phantom Sports Jet all aluminum just give me 16 inches of water and we good to go great for fishing in all kinds of weather handles well in rough water and wind only draw back is in this area Utah it is Hard to find a good place that will or even knows how to work on Jet Boats.
  2. Oct 15, 2018 at 3:30 AM
    #1222
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    ^^ Quite a unique boat you got there :thumbsup:
    Wsteven likes this.
  3. Oct 15, 2018 at 2:50 PM
    #1223
    Wsteven
    2018 Tacoma TRD Pro
    Working on them
    Thanks they actually more common with the bigger engines up north like Wyoming on the Snake river and Montana where ever there are a lot of Rivers to run
    ecoterragaia[QUOTED] likes this.
  4. Oct 16, 2018 at 8:45 AM
    #1224
    Spider bit
    Spider bit Member
    Rick
    Toyota Tacoma 2.7
    Just me in my 1983 17’ Clipper Craft Dory.
    I pull it over the coastal range from Portland Oregon to the ocean with my 2000 Tacoma 5spd 2.7 4/4
    I end up down shifting to third a couple times so it makes me wonder if it’s time to move on to bigger after finding out my Frame is toast?
  5. Nov 15, 2018 at 7:10 AM
    #1225
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2025 SR 4X4 DCSB
    Posted in the 4cyl forum but this thread seems fitting!
    2019 G3 Sportsman 1610 w/ 70hp Yammy, Humminbird Helix graphs on console and bow. Boat has been badass so far :dancingbacon: Love gettin after them white perch here in central Louisiana.
    The 2.7 5 speed does great with it, too
  6. Nov 25, 2018 at 9:51 AM
    #1226
    BZ4X4
    BZ4X4 Well-Known Member
    Brian
    2018 Blue Tacoma TRD Off-Road
    Here's my fishing machine. Robalo R222
    Intrepid, Thatbassguy and StayinStock like this.
  7. Nov 25, 2018 at 9:54 AM
    #1227
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Those are pretty much all you see up here in Alaska until you get to the ocean. Practically the only way to get around in the summer is on a good boat going up a river.
    Wsteven[QUOTED] likes this.
  8. Dec 2, 2018 at 6:56 PM
    #1228
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    Here's the little sprint boat that's put away for the winter now. It still makes me laugh to think the boat has 345 hp and the truck only has 159! :D
    Intrepid, Thatbassguy, WOTaco and 2 others like this.
  9. Dec 9, 2018 at 6:37 AM
    #1229
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    My new fishing machine: Blue Sky Boatworks Angler 360 by Jackson Kayaks.
    I have all winter to rig it up in time for the 2019 local bass fishing tourney.
    Probably gonna do:
    Electric motor
    Fish/depth finder
    Multiple rod holders
    DIY two shallow water stake out poles
    DIY anchor trolley, anchor, drift sock
    DIY Milk Crate Box
    Cooler
  10. Dec 9, 2018 at 4:09 PM
    #1230
    Kamakiri
    Kamakiri Overland and Overwater
    Joe
    West Haven Connecticut
    2004 DCSB TRD 4WD SR5 LunarMist 151k
    Ramblin Rose
    1969 Cal 25
    Got her for free and fixed her up a little
  11. Dec 17, 2018 at 1:54 PM
    #1231
    ReelAddict
    ReelAddict Well-Known Member
    Rob
    Lynnwood, Washington
    2018 TACOMA TRD OFF-ROAD DBL CAB
    SUSPENSION: Bilstein B8 6112 Off-Road Suspension Kit - 47-234413 (5/4 Setting) Bilstein 600lb Front Coils Bilstein 5160 Series Shock - w/0" to 1.5" Rear Suspension Lift SPC Adjustable Upper Control Arms (SPC 25470) Wheelers Off-Road Multi-Leaf Add-A-Leaf Set - 1.5" Lift 3 Leaf Progressive Wheeler's Front Superbump Set Wheeler's Rear SuperBump Bumpstop Set Tacoma 2005-2020 Toyota 4WD - Carrier Bearing Shim Kit by Old Man Emu 2016-2020 Toyota Tacoma 4x4 (2"- 6" lift) Front Differential Drop Kit by Revtek Front Strut Mounting Kit KYB SM5640 WHEELS & TIRES: Venomrex 602 17" X 9" -12 Offset Coal Black Venomrex Red Center Cap Inlay NITTO Ridge Grappler All-Season Radial Tire-LT285/70R17 C Rated Cab Mount Chop PERFORMACE: Toyota OEM Intake Flow Accelerator Mod Toyota OEM TRD Air Filter MBRP Cat-Back Exhaust System Single Side Exit 3" Black Series Toyota TSB Software Update (Transmission) KDMAX Performance Tune LIGHTING: AUXITO H11 LED Headlight Bulbs 80W 16,000LM (High & Low Beam) Complete Interior LED Lighting Kit (Xenon White) NAKOBO White 29mm Festoon Led Bulb (Vanity Mirrors) XSPEED 7440 7441 T20 LED Light Bulbs XSPEED 921 912 906 W16W T15 LED Light Bulbs XSPEED 7443 7440 7444NA W21W T20 LED Light Bulbs CaliRaised Side Shooter Ditch Lights R4T Smoked White Grille Lights Meso Customs Ultimate Turn Signal CaliRaised LED 18W Slim Flood Work Lights (Roof Rack) DV8 Offroad BS20E100W5W BS-20 20" SL8 Slim Series LED Light Bar iJDMTOY Yellow Fog Lights CaliRaised LED 18W Slim Flood Work Lights (Bed Rack) STYLING & ACCESSORIES: TRD Pro Grille W/ OEM Garnish Sensor Cover N-Fab Textured Black Nerf Steps Coverking Neosupreme Seat Covers Full Front and Half Hood CHIPPROTECT by IDENS 30% Front Window Tint Toyota OEM TRD Skid Plate Toyota OEM Bed Mat Toyota OEM Bed Cleats Toyota OEM Door Sill Protectors Toyota OEM All-Weather Floor Mats Toyota OEM Blackout Emblem Overlay Kit Matte Black TRD Off-Road Decals Bed Net Organizer Storage Box Center Console Organizer EGR Matte Black In-Channel Vent Visors TAC Fender Flares Sprayed W/Line-X Smittybilt Smart Cover Tonneau Cover AJT Key Fob CaliRaised Low Profile Ditch Light Brackets BFP Heavy Duty Recovery Tow Hook (Painted In Super Red 2) TufSkinz Red Glove Box Insert Center Console Armrest Cover Cup and Console Liners 7" Screen Protector R4T Off-Road Badges Prinsu Design Cabrack Anti Glare Hood Vinyl Custom Rocker Panel Vinyl Mountain Graphics TacoVinyl Pro Grill Decal Pelican Vault V770 Case (2) Blacked Out Side Mirrors X-Bull Traction Board's DV8 Toyota Tacoma Center Mount Winch Capable Front Bumper OEdRo D Ring Shackles Mountain Hatch Tailgate Insert (Red) Toyota OEM Tailgate Power Lock Custom Tailgate Vinyl by IDENS Kentro License Plate Holder AJT Steering Wheel Overlay (Red) AJT Cup Holder Ring (Red) Meso Custom Door Handle Covers Prinsu Ridgeline Handles All-Pro Off-Road Bed Stiffeners Rek Gen Mud Flaps (Red Lettering) Original Quick Fists (2) 3" Quick Fist (2) RotopaX RX-DLX-PM Deluxe Pack Mount (2) RotopaX RX-1.75G Gasoline Pack RotopaX RX-2G Storage Pack First Alert Fire Extinguisher Bond LH043 Red Fiberglass Shovel Gzila Awning Mount Thule 4.5' Overcast Awning CaliRaised DItch Lights Switch CaliRaised Zombie Lights Switch Nexar NEXS1 Smart Dash Cam Ironman 4x4 Fridge Slide Frontrunner RTT Quick Release Mounts Thule X Tepui Explorer Kukenam 3 Yakima Roadshower 7G Havoc Off-Road Running Boards JoyTutus Portable Car 42 Quart Refrigerator
    This is my favorite accessory to go with my TRD OR, I have a Duckworth Advantage 18.7 aluminum fishing boat. I bought her brand new in 2014 and I spend as much time with her on the Puget Sound,, at least once a week. I chase salmon year round out here and will go after lingcod, rockfish, and halibut when in season. I will get about 2 to 3 trips a year out to the Columbia River to chase springers, summer, and fall run Kings.
  12. Dec 29, 2018 at 9:58 AM
    #1232
    squeaky
    squeaky Well-Known Member
    Wisconsin
    2014 MGM DCSB Sport 4x4
    No saltwater here in the Midwest. Walleye fishing is the game in my neck of the woods.
  13. Dec 29, 2018 at 10:32 AM
    #1233
    ReelAddict
    Rob
    Your boat looks like a walleye slayin machine. Walleye is right up there with kokanee salmon as my favorite fresh water fish to eat. We have a pretty good walleye fishery on certain stretches of the Columbia River. I wish I had more time to go after them.
  14. Dec 29, 2018 at 10:39 AM
    #1234
    squeaky
    Wisconsin
    Thank ReelAdict. My bro lives in Portland and he’s told me there are some monster walleye in the Columbia. He’s a big kokanee guy too. I definitely need to get out there and give the kokanee a try
    ReelAddict[QUOTED] likes this.
  15. Dec 29, 2018 at 10:41 AM
    #1235
    squeaky
    Wisconsin
    That brat/grill set up is awesome.
  16. Dec 29, 2018 at 10:51 AM
    #1236
    ReelAddict
    Rob
    Thanks man. It's nice to take a break and grill up some lunch every now and then. Mounts right up on a Scotty rod holder base.
    stickyTaco likes this.
  17. Dec 29, 2018 at 10:59 AM
    #1237
    ReelAddict
    Rob
    You need to visit your brother and have him take you out for some famous Columbia River Kings. That stretch right there in Portland is pretty awesome, especially when there is a good run of salmon and fish & game opens the season.
  18. Feb 11, 2019 at 12:12 PM
    #1238
    sidedrifter
    sidedrifter Member
    Pete
    Shady Cove,Oregon
    2019 Tacoma TRD Offroad LB
  19. Feb 11, 2019 at 12:14 PM
    #1239
    sidedrifter
    sidedrifter Member
    Pete
    Shady Cove,Oregon
  20. Feb 19, 2019 at 1:16 PM
    #1240
    jtill75
    jtill75 Well-Known Member
    jerry
    Nautique G21...in the full on NE Patriots/ The GOAT theme! This was the mock up of the logo....actually centered upon install!goat.jpg patriotsGOAT.jpg
    Clark27 and capetaco12 like this.
