Show Us your Camp GRILL!~
Discussion in 'Food Talk' started by skygear, Sep 30, 2014.
  1. Apr 26, 2015 at 7:50 PM
    skygear
    skygear [OP]                    
    If you look at the tanks. There are 2 different styles.
    1 is the Van style with Bottom access
    2 is the motorhome with Side access.
    I believe the Van style is the preferred tank for my application. However, I was considering an install similar to this one.
    https://www.youtube.com/watch?v=7TpFrrdwOxU
    Starts around 5 min and then again around 9 for the Filler hose .
  2. Apr 26, 2015 at 8:17 PM
    skygear
    skygear [OP]                    
  3. Apr 26, 2015 at 8:51 PM
    skygear
    skygear [OP]                    
    Doing water there also and moving the Air tank.
    Debating on the 12" or 10" diameter tanks now. The 12" would be right at the tow hitch center. If I'm doing a HCRB, 10" might be the proper height. Any thoughts?
    Difference in the mounting options for the valves.
  4. Apr 26, 2015 at 9:22 PM
    skygear
    skygear [OP]                    
    I agree. Also plan to cut out the spare tire carrier completely. Then weld in or bolt in some square bar or 'I' beam. Then a tank in between the new brackets.
  5. Jun 4, 2015 at 8:53 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    So I got my new Camp Chef Rainier stove and I gotta say I am not impressed. After the way everyone else brags about the brand I was expecting a lot better.
    For starters the main body of the stove is dented. There is no real damage to the box so I guess they packaged it up knowing that it was dented. There are little tabs on the base that the surface of the burners is supposed to be hooked under but its not - it was assembled very poorly. The ignitor mechanism works only on the stove burner, not on the grill/griddle burner. The grill and griddle plates are really thin and flimsy and all of the legs are bent to some degree. Those legs are supposed to line up with slots on the base of the stove but they don't so getting it set up is difficult. Then add to that the fact that the ignitor doesn't work so I had to use a lighter to get the burner going....and then try to get the grill with the bent legs situated in the holes that didn't line up before it heated up too much and burned my fingers!
    Debating if I want to exchange it and hope that the next one doesn't have any defects or if I want to just return it and go to some other brand.
  6. Jun 4, 2015 at 9:03 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I have this as well- and we have the CrockPot attachment that sits on top as well! Awesome little grill.
  7. Jun 4, 2015 at 2:18 PM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    just a thought.... what else do you run with propane? I found myself running several types of gas. I made the switch to white gas on everything, or gasoline. The benefits of white gas/ gasoline are also no freezing at altitude or wet weather. propane will ice up when its raining. white gas is great! I use an old school coleman stove from the 60s. works GREAT. for heating the kettle/coffee pot in the morning I use a MSR whisperlite I got for 5 bucks at a thrift store (suckers). I have 4 coleman stoves and didn't pay a single penny for any of them. If you can get an old one, the pump membrane is leather vice rubber, this allows you to soak the leather in oil to keep it fresh if it ever dries out. these are truly bullet proof. I have a secret project if anyone welds aluminum.
    DoorDing likes this.
  8. Jun 4, 2015 at 2:29 PM
    bongwhisperer
    bongwhisperer Well-Known Member
    horn that plays "la cuka racha,"
  9. Jun 4, 2015 at 2:30 PM
    MTgirl
    Weesa
    just wait until it breaks...they don't make any parts for it :mad:
    holy expensive batman!
    still doesn't help me keep things compact either. the two stoves that I have (the old broken coleman an the new broken camp chef) both pack up pretty small AND the grill/griddle pack up inside of the main stove body. no mess, easy to pack, and doesn't take up a ton of space.
  10. Jun 5, 2015 at 10:35 AM
    travis.diller
    Travis
    Kitsap Peninsula
    I do love those Partner steel stoves,way more heavy duty. I want to make a copy of one and then rig it up with the coleman white gas "guts"
  11. Jun 5, 2015 at 11:42 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I like to travel as light as possible so just carry a simple charcoal or gas grill depending on where I'm going. I prefer Weber brand as their products are made with thicker metal unlike the flimsy other brands out there.
  12. Jun 28, 2015 at 8:33 PM
    skygear
    skygear [OP]                    
    Just wanted to say, my PS stove is killer. Used it again today and turned down an offer to buy it from me. Too many memories built in it already I. Such a short time. Used it again today.
  13. Jun 29, 2015 at 11:41 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Holy crap. That Partner stove just made my camp chef look bad. Haha.
  14. Jun 29, 2015 at 12:57 PM
    aficianado
    back to bone stock.
    Right. The Achilles on the camp chef is the bulk. Folding it closed like a book is brilliant.
