Show us your get home rifle
Discussion in 'Guns & Hunting' started by svermilyea, Apr 8, 2020.
  1. May 19, 2020 at 3:17 PM
    #41
    svermilyea
    svermilyea [OP] Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    Personally, the ingenuity of options like this present all kinds of possibilities for lockable storage.
    Beretta4x4 and docloco[QUOTED] like this.
  2. May 19, 2020 at 3:33 PM
    #42
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    7.62x51 or 7.62x39 or 7.62x35?
  3. May 19, 2020 at 3:34 PM
    #43
    GATacoRookie
    GATacoRookie Well-Known Member
    Phil
    Atlanta GA
    MGM TRD OR DCSB 4x4 AT. Mall Rated sticker
    Toytec Fronts. 18x9 Fuels on 285/65/18 TerraGrapplerG2's. LEDs everywhere.
  4. May 19, 2020 at 3:47 PM
    #44
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    x39
    Much more common as well as having brass option from Serbia.
    If I went with 7.62x51, I would have just gotten an AR-10
    ColoradoTJ and Gyrkin[QUOTED] like this.
  5. May 19, 2020 at 7:30 PM
    #45
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    In the name of full disclosure, my cohost and I (we run a podcast together) received one to test and evaluate. He ran it for a good bit without any stumbles, put his suppressor on his AR pistol and broke the folder’s latch mechanism in half a magazine. Both of us and the company agree it’s likely a heat treating issue from how it failed.
    They sent us another one, which I have been running for about a year now without issue. Other than me not having a can, my pistol and my cohost’s aren’t radically dissimilar.
    I don’t shill for anyone, if a product eats dirt I tell my listeners what happened. I have mixed feelings about this one because of the initial failure, but on the other hand it’s run flawlessly for a year since so....
  6. May 20, 2020 at 10:53 AM
    #46
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Have you not put it back on the co-host's gun with the suppressor to see if the problematic part has been fixed? I would think that's one of the first things you would do if you knew a suppressed gun cause a failure or found a weak point.
  7. May 20, 2020 at 11:06 AM
    #47
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Can you all briefly walk me through the AR pistol regulations? A paraphrased version is fine. Looking at the options for an 11.5 or 12.5".
  8. May 20, 2020 at 11:10 AM
    #48
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Not much to it, basically if the barrel is shorter than 16in's and you don't want to get a tax stamp for an sbr, you need to use a pistol brace instead of a stock. You can add a vertical grip if the overall length of the gun is over 26in measure to the end of the barrel (not muzzle device). The gray area is where people say you need to start the measuring. (from the end of the extended brace, end of the buffer tube, or end of brace as long as it doesn't exceed 13 inches length of pull)
    How you travel or carry the pistol varies by state laws.
    TacoTRD78 likes this.
  9. May 20, 2020 at 11:19 AM
    #49
    desertjunkie760
    Shane
    Check My Sig.
    Makes sense. The 26" is the NFA's number for an SBR. Are there specific lowers that are "pistols" or can you use any lower as long as it meets the other requirements (pistol brace, etc)
    Beretta4x4 likes this.
  10. May 20, 2020 at 11:21 AM
    #50
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Technically, once a lower is built into a rifle, it can't be built into a pistol. If you bought a complete rifle and then wanted to build a pistol, you can't use that lower. If you buy a stripped lower and they mark it as a rifle and not "other" on the form, then you can not build it into a pistol.
    wood714 and Beretta4x4 like this.
  11. May 20, 2020 at 11:22 AM
    #51
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    If it's a folder, you measure from the back of the tube, while it's folded, to the end of the barrel.
    If it's telescoping, you remove the brace and measure from the rear of the gun to the end of the barrel.
    BATF put out a letter last year about it.
  12. May 20, 2020 at 11:23 AM
    #52
    Beretta4x4
    Josh
    Temple, TX
    Wrong. Pistol first, it can always go back to pistol. Rifle first, can't go to pistol length unless it's SBR'd
  13. May 20, 2020 at 11:24 AM
    #53
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    BATF as put out a few letters on the subject. Some will contradict others. There really is no black or white regs and the BATF can change their opinion at any time.
    Beretta4x4[QUOTED] likes this.
  14. May 20, 2020 at 11:25 AM
    #54
    Beretta4x4
    Josh
    Temple, TX
    True :bananadead:
    That was their most recent letter on the subject, though
  15. May 20, 2020 at 11:27 AM
    #55
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    You are correct, I did not think about starting as a pistol then to rifle. Basically what i was getting at is your second part. If it was bought as a rifle, don't build it into a pistol.
  16. May 20, 2020 at 11:28 AM
    #56
    Beretta4x4
    Josh
    Temple, TX
    :fistbump:
    Definitely don't make that mistake lol. I always check 4473s so they don't say rifle or pistol, too.
  17. May 20, 2020 at 11:30 AM
    #57
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Right....stick with other so there's no question about it.
  18. May 20, 2020 at 11:33 AM
    #58
    Beretta4x4
    Josh
    Temple, TX
    Yep. Luckily, I haven't ran into that situation, but I have heard of it being done to people.
  19. May 20, 2020 at 11:38 AM
    #59
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    I have also. Read a story of an ffl who would refuse to mark the form as upper on a stripped lower and marked it as rifle. That would be the last time I ever spent money at that location. And that would be the last time any of my friends would too. It's not the end of the world b/c then I would just use that lower on a gun that I know would always be a rifle, but that's not the point.
  20. May 20, 2020 at 11:41 AM
    #60
    Beretta4x4
    Josh
    Temple, TX
    If an FFL did that to me, I'd cancel the purchase and never return. I'd also go Karen on them online :rofl::bananadead:
