show us your gps
Discussion in 'Audio & Video' started by l_prettyman, Dec 31, 2010.
  1. Dec 31, 2010 at 9:29 PM
    l_prettyman
    l_prettyman [OP] Well-Known Member
    Logan
    Maryland
    18 TRD Offroad
    i guess im in the right thread..? but anyway, lets see your gps setup. placement, what it is, anything. i want ideas for a semi-perminant mount. something that can be taken out, but wont be very often.
  2. Jan 3, 2011 at 1:38 PM
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    18 Super White TRD Offroad
    Level 8 Wheels, Bilstien/Eibach lift, 2" aal, blacked out rear bumper, AC drain hose relocation, sound deadening 4 doors and back wall, amp/speaker upgrade, 10" daytona sub, LED interior lights.
  3. Jan 3, 2011 at 2:25 PM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
  4. Jan 4, 2011 at 4:16 PM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
  5. Jan 4, 2011 at 4:23 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    This is what I did with mine and it works really well for me.
  6. Jan 4, 2011 at 4:25 PM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
    is that a custom made thing or can you buy that? or a mix of both haha
  7. Jan 4, 2011 at 4:41 PM
    jeremiekc
    Jeremie
    Vilseck, Germany
    I took apart a cigarette lighter mount that I got through The GPS Store, I hard wired a power cable directly to the fuse panel with an add a fuse and ran an external antanea. It worked really well, I have since changed the way the wires are wrapped.
  8. Jan 4, 2011 at 6:55 PM
    mrmumbels
    mrmumbels Well-Known Member
    Land O Lakes, fl
    09 prerunner
    none
  9. Jan 9, 2011 at 9:06 AM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
  10. Jan 10, 2011 at 6:04 PM
    the arkitect
    the arkitect I will gladly pay you on Tuesday...
    Houston
    08 PreRunner SR5
    jeremiekc, what did you paint your dash with, rattle can? I like it and may have to steal the idea.
  11. Jan 11, 2011 at 4:21 AM
    jeremiekc
    Jeremie
    Vilseck, Germany
    I haven't painted my dash. It came stock with the black dash and a black head unit. I did cover it with a custom fit DashMat cover.
  12. Jan 14, 2011 at 8:24 PM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
  13. Feb 5, 2011 at 11:30 AM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    bump...looking for ideas as well.
  14. Feb 6, 2011 at 8:12 AM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
    i stuck the pad that came with my gps in the dash and put the suction cup onto that. i'll load pics in a couple hours.
  15. Feb 6, 2011 at 8:28 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I can take pics later, but I used the disc it came with and not sure if your 06 has this, but I have a little storage cubby hole kind of below the ignition. I but the disc there and then just stuck my suction cup on that. And the GPS is partly infront of the fan speed switch. Perfect for me cause I normally rest my hand on the shifter, and I can just stick my finger out and change anything I want pretty easily.
  16. Feb 6, 2011 at 8:29 AM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
  17. Feb 6, 2011 at 8:45 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    Mine looks like a garmin zumo 550......for my cycle or car/truck..........my droid google navigation is amazing also
  18. Jun 4, 2011 at 10:36 AM
    section8
    section8 Member
    Cape Codder...
    Like the GPS mount. I need something like that. Looking at the website though the mounts they suggest mount to the left of the steering wheel or down by the shifter. Is that a mod you did or am I missing something? I have a garmin older model 255w and would upgrade it if I needed to have it there. Currently its mounted with the suction cup and plate to the plastic piece where your airbag key control is. That plastic plate pops off from time to time though with the added weight. Its for a 2011.
  19. Jul 3, 2011 at 7:48 AM
    Cape Codder
    Jack
    I'm sorry, haven't been on Site much lately, and missed this.
    Components as follows:
    from - http://www.pro-fit-intl.com/index.html
    VSM Legend 2010 Tacoma Specific Vehicle Device Mount - TY72-05-L
    Device Mount Extension Bracket - EX13-70
    Garmin Nuvi Mounting Adaptor Plate - TT39
    and a couple of tools
    Dash Trim Removal Tool - DTRT DM40-22
    Hook Tool Set - DM30-22
    from - http://www.proclipusa.com/home/home.aspx
    Cell Phone Specific - Item No. 848845 - Holder with Tilt Swivel
    Both Sites have you enter your vehicle and device info to drill down to the specific item
    CC
  20. Jul 3, 2011 at 8:26 AM
    maju
    maju Well-Known Member
    Davenport Fl
    2010 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
    I got these to mount my Garmin on the AC vents, works great cost for both parts was about $7
    [​IMG] [​IMG]
