Show us your REAR Awning? Cover the tailgate?
Discussion in 'Outdoors' started by 2Toyotas, May 18, 2024.
  1. May 18, 2024 at 8:38 AM
    2Toyotas
    2Toyotas [OP] Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Anyone have an awning set up that covers the rear of the truck?
    Tailgate or cap, either one.
    I want ideas to cover the door that we access the back of the truck.
    I've seen the 270 degree setups.
    Thanks.
  2. May 18, 2024 at 9:08 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I've got a couple. The main one I use was sold as some sort of "tailgater" awning and has Velcro loops to attach to the roof rack and came with some poles and guy lines. It was longer than I needed so I cut it to about six or eight feet and added more grommets to make it more adjustable. It and the poles and guy lines/stakes ride in the back of the truck. I've got one of the Keltys (I think they called it the Carport) somewhere too but it's lightweight so it doesn't do well in wind and the window cover is on the inside so if it rains it just leaks everywhere (works as a sunshade though). When I had my VW Westy I just clamped a tarp to the rain gutter and adjusted as desired.
    With all of the homemade "solutions" I've made over the years it'd have been cheaper and easier to have just bought an ARB. :anonymous:
    2Toyotas[OP] and Steves104x4 like this.
  3. May 19, 2024 at 6:24 AM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    I have an ARB off the driver side.
    The rear presents several problems.
    I don't have a rack to attach it to.
    The rails, that I have the thule and awning on, don't present a way to attach the 4 ft ARB awning. I would like that one if ....
  4. May 19, 2024 at 6:34 AM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    I found the Kelty Waypoint. Looks promising.
    Also Slumberjack Roadhouse. It has 2 poles.
  5. May 19, 2024 at 1:59 PM
    Plaintaco
    Plaintaco Well-Known Member
    Houston, TX
    2023 Access Cab TRD Off Road
    Here’s my SJK roadhouse. It’s pretty easy to set up. You can also do an A-frame setup in heavy rain to shed water better.
    TunedUpTaco and 2Toyotas[OP] like this.
  6. May 19, 2024 at 2:26 PM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Thanks
  7. Aug 21, 2024 at 9:29 PM
    suomiM31
    suomiM31 Well-Known Member
    Some interesting ideas here. I have lots of tarps so buying a nice "purpose made" tarp for truck canopy use is out of the question. But I like the concept. Any recommendations on tarp poles? What to look fore, cheap generic substitutes? Amazon.ca has several options but I am leary as quality tends to vary alot in such items on Amazon.
    Thanks!
  8. Aug 21, 2024 at 10:02 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    I got these a year ago and they are not bad at all. Got this link from TW somewhere.
    https://www.amazon.com/gp/product/B08CSKJHXK?ie=UTF8&th=1
  9. Aug 21, 2024 at 10:11 PM
    hikerduane
    hikerduane Stove & lantern collector, retired
    Duane
    Meadow Valley, Jefferson USA
    '16 Blazing Blue Pearl TRD Sport AC V6 manual, tow pkg
    RCI sliders fuel tank skid plate, Softopper, tailgate insert
    I’ve used this a few times, straps to the wheels, enough height to stand up in for a couple people, I’d like to add some short poles and guy them out to the lower end so there is a little more useable space. Lower end could be staked to the ground also as it sits on the ground.
    Duane
    https://www.amazon.com/Kelty-SIDEROADS-Awning-Midnight-Winter/dp/B096SW6XX5
  10. Aug 22, 2024 at 1:26 PM
    suomiM31
  11. Aug 22, 2024 at 1:34 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    AT Habitat made for a nice rear awning when it was setup! About 4 x 7 feet.
  12. Aug 22, 2024 at 1:35 PM
    tacoma_ca
    I got the cheapest ones and they don't seem any worse in use than they look in the images.
    If I ever ordered another set I'd consider getting telescoping poles just because they likely pack down to slightly less space since they are nested. But the cheap ones work to expectation without issue.
    suomiM31[QUOTED] likes this.
