Show us your winches (not your wives)
Discussion in 'Off-Roading & Trails' started by LoadedTaco, Feb 14, 2013.
  1. Jul 7, 2014 at 2:37 PM
    #401
    Grakyn
    Grakyn Well-Known Member
    Kyle
    Prince George, British Columbia, Canada
    2013 DCLB TRD Sport
    Toytec Ultimate Lift, Leer truck cap, Kenwood D710a ham radio, OTRATTW switches
    If someone wanted the shackles that bad, they could just cut your nice synthetic line and have them. Suppose it makes sense for rattling though. Maybe you can find some type of extenstion line and tension them that way, so you have less of your synthetic exposed?
  2. Jul 7, 2014 at 2:39 PM
    #402
    skygear
    skygear                    
    There is a shackle dampener that I see on these all the time
  3. Jul 7, 2014 at 5:28 PM
    #403
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    So do y'all recommend pulling the line all the way in to the hook? Or just putting the hook on 1 shackle and tensioning it there?
  4. Jul 7, 2014 at 5:31 PM
    #404
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    What do you recommend?
  5. Jul 7, 2014 at 5:34 PM
    #405
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
  6. Jul 7, 2014 at 5:35 PM
    #406
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
  7. Jul 7, 2014 at 5:38 PM
    #407
    tbturner47
  8. Jul 8, 2014 at 5:46 AM
    #408
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Thank you Sirs. Have a set on the way. God I love Amazon Prime. That's my go to source for Tacoma parts, and damn near everything else.
  9. Jul 8, 2014 at 9:39 AM
    #409
    tbturner47
    Your welcome. Just ordered a set myself.
  10. Jul 8, 2014 at 9:55 AM
    #410
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I got my winch for free because the wires were run with no protection like many here have been doing. It shorted out and fried the motor - luckily it did not burn down the guys truck.
    I recommend anything made for protecting wire, but I use this because it dries out quickly:
    Where the wire runs over/on/next to/through sharp metal I zip tie a small section of this over the above:
  11. Jul 8, 2014 at 10:49 AM
    #411
    la0d0g
    running for the hills
    For crawling not hauling
    For rattling I put rubber rings on my shackle pin in between the shackle and the recovery points. Makes is so they don't swing unless you move them by hand. Cheap and effective.
  12. Jul 8, 2014 at 12:42 PM
    #412
    lemons
    lemons LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    I used the same stuff on mine. Makes it look nice and clean too.
  13. Jul 8, 2014 at 1:10 PM
    #413
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Anyone found any kind of stick on wire loom to route wires? Mine are currently duct taped into place
  14. Jul 8, 2014 at 5:14 PM
    #414
    skygear
    skygear                    
  15. Jul 8, 2014 at 5:24 PM
    #415
    ckeene9
    Chesterfield, VA
    See Build Thread
  16. Jul 8, 2014 at 5:48 PM
    #416
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    Sorry, but what does this do? Is this just a way to keep the wire from touching the metal if the insulation wears through?
  17. Jul 9, 2014 at 9:26 AM
    #417
    la0d0g
    Yep, provides extra layer of protection.
  18. Jul 9, 2014 at 9:53 AM
    #418
    XXXX
    sKiP
    05 Prius
    No, it keeps the insulation from ever getting worn so it never shorts out and causes a fire or short.
    Intact insulation is key and vibration is the enemy.
    Large cables like these do not need direct contact with metal to short as is the case with the winch I got for free. The cable got sliced exposing the wire at some point and even though the cable was 1-2" away from anything at some point it found a conductor to create the short (my guess is water got to it).
  19. Jul 9, 2014 at 12:25 PM
    #419
    james Daniel
    james Daniel Well-Known Member
    james
    13 TRD off road
    Finally mounted the warn
  20. Jul 10, 2014 at 3:42 PM
    #420
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    :popcorn: I want a winch when I grow up
