Show us your winches (not your wives)
Discussion in 'Off-Roading & Trails' started by LoadedTaco, Feb 14, 2013.
  1. Feb 26, 2015 at 9:56 PM
    #701
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    ok. Remember, you asked.
  2. Feb 26, 2015 at 10:16 PM
    #702
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I sure did. I was hoping for a few more personal impressions but it seems like Warn has done an amazing job capturing most of the market. I appreciate the comments either way, in the end it wasnt enough to sway me to spend double the money. I'll post my winch on here when I get everything installed and update for others if something does go wrong. :thumbsup:.
  3. Feb 27, 2015 at 4:00 AM
    #703
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    I personally have seen or heard about 3 Warn motor failures when the winch was needed most within our group here in Colorado. All were related not needing the winch for some time and then when needed the motor had quit. Also one solenoid going out. Every single one was a Warn.
    Could be a coincidence sure. But the numbers keep stacking up.
  4. Feb 27, 2015 at 6:48 AM
    #704
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    You can always throw that high point at someone. From my experience that is the only way a high point will hurt someone. Good winch analogy...
  5. Feb 27, 2015 at 7:21 AM
    #705
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    so after 3-ish years with my winch, it's about time to replace the line, out of the countless pulls I've made on the winch, I can count on one hand, how many have been straight pulls with light to no line pressure on the hawse. this has resulted in deterioration of the line over time from friction.
    starting the search now for a very durable winch line to replace this one with. I can buy one premade, or I can go directly to a company like plasma or amsteel and splice my own. not preferring one vs the other at this point.
    Master pull has actually caught my attention for durability, as one version of their lines is fully shielded, much like the dock lines or sheets that are used on boats.
    not so much concerned on their strengths, as most of the manufacturers are within a very close range for given line diameters.
    so for those of you who have owned multiple brands of synthetic line, or have used/inspected different types on other folks rigs, what do you believe is the most durable synthetic line? go :)
  6. Feb 27, 2015 at 7:59 AM
    #706
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    the thing with line that has a braided casing is this:
    it's the core diameter that provides the strength.
    Then the casing provides protection. But it increases total line diameter.
    And only so much line fits on the spool. So if you go with a shielded line, you end up with a shorter one.
    That may be a good tradeoff for you, I dunno.
    Also, most snatchblocks are for 5/16 or 3/8. So a line with a braided casing may not fit through it.
  7. Feb 27, 2015 at 8:19 AM
    #707
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I'm fine cutting 20 feet out of my total line length to accommodate the larger diameter. Already planning on splicing the pristine sections of my current line into extensions, so length won't be an issue.
    I'll have to check what diameters my snatch blocks can handle. Good point and thank you for the input.
  8. Feb 27, 2015 at 10:09 AM
    #708
    Idaholandho
    I don't doubt they have failed in the field. Having a number of off road vehicles, and having logged many miles on trails, I have thankfully not seen any winch fail.
    I can google Warn/Smittybuilt/Superwich failure and find it but, I am comfortable buying Warn products because of their success and my experience.
    I also use ARB recovery straps. Yep, they are expensive and there are cheaper ones available and am sure they will successfully assist a recovery much like the ARB's but, I am one not to go cheap in recovery gear. It is one of the most important links in our sport and hobby and I will continue to spend the extra money.
    Budget can be a key a factor and if it is the crux of the buying process than so be it but, if not, than many including myself will lean towards quality and successful history over saving money(Much like the Toyota's we drive :))
    :thumbsup:
  9. Feb 27, 2015 at 10:21 AM
    #709
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    For recovery I use both ARB straps and Bubba rope. The Bubba rope is far superior for tugging someone out since it's a true kinetic design. The Bubba also costs more. Sticking with one brand isn't always the best idea. If no one ever tries something different, how will you know if something works well or not?
  10. Feb 27, 2015 at 10:24 AM
    #710
    Gramps
    Gramps
    07 TRD DC 4x4
    I always wanted to get my hands on a Bubba rope and try it. I have the assorted ARB straps and a Viking tree saver. I think the Bubba would be good for snow bashing.
  11. Feb 27, 2015 at 2:29 PM
    #711
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    I got to use my 7/8" bubba rope on a recent 9 day trip down to southern Utah. Came around a sharp corner in Canyonlands NP and saw two fellas in a 2wd GMC Envoy stuck in the soft sand/dirt having failed to negotiate the corner in the dark. About 5 minutes of digging with the shovel to clear a little path for the wheels and a quick yank with the rope and they were free. Worked perfectly!
  12. Feb 27, 2015 at 3:51 PM
    #712
    Idaholandho
    I think you will get many years of use out of the SBilt. They seem to be getting a good rep out there :cheers:
    I also love Bubba....rope. The best out there imo.
  13. Mar 1, 2015 at 8:39 AM
    #713
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Have you considered switching to a roller fairlead? Should put a lot less stress on the line during angled pulls. I've got Daystar poly rollers and they seem to work great. Come in black and red too so you're not stuck with silver/chrome (if that matters to you)
    Unrelated: my Superwinch ep9.0 has experienced so issues lately with pulling power. Could it be that my battery is undersized? It's a gold series from Advance Auto 640cca. Should I look into a dual battery set-up? Or possibly it's that they have been short pulls ~25' and I didn't pay out enough line to get max pulling power? Also, could the extreme cold temps lately affect the efficiency of the motor, ie frozen grease?
  14. Mar 1, 2015 at 4:34 PM
    #714
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    My winch won't power out. Who makes a good replacement contactor?
  15. Mar 1, 2015 at 4:53 PM
    #715
    Idaholandho
    What brand winch? I would think most companies are now making single replacements whether updating to a contactor from solonoids or just replacement due to failure.
  16. Mar 1, 2015 at 4:59 PM
    #716
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    I'm wondering if the newer warns that have the solenoids externally mounted are causing problems since they are exposed in the elements. Mine is an older warn all integraded, never had any problems
  17. Mar 1, 2015 at 5:30 PM
    #717
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    My motor failure was my fault. There are specific instructions mentioning feet forward mounting, I didn't read that part. So my motor filled up with water and rusted out everything on the insides. That reminds me I have to change it back to mount in the Addicted bumper.
  18. Mar 1, 2015 at 6:08 PM
    #718
    Gramps
    Gramps
    07 TRD DC 4x4
    Yeap I have been thinking about that. Need to re-clock the motor for feet down with the new bumper.:)
  19. Mar 1, 2015 at 6:17 PM
    #719
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Recon 10,500lb. I'm pretty sure all these Chinese winches are the same.
  20. Mar 1, 2015 at 8:45 PM
    #720
    Idaholandho
    lol. In that case, maybe just stick with the cheaper ones. I suspect a Warn or Superwinch will be double/triple the amount :notsure:
    I am not sure of your set up but, may not be able to fit the new one in your current control box, I would find a protected place to mount it and go to NAPA to find at least 4ga wire to use or 2ga if you want a bit better amp protection.
