Show your 1911.
Discussion in 'Guns & Hunting' started by rmb_crew, Jan 22, 2010.
  1. Dec 31, 2010 at 3:24 AM
    #181
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    They don't make a model for the CW45, and there's enough differences between that and the PM40 that I'll need to try fitting in the flesh before I buy another holster. (Found that out with a Fobus from Cheaper Than Dirt)
  2. Dec 31, 2010 at 3:43 AM
    #182
    SteelRain
    SteelRain Veteran Redleg
    Curt
    San Tan Valley, Arizona
    Bummer. I guess that's the one thing about Kahr that I don't like. It was hell to try andfind a mag carrier for my cw9 mags. I finally had one custom made from Jimmy at Sabrosa Holsters.
  3. Dec 31, 2010 at 3:52 AM
    #183
    TXBulldawg
    TXBulldawg Well-Known Member
    Texas
    2014 Silver 4Runner SR5 4x4
    In progress...
    Here's a Springfield GI I did some tinkerin' on a couple months back.
    C&S hammer/sear/disconnector/sear spring/main spring
    S&A .220 grip safety
    Wilson thumb safety
    Ed Brown plunger tube
    EGW extended checkered mag catch
    Wilson flat checkered MSH
    Harrison retro rear sight
    Novak tritium front sight (dovetailed by Novak)
    Dehorned edges
    Slightly beveled mag well
    VZ Grips (Tiger Stripe Operators II... although I swap grips like a woman swaps shoes)
    Stair tread tape on the front strap
    Lots of Brownells Oxpho Blue
  4. Dec 31, 2010 at 6:47 AM
    #184
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Looks good! I hear what you're saying about the grips. Right now a set of $60 VZ Gatorbacks is sitting in the parts drawer while my 1911 has a set of $11 Hogues on it.
  5. Dec 31, 2010 at 8:58 AM
    #185
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    I'm curious to know what how do u guys sight in your 1911 and fine tune it??? What kinda steps do u take in order to get the most accurate possible shot...???
  6. Dec 31, 2010 at 10:04 AM
    #186
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Love the VZ grips...I just haven't found the desire to spend $60 or more on grips.
    Skateboard tape is the shit for FS grip.
    Good job.
  7. Dec 31, 2010 at 5:14 PM
    #187
    Dimonback
    Patrick
    For fine tuning I check out several different handloads, and factory ammo.
    I wouldn't trust myself again to try tightening the bushing or slide, although I did it once on a Springfield Mil Spec without bad results. High end 1911s should not need this kind of treatment until after many thousands of rounds.
    I also polish the feed ramp and chamber with a dremel buffing mop(?) and jeweler's rouge. I like both to have a mirror surface.
    Other than that, realize that every load will hit differently, and until you settle on only one, moving the rear sight isn't going to zero the gun.
  8. Dec 31, 2010 at 6:07 PM
    #188
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    thanks boss...
    have u ever used or heard of this recoil reducers...??
    http://sprinco.com/recoil.html
    i just found out about them... and was curious to know there benefit..??
  9. Jan 1, 2011 at 6:18 AM
    #189
    Dimonback
    Patrick
    I've seen them, tried them, and found no obvious benefit. If they worked for anything I couldn't tell.
  10. Jan 1, 2011 at 9:44 AM
    #190
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    yea i kinda was skeptical about it... wasnt really familiar with the spring also being incorporated in the glide rode... im assuming the muzzle compensator would be more useful than that....
  11. Jan 1, 2011 at 10:15 AM
    #191
    TacPro45
    TacPro45 Well-Known Member
    '11 TRD Sport Double Cab Long Bed
    Weathertech Floor Liners
    x2 on the CDP! I have the Ultra CDP II and it's perfect size for concealed carry, very accurate right out of the box as well!
  12. Jan 1, 2011 at 9:21 PM
    #192
    SteelRain
    Curt
    I am looking into buying a new 1911 soon. Torn between the Kimber or the Springfield Armory. Custom TLE RL or Springfield Loaded.
  13. Jan 2, 2011 at 3:23 AM
    #193
    Dimonback
    Patrick
    Both fine weapons, but the checkered frontstrap on the Kimber tips the scale in my mind. It makes a lot of difference in the stability- although I've used the skateboard tape trick with good results. Kimber triggers seem to be generally better as well- Springfields tend to hit a notch just before the sear releases.
    Numbers on Gunbroker.com are all over the place.
  14. Jan 2, 2011 at 8:51 PM
    #194
    SteelRain
    Curt
    I've been on that site a lot lately...browsing. I miss my Kimber Pro carry HD..kinda leaning towards the Curtom TLE/RL
  15. Jan 2, 2011 at 9:01 PM
    #195
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    This, and, seems quite a few of the newer Springers are made in Brazil, otherwise, Kimber are 100% made in Yonkers, New York USA.
  16. Jan 3, 2011 at 10:45 AM
    #196
    thinkingman
    redmond WA
    Be careful with the Dremel...probably the gunsmiths favorite item for generating business.
    For those of you with Kimber CDP's and other light alloy frames...polishing the feedramp will quickly wear through the hard anodizing of the frame and polished aluminum doesn't stay polished very long....hollowpoints will eat right into the frame.
    I only buy steel-framed 1911's and those can be worked a little more agressively.
  17. Jan 3, 2011 at 11:06 AM
    #197
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I had reservations about aluminum frames too. i only got the S&W 1911 PD because it isn't straight aluminum. It has scandium too which is supposed to be some pretty hard stuff, though I'm not about to test it by polishing the feed ramp. They say steel guns you shoot a lot and carry a little, aluminum you shoot a little and carry a lot.
    As far as reliability, I have feed about 200 israeli made wad cutters made in 1973 through it with two malfuntions, can't remember for sure but i think they were stovepipes. That would make sense with 40+ year old powder and very light bullets. Never had any other problems, and I can easily hit a honeydew at 100 yards with novak low mount sights. The steel guns do shoot nicer though because of the weight. My scandium smith just handles more quickly.
  18. Jan 3, 2011 at 3:08 PM
    #198
    SteelRain
    Curt
    Well...I settled on this one. Kimber Crimson Carry II.
  19. Jan 3, 2011 at 10:28 PM
    #199
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    BADASS!!!! congrats
  20. Jan 3, 2011 at 10:50 PM
    #200
    in2nite
    in2nite Well-Known Member
    James
    SoCal.
    blk 07 prerunner
    Engage Offroad L/T front and rear, Kings and 50t pack, Hella 4000's, Pro Comp Wheels and tires
    Colt commander
    para orrdinance p13
    sig 228
    ruger red hawk 41 mag
    s&w j frame 38.
