Show your 285/75/16 and 285/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spewed, Jan 14, 2017.
  1. Mar 3, 2022 at 4:17 PM
    #2781
    zee_vee
    zee_vee Well-Known Member
    TITE....
    kas2828[QUOTED] likes this.
  2. Mar 4, 2022 at 9:07 AM
    #2782
    Thomasf94
    Thomasf94 Well-Known Member
    Thomas
    Pensacola, FL
    2017 Cement TRD Pro
    AUXBeam LED Headlights Blacked out letters
    Wildpeaks, westcott pro lift, and AAL going on this afternoon! So pumped
  3. Mar 4, 2022 at 2:13 PM
    #2783
    zee_vee
  4. Mar 5, 2022 at 3:16 PM
    #2784
    Thomasf94
    Thomas
    Pensacola, FL
    2017 Cement TRD Pro
    Alright this looks sooooo freakin good in person. So glad I went with 285.
  5. Mar 5, 2022 at 3:21 PM
    #2785
    rip ej1
    rip ej1 Well-Known Member
    Daniel
    NorCal
    2020 AG TRD Pro
    Damn that’s hot!
    Which AAL did you go with? I’m assuming you didn’t use the rear block from the Westcott kit?
    Thomasf94[QUOTED] likes this.
  6. Mar 5, 2022 at 3:34 PM
    #2786
    Thomasf94
    Thomas
    Pensacola, FL
    2017 Cement TRD Pro
  7. Mar 5, 2022 at 3:53 PM
    #2787
    rip ej1
    Daniel
    NorCal
    2020 AG TRD Pro
    Bedawson and Thomasf94[QUOTED] like this.
  8. Mar 6, 2022 at 2:57 PM
    #2788
    rnmnzii
    rnmnzii Active Member
    rene
    taco
    2020 DCSB SR5
    - Eibach Pro Sport Shocks on OEM Springs (1.75”)
    - Toytec 1.5” Rear Blocks
    - 285/70r17 BFG KO2’s
    - 17x9 Rocktrix RT113 (-12 Offset)
    - Mudflaps rubbed, removed
    - Front fender liner rub (trimmed plastic)
    - No CMC necessary for daily driver
    rip ej1, 6mtTRD, JDSmith and 5 others like this.
  9. Mar 7, 2022 at 9:34 AM
    #2789
    Kaptain_02
    Kaptain_02 2019 OR
    285/75/16's (-12 offset)
    About 1.5 inches of lift up front (OME 886's)
    Stock UCA's
    CMC
  10. Mar 7, 2022 at 3:51 PM
    #2790
    zee_vee
    LOOKING SHARP!!!!!
    Kaptain_02 and Thomasf94[QUOTED] like this.
  11. Mar 7, 2022 at 3:54 PM
    #2791
    zee_vee
    thanks for that info ...my new truck is at the 4X4 spot now getting
    Nitto Ridge Grapplers 285/70r/17
    SCS GEN5 17x9 -38 offset ...
    well will see whats gonna have to be done ...my friend who rinds the shop said hes got me and no worries ..
  12. Mar 7, 2022 at 4:58 PM
    #2792
    Thomasf94
    Thomas
    Pensacola, FL
    2017 Cement TRD Pro
    Thank you! Really happy with the look!
  13. Mar 7, 2022 at 5:02 PM
    #2793
    satburn
    satburn Fast, Cheap, Reliable... Pick any two.
    Columbia, MO
    2018 Tacoma TRD Off Road
    Nitto Ridge Grappler 285/70R17
  14. Mar 8, 2022 at 3:45 PM
    #2794
    Kennyu5
    Kennyu5 Active Member
    TRD Off-road 4x4
    Day 1 and no rubbing as of yet. I’ll probably need to trim a little off the front at some point. For some reason my wife isn’t as excited as I am….
  15. Mar 8, 2022 at 4:11 PM
    #2795
    rip ej1
    Daniel
    NorCal
    2020 AG TRD Pro
    So purrty. Suspension?
    Thomasf94 likes this.
  16. Mar 8, 2022 at 5:29 PM
    #2796
    Kennyu5
    TRD Off-road 4x4
    Found a newish set of 2021 Pro Fox shocks.
    rip ej1[QUOTED] likes this.
  17. Mar 9, 2022 at 2:50 AM
    #2797
    Pengowirr
    Pengowirr Well-Known Member
    2018 TRD Off Road Manual Transmission Cement
    265/75/r16 Cooper ST MAXX
    What kills more MPG, heavier tire or bigger diameter.
    im currently running 265/75r16 Cooper ST Max and the website says they’re 55lbs
    Looked at their AT3XLT 285s and it says they’re 54 lbs and their 295s are 58 lbs
    Would going to the 285s keep me at the same MPG or would it tank even further because of the bigger diameter.
    Thanks guys
  18. Mar 10, 2022 at 1:27 PM
    #2798
    zee_vee
    285/70R/17
    SCS 17/9 -38 offset
  19. Mar 11, 2022 at 2:40 PM
    #2799
    Rodarbal
    Rodarbal Lurk lurk lurk
    RJ
    Cedar Park, TX
    2019 DCSB TRD OR Calvary Blue MT
    It will likely be worse. This is a classic case of, "it's not so much about how much it weighs, but where the weight is located." Despite the 285s weighing slightly less than the Coopers, most of the tire mass is on the outside diameter. The bigger diameter (and wider footprint) will require more work which negates the slight savings you had in overall weight.
    HAILST8 likes this.
  20. Mar 11, 2022 at 5:07 PM
    #2800
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    That looks great! No rubbing? I have the same kit to install, might do an AAL like you did vs the westcott rear block.
