Show your 285/75/16 and 285/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spewed, Jan 14, 2017.
  1. Apr 24, 2022 at 6:28 AM
    #2901
    Theoncosmokane
    Theoncosmokane Member
    Licas
    2022 Taco Off Road
    2022 TRD OR, Fuel Rebel 6s and KO2s 288/70/17
  2. Apr 25, 2022 at 6:38 PM
    #2902
    awantura
    awantura Active Member
    285/75/16 st maxx + scs f5 0 offset. spc uca at D and the lowers aren't maxed for caster/clearance. Zero rubbing...maaaaybe may slightly rub pinch weld at full compression and wheel turned which I haven't done yet (and I still have room to move them further forward).
    6mtTRD[QUOTED] likes this.
  3. Apr 25, 2022 at 7:29 PM
    #2903
    Nymbus
    Nymbus Well-Known Member
    2021 TRD Offroad DCSB Cement 4x4 AT
    What’s your circlip on the 6112? I’m thinking about going to 285s but have my 6112 on the 4/5 setting and my wheels are also 0 offset. I might have to to change the circlip setting most likely to 5/6 to keep 285s from rubbing.
  4. Apr 25, 2022 at 7:37 PM
    #2904
    awantura
    my 6112 are at 5/6 on 285 0 offset….it won’t make a difference with 4/5 as the wheel will still travel up the same amount 5/6 just just let’s the spring extend more in neutral position (more lift)
    Nymbus[QUOTED] likes this.
  5. Apr 25, 2022 at 7:42 PM
    #2905
    Nymbus
    Thanks for the info. I was really hoping not to pull the shocks out to change the circlip setting. I should have gone 5/6 the first go around but I’m happy where it’s at now. Just wanting to go a little bit bigger tires.
  6. Apr 26, 2022 at 11:13 AM
    #2906
    9MM
    9MM Member
    Jonathan
    2017 Quicksand TRd OR
    I’m at the 5/6 setting, no rubbing and feels great!
  7. Apr 26, 2022 at 2:35 PM
    #2907
    Nymbus
    what’s your caster on the alignment if you don’t mind me asking?
  8. Apr 26, 2022 at 5:51 PM
    #2908
    9MM
    9MM Member
    Jonathan
    I don’t recall the but it is within Toyota’s spec. I did opt for 0 camber up front as Toyota calls for +1.. which looks gross with a lift and big tires.
  9. Apr 29, 2022 at 5:52 AM
    #2909
    DACO86
    DACO86 New Member
    2020 TRD OffRoad
    Question, I have 2inch level kit, TIS -10 offset 17in rims and 285/70/17 WildPeaks AT3 getting ready for install on my stock 2020 TRD Offroad. Alignment to follow after setup is complete. Is there anymore expectations that'll be necessary to prevent fender wall rubbing, UCA rubbing and so forth?
  10. May 2, 2022 at 7:59 PM
    #2910
    austinangus2
    austinangus2 Member
    Austin
    North Jersey
    2018 Toyota Tacoma TRD Sport
    what are your side steps?? I need those!
  11. May 3, 2022 at 1:04 PM
    #2911
    geoyota760
    geoyota760 Allergic to pavement
    PHOENIX, AZ
    2019 TRD OR
    5.29 Nitros Bilstein ICON Kansei BFG
    Looking at the BFG KO2's in 285/70/17...according to Discount Tire's website tire weight is 51lbs in load range C.
    Has anyone actually weighed their tires before mounting to see how accurate stated vs. actual is on tire weights?
    Same Q on wheels...interested in the Kansei Roku HD which has a claimed wheel weight of 24.8 lbs?
  12. May 4, 2022 at 12:27 PM
    #2912
    Diesel156
    Diesel156 Well-Known Member
    Looks good is that 0 offset?
    Fullsendcf likes this.
  13. May 9, 2022 at 8:48 AM
    #2913
    Jpalafox
    Jpalafox Active Member
    Jonathan
    2019 Tacoma TRD Off Road to 2022 TRD Pro
  14. May 13, 2022 at 12:27 PM
    #2914
    Hockey71
    Hockey71 Well-Known Member
    Jacob
    Hockeytown, Detroit, Michigan
    2021 TRD Sport
    285/70/17 on 17x8.5 +0 KMC Impact OL
  15. May 19, 2022 at 8:18 AM
    #2915
    DAGDVIKING
    DAGDVIKING Well-Known Member
    Nick
    Salt Lake City
    2017 DCSB TRD Off Road 4x4
    2017 TRD Off Road with all options
    sport hood with paint matched bumpers
    TRD pro grill
    Tacomabeast headlights
    Nitro 4.88 gears
    OME 886 springs with 5100's and add a leafs
    SPC upper control arms
    285-70-17 BFG KO2's
    Junkhead, TacomaONT, Treggit and 11 others like this.
  16. May 21, 2022 at 1:58 AM
    #2916
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Now thats nice!!! Well done, so tell me this? Rubbing? OEM 4runner Pros or or knockoffs?
  17. May 21, 2022 at 5:25 AM
    #2917
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    our trucks are very, very similar.
  18. May 22, 2022 at 2:20 PM
    #2918
    9MM
    9MM Member
    Jonathan
    Lemme see it!
  19. May 23, 2022 at 8:56 AM
    #2919
    hokiehunter19
    hokiehunter19 Well-Known Member
  20. May 23, 2022 at 9:52 AM
    #2920
    Rahjer
    Rahjer New Member
    Roger
    San Diego, California
    2020 Toyota Tacoma TRD 4x4 Off-Road
    Fox 2.5 DSC with 2.5" lift plus Fox 2.0 DSC with Deavers AAL Method MR305 wheels with BFG KO2 285/70/17 Misc Overlanding gear
    Loving my new wheels!
    Method MR305 17x8.5 0 offset plus BFG KO2 285/70/17
    Fox 2.5 DSC fronts with 2.5" lift, Fox 2.0 DSC rear with Deavers AAL + 1" block
    geoyota760, DavesTaco68, TK11 and 3 others like this.
