Show your 285/75/16 and 285/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spewed, Jan 14, 2017.
  1. Jul 30, 2022 at 7:53 PM
    #2941
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    You should gain at least 2mpg going to stock size compared to the tires u have now. I dropped 1 mpg going to 265/75//16s compared to stock size.
    Of course thats providing that u actually need new tires and wouldnt be buying a smaller set just to increase mpgs. In which case, how long would the increase in mpgs take to equal the expense of new tires that u dont really need right now?
  2. Jul 31, 2022 at 8:24 PM
    #2942
    2jyoda
    2jyoda Well-Known Member
    Stevie
    Chandler az
    2021 Super White SR Taco 3.5 V6
    SDHQ ABS Guards, AC Drain mod lol. Bed Mat and Bed lights.
    would you be rubbing with 35s?
  3. Aug 2, 2022 at 11:41 AM
    #2943
    DmiRider
    DmiRider Well-Known Member
    Cale
    yeah the tires I have now still have a good bit of life left in them, I was just thinking about it and figured I’d ask for the future. Definitely would make financial sense to buy new when these are still good.
  4. Sep 2, 2022 at 8:40 AM
    #2944
    scottyventure
    scottyventure Well-Known Member
    Scott
    2018 Tacoma TRD OR DCLB
    A.R.E MX topper with a custom rack on top Total Chaos bed stiffeners 265/75R16 Cooper AT3's
    Anyone running 285/75r16 Geolander G015? I am currently on 265/75r16 Toyo AT3's and love them but the are starting to wear. The toyo's in a 33" are $300 each and that's tough to justify. The Geo's are just over $200 each and seem like a solid tire with good road manners.
  5. Sep 2, 2022 at 9:25 AM
    #2945
    RoxysToy
    RoxysToy Member
    Roxanne
    2019 Trd 6 Speed Sport
    Love this thread I am going with a 285/75/17 and I'm curious if you guys are running any spacers and if so should I go 1.5" or 2"
  6. Sep 3, 2022 at 8:04 PM
    #2946
    Mt133677
    Mt133677 Well-Known Member
    SoCal
    2020 DCSB TRD OR
    All the things
    bfg ko2’s on enkei rpt1’s
  7. Sep 3, 2022 at 8:43 PM
    #2947
    My4thTacoma
    My4thTacoma Pain Don't Hurt
    St Petersburg, FL
    2024 TRD Sport 4x4 (Solar Octane)
    that is exactly the stance i want on my truck. beautiful!
  8. Sep 3, 2022 at 8:45 PM
    #2948
    My4thTacoma
    St Petersburg, FL
    is the ride firmer, or softer with the 5100s?
  9. Sep 5, 2022 at 3:29 PM
    #2949
    kas2828
    kas2828 Well-Known Member
    Austin
    Arizona
    2020 TRD Off-road 4x4 DCLB
    With the 5100s it made it a firmer ride but in a good way. The stock OR suspension was really bouncy and would nose dive when braking. Now it feels more planted to the road on and off roading. Way better than stock.
  10. Sep 8, 2022 at 1:23 PM
    #2950
    My4thTacoma
    St Petersburg, FL
    i wonder if its similar to the Sport suspensions feel? Im looking for something like that or a little softer
  11. Sep 8, 2022 at 3:51 PM
    #2951
    6host
    6host Active Member
    I’ll add in there that the 5100s are mono tube shocks with a digressive piston. They “cycle” a lot better than stock and have more travel.
    “The magic of the digressive rate piston is that it can retain softer and compliant high speed compression characteristics while having relatively stiff low speed compression characteristics. This makes the shock incredibly active and compliant over bumps and rough roads while being firm and resistant towards unwanted body motions making the car that much more stable. Essentially you can have a setup that will do a better job of managing unwanted body motions while also still providing a compliant ride, so that you can achieve the maximum performance of your vehicle possible while making less compromises.”
  12. Sep 8, 2022 at 3:58 PM
    #2952
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Ooooh another thread that ask for pics? You got it.
    285/70/17 Nitto Ridge Grapplers on 17x8.5 -10 Volk RAYS TE37's.
    (Truck has been lowered a little since this was taken)
  13. Sep 8, 2022 at 6:00 PM
    #2953
    Casey182
    Casey182 Well-Known Member
    Sacramento
    '20 TRD OR - '21 T4R ORP - '66 Chevy C10 SB
    3 inch lift? THATS the look right there that I want.
  14. Sep 8, 2022 at 6:07 PM
    #2954
    MTBswift
    MTBswift Well-Known Member
    Hunter
    Coeur d'Alan, ID
    2016 Tacoma Offroad
  15. Sep 8, 2022 at 8:13 PM
    #2955
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    That was with the RXT leaves @ stage 1 (which gave me about 2.25" rear lift - about .5" more than advertised) which made me have to lift the front more than I wanted (probably 2.5-2.75") to keep the rake proper. I was never happy with the RXT's, they lifted too much and we're way too stiff. I have since swapped over to Deaver J66 leaf packs which are softer and sit lower which let me lower the front about .75" to match with the rear leaves and it rides immensely better. Handles better as well and axle angles are happy again. Still looks tough where it's at now but being comfortable is a big deal to me.
    Casey182[QUOTED] likes this.
  16. Sep 8, 2022 at 10:01 PM
    #2956
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    I have the Icon RXT Stage 1 and you've got me looking at the J66 for the past 30 mins now.... they were on my radar back when I was deciding on my setup but your statement above makes me want to pull the trigger. Stage 1 RXT still seems a bit stiff for me (next to no load in the bed)
    drizzoh[QUOTED] likes this.
  17. Sep 8, 2022 at 10:18 PM
    #2957
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    285 75 16
    trailbound likes this.
  18. Sep 8, 2022 at 10:29 PM
    #2958
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    285/75r16 with 1.5 inch wheel spacers
    Mrod18, DavesTaco68, kas2828 and 7 others like this.
  19. Sep 9, 2022 at 8:23 AM
    #2959
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    You won't regret it. It's night and day different if you mostly keep the bed unloaded. Even nicer if you install them with an upgraded shackle - I changed mine out for the greasable BAMF HD's.
    bttrbsch[QUOTED] likes this.
  20. Sep 9, 2022 at 8:46 AM
    #2960
    Kefka
    Kefka Well-Known Member
    01001010 01101111 01101000 01101110
    2019 MBM TRD PRO
    Joined the 285 club recently: Toyo AT3 285/75 16
