Show your 285/75/16 and 285/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spewed, Jan 14, 2017.
  1. Feb 2, 2023 at 2:19 PM
    #3081
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    I moved up to a similar lift, with 285/70R17's on some lightweight Method Wheels and I'm getting 17 MPG's cruising the highway at 70, and 14-15 MPGs around town. I do drive in ECS PWR all the time. I have stock gears, and plan to swap them out for 5.29s here next winter.
  2. Feb 2, 2023 at 2:22 PM
    #3082
    KobyTaco19
    KobyTaco19 Active Member
    2019 Black Tacoma Limited
    Stinger head unit on way
    what's the advantage of the 5.29 gearing??
  3. Feb 2, 2023 at 2:27 PM
    #3083
    rukness
    rukness Well-Known Member
    Love the look! what's your lift?
    tacoLvR10 likes this.
  4. Feb 2, 2023 at 7:31 PM
    #3084
    2Shoes
    2021 TRD Off-Road
    When you move to a larger tire size, the gears in the axles become, too high for the engine and transmission to operate properly. For example, if I was to stick with this tire size, I would only go to 4.56, or 4.88 gears, but I plan to move up to 35's, or at least 285/75R17's in the next year or two and possibly even up to 37's. It's fairly simple math, but the engine has to work harder, with a higher stock gearing, and larger tires, and will lose fuel economy, because it's working harder, to go the same speed. When you lower the gears, the engine will have to work as it's intended, and it will help the engine and transmission last longer.
  5. Feb 14, 2023 at 12:49 AM
    #3085
    cheesus
    cheesus New Member
    285/75/16 duratracs and scs f5 -25
    Mrod18, andthen, tacoLvR10 and 6 others like this.
  6. Mar 3, 2023 at 12:53 PM
    #3086
    GSager78
    GSager78 Well-Known Member
    SoCal
    2021 TRDOR 4x4 DCSB AT, 1978 FJ40
    TRD wheels, 6112s/5160s, 285/70/17 KO2s
    Pretty basic stuff, but I dig it ... 285/70/17 KO2s, sema bronze wheels, 6112/5160. Had a CMC done by the one and only @GHOST SHIP, which turned out great (if you're anywhere near Burbank and need work done, he's the guy!). Super happy with it ... rides great, no rubbing yet (even with mudflaps).
  7. Mar 3, 2023 at 5:22 PM
    #3087
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Looks great. I have the same 4Runner sema wheels, 285/70s and no cmc or rubbing anywhere. I still have the oem mudguards. So why a cmc? Did you really need one?
    GSager78[QUOTED] likes this.
  8. Mar 3, 2023 at 8:55 PM
    #3088
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Looking awesome man!
  9. Mar 4, 2023 at 5:11 AM
    #3089
    GSager78
    SoCal
    Thanks! Might not of needed it, but I was getting the lift done by a local guy on here that does super clean CMCs, so figured why not. I was rubbing on the front mudflaps without the lift, but it's all clear now.
    VaToy[QUOTED] likes this.
  10. Mar 4, 2023 at 5:35 AM
    #3090
    rnmnzii
    rnmnzii Active Member
    rene
    taco
    285/70/17 with Eibach Stage 1 Lift, zero rub
    H4I2G0H, andthen, T378 and 2 others like this.
  11. Mar 4, 2023 at 9:33 PM
    #3091
    INTERRUPTOR22
    INTERRUPTOR22 Well-Known Member
    Port Hueneme, CA
    2017 tacoma TRD off road 4x4 Magnetic Grey
    BakFlip tonneau cover. Rexing front and rear dash camera. Leather seat covers Dessert Does it seat jackers TRD Pro Front grille OTT ECU 285/70/R17 Falken Wildpeaks AT3W. Methods 703 Bronze 0 offset Fox 2.5 with Remote Resi with DSC adjusters front and rear ICON Tubular UCA Cab mount chopped Superbump bumpstops with Ubolt Flip kit Meso customs interior black out kit with LED white/red map light and dome light and TRD shift knob with hidden buttons Kustom 45 headlights with rgb halo ring.
    285/70/R1720230304_164548.jpg :mudding:
    andthen and TacoTime55 like this.
  12. Mar 5, 2023 at 7:58 AM
    #3092
    G8tor
    G8tor Well-Known Member
    Gainesville
    2022 Tacoma trail edition
    285/75/16 Nitto ridge grapplers. Stock rims
    andthen and 98_3RZ_NIC like this.
  13. Mar 5, 2023 at 12:28 PM
    #3093
    Omegastu
    Omegastu Well-Known Member
    Mid Tenn
    2021 Cement TRD Sport DCSB
    Truck looks great. What kind of lift do you have?
  14. Mar 5, 2023 at 2:40 PM
    #3094
    2Shoes
    2021 TRD Off-Road
    At the time I was just running 2" spacers, but I've since swapped out the struts for Bilstein 6112's and 5160's
    andthen, banditcamp and TacoTrigger16 like this.
  15. Mar 5, 2023 at 2:43 PM
    #3095
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    what setting are your 5100’s at? How’s the ride up front?
  16. Mar 6, 2023 at 7:31 PM
    #3096
    Nutts99
    Nutts99 Member
    Brian
    2019 Toyota Tacoma
    Bit of a double post with the MGM thread, but here is the truck stock with 285/70R17 and after install of my Bilstein lift.
    Tires: Wrangler Ultraterrain AT 285/70R17
    Wheels: Race Relation RR5-V 17x8.5
    Lift:
    • Front is Bilstein 6112 set at 11/9, SPC UCA's (maxed forward along with LCA alignment adjusters), Wheelers Superbumps, ECGS bushing replacement.
    • Rear is Icon RTX leafs set at #1, Bilstein 5160's, and Wheelers Superbumps with the u-bolt flip.
  17. Mar 6, 2023 at 7:43 PM
    #3097
    98_3RZ_NIC
    what lift!?
  18. Mar 7, 2023 at 6:22 AM
    #3098
    evandrew01
    evandrew01 New Member
    21' Tacoma OR 4x4
    You running aftermarket UCA's?
  19. Mar 7, 2023 at 7:12 AM
    #3099
    Madimor
    Madimor Well-Known Member
    Scott
    Anchorage, AK
    2017 MGM TRD Off Road
    265/75/16
    Tacoma Mty.MX and andthen like this.
  20. Mar 7, 2023 at 9:50 AM
    #3100
    G8tor
    Gainesville
    Just spacers up front blocks in the back for now.
