Show your 285/75/16 and 285/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spewed, Jan 14, 2017.
  1. Sep 18, 2024 at 4:39 PM
    #3461
    Its_me_Jaybird
    Its_me_Jaybird Member
    Jay
    Birmingham, Al
    Thanks! They are Method 315's 17x9 -12/4.50"
    FWIW the center caps that come with the wheels are black plastic but I swapped them for the ones shown that have the aluminum with black plastic center.
  2. Oct 20, 2024 at 9:47 PM
    #3462
    MuleyCrazy13
    MuleyCrazy13 Well-Known Member
    Stock uca’s?
  3. Oct 21, 2024 at 5:48 AM
    #3463
    Stinky8390
    Stinky8390 From Planet Mars
    Mars occasionally on Earth
    2019 TRD OR Super White DCSB
    285/75R16 Falken R/T 01s
    Vision 351 / 0 offset
    Billy 6112s 650lb springs 6/5 setting for lean
    OME UCAs
    Camburg Cam bolts
    5160s
    OME EL112R springs
    XT u-bolt flip kit
    XT Bump Stops
    Extended Stainless brake lines
    banditcamp likes this.
  4. Oct 21, 2024 at 6:36 AM
    #3464
    IsaacFrancis
    IsaacFrancis New Member
    2020 mgm Off Road
    Yes sir
  5. Oct 21, 2024 at 7:24 AM
    #3465
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    What are your thoughts on those Falken Rts? I was really interested in them until I saw they are pretty heavy in the 285s.
  6. Oct 21, 2024 at 8:24 AM
    #3466
    Stinky8390
    Yessir they are heavy at 70lbs each wheel! So far I can say i have a good amount of time on these tires on and off road moderate FS roads and pavment pounding. I got these mounted on May 1st earlier this year. I logged 18K on them so far!!!!! I drive a lot! Very well mannered and grippy off road on light loose rocks and when aired dwn to 15psi they still held well even with my non beadlocked wheels. BUT...... wet weather on road traction is kinda lack luster. Just watch your speeds on corners and you'll be fine. But 18K since May I freakn love these tires! No real complaints from me.
    banditcamp[QUOTED] likes this.
  7. Oct 21, 2024 at 8:55 AM
    #3467
    banditcamp
    daniel
    Thank you for the information. I'll probably stick with my Mickey Thompson Baja legend. They are only 56 pounds and have been great in every situation.
    Stinky8390[QUOTED] likes this.
  8. Oct 21, 2024 at 5:30 PM
    #3468
    Lunar.tacoma
    Lunar.tacoma Semi-Pro Mallcrawler
    Kyle
    Oceanside, CA
    2023 Lunar Rock Trail Edition
    Bilstein 6112 (Front) Bilstein 5160 (Rear) 285/70r17 KO2 Stealth Custom Series F5 (Matte Bronze)
    285/70r17s on some SCS F5's
  9. Oct 21, 2024 at 7:19 PM
    #3469
    Stinky8390
    This is including the wheel and tire combo. I didn't exactly do a super scientific weighing of the wheel and tire on a proper scale. I weighed myself and then had my two buddies at work hand me my wheel and read the scale again. If I rmbr I had a difficult time holding a big ass heavy wheel n tire. It was around 70-75lbs but maybe this time I'll weigh my spare wheel instead!
  10. Oct 21, 2024 at 7:25 PM
    #3470
    Stinky8390
    So according to Discount Tire's website, a E1 load range for 285/75R16 is 65lbs just the tire.
    Visions website states their Flow 351 16in wheel is 21lbs.
    So 86lbs is roughly how much my wheel and tire should weigh.
  11. Oct 21, 2024 at 8:01 PM
    #3471
    Lunar.tacoma
    Kyle
    Oceanside, CA
    In case anyone is wondering
    SCS F5s 17x8.5 -10mm offset are like 22lbs and the 285/70r17 KO2s in C load weigh 51lbs. I think I only gained like 5lbs per wheel going up between the stock set up.
  12. Oct 22, 2024 at 4:56 AM
    #3472
    banditcamp
    daniel
    FN five star 16x8 -25 is a little less than 19 pounds. Mickey Thompson Baja Legend exp 285 75 16 is 56 pounds. So I'm around 75 pounds per corner.
    Jpalafox and Stinky8390 like this.
  13. Oct 22, 2024 at 7:06 AM
    #3473
    Rsatch
    Rsatch Well-Known Member
    21 Army Green TRD OR 6MT
  14. Oct 22, 2024 at 9:27 AM
    #3474
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    Those tires look humongous!
    Rsatch[QUOTED] and Stinky8390 like this.
  15. Oct 22, 2024 at 11:08 AM
    #3475
    Stinky8390
    Those wheels are nasty sick! Freakin dope a$$ wheels. I'll have nice wheels someday......
    Rsatch[QUOTED] likes this.
  16. Oct 22, 2024 at 4:03 PM
    #3476
    Rsatch
    I think because it doesn't have much lift. Fox Pro’s with Eibach springs and 1” rear block.
    71tattooguy and xp0nex[QUOTED] like this.
  17. Oct 22, 2024 at 4:06 PM
    #3477
    Stinky8390
    Your rig looks just as tall as mine
  18. Oct 23, 2024 at 10:43 AM
    #3478
    AGTaco22
    AGTaco22 Well-Known Member
    Warren
    RVA
    2022 Tacoma TRD OR
    Nice truck! How much lift are you running up front, 2"? Thanks!
    Mcflyfoo likes this.
  19. Oct 23, 2024 at 11:03 AM
    #3479
    Rsatch
    Yes right at 2” over stock.
    Stinky8390 likes this.
  20. Oct 26, 2024 at 3:04 PM
    #3480
    Van_island
    Van_island Well-Known Member
    Isaac
    2019 taco
    How much lift do you have ? Did you have rubbing problems?
