Show your 285/75/16 and 285/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spewed, Jan 14, 2017.
  1. Aug 23, 2018 at 6:14 PM
    #821
    OR_MG_TRD_SEA
    OR_MG_TRD_SEA New Member
    2016 MG tacoma OR
    Yup in Puyallup now lol
    I just have 2.5" lift no rubbing at all..
    These wildpeaks are awesome!
  2. Aug 23, 2018 at 6:36 PM
    #822
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    They look great! Maybe I'll see you around town.
  3. Aug 23, 2018 at 7:56 PM
    #823
    Tim801
    Tim801 Well-Known Member
    Tim
    Covina
    2018 Tacoma trd-off-road 4wd
    Cst suspension UCA, dirt series coilover, dirt series rear 2.0 shock, 1.5” aal. Method 701 series rims with Toyo open country RT’s 285/70r17
    What offset wheel should I be looking for? Going to run 285/70r17 M/T (KM3’s)
    On a uniball upper, coilover, leaf springs and remote resi in the rear
  4. Aug 23, 2018 at 8:13 PM
    #824
    Shwankin407
    Shwankin407 Well-Known Member
    Casey
    Orlando,FL
    17 TRD OR 4x4 6MT
    How is the ride with the 886's on the slimline? I have the same bumper setup otw.
  5. Aug 23, 2018 at 8:21 PM
    #825
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    Its a little stiff but prefer that over being soft and bouncy. I have the Smitty x20 in it and full set of steel skids. I've thought about grabbing some 888's to try out but I'm too cheap to pull the trigger. I'll probably keep it as is until I'm ready to do a full over hall to ADS or King. I also plan on changing out the front bumper to a full one but most likely aluminum, some day in the not so near future. I think the next big purchase will be a re-gear to get some low end power back in the truck with the weight I carry.
    Shwankin407[QUOTED] likes this.
  6. Aug 24, 2018 at 6:53 AM
    #826
    navybluechief
    navybluechief Well-Known Member
    Kevin
    2018 TRD Sport MT ACLB
    Just picked it up this week. Happy to be in the club. What an incredible vehicle we have the privilege to own and drive. 3" lift on 285/70R17 KO2s. Lovin it! 20180822_145300.jpg
  7. Aug 24, 2018 at 12:11 PM
    #827
    PAKraig
    PAKraig Well-Known Member
    Kraig
    Central Pennsylvania
    2017 DCSB 4x4 in Silver Sky
    OME suspension and 285/70R17 BFG KO2s
    Any suggestions/advice on tire pressure for 285/70R17s load range C for perfect tread-wear? I'm running 35 on mine and don't want to ruin them prematurely.
  8. Aug 24, 2018 at 12:32 PM
    #828
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    What does the sidewall say?
  9. Aug 24, 2018 at 1:28 PM
    #829
    SuperBad
    Dallas, TX
    Truck stuff
    Chalk test it to find the right psi for your truck. If you don't know what that is Google it.
    Gettin Lost likes this.
  10. Aug 24, 2018 at 5:52 PM
    #830
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    What’s everyone running for a spare tire besides the guys with bed and bumper mounted spares.
    I’m aware of mods needed to cram a 285/70R17 in stock spare location. Just a lot of salt mud and rock rash up north so wouldn’t want to have a brand new SCS wheel under there. Have found many used 285s locally and was going to put one on the stock rim but that would rub the front UCA if I flew out a front tire?
  11. Aug 24, 2018 at 10:40 PM
    #831
    Sr5guy777
    Sr5guy777 Member
    Garrett
    Grey 2018 sr5
    Trd pro grille
    I have 285/75/16 with a 3 inch spacer up front with total chaos UCA and two inch block in the back. My rims are method nv with BFG ko2 I went cheap just to get a lift and the tires I want but plan on saving for some Fox 2.5s
  12. Aug 25, 2018 at 5:58 AM
    #832
    TexasGunGuy88
    TexasGunGuy88 Insta: @midnite_taco
    Burleson , TEXAS
    2017 Tacoma SR5 4x4 SR5sMatter
    6112 / 5160's w/ DAKAR Heavy 285's KO2
  13. Aug 25, 2018 at 6:49 AM
    #833
    cnstaco
    cnstaco Well-Known Member
    CO
    17 DCSB OR
    What’s your caster set to and what bump stops are you running?
    SuperBad[QUOTED] likes this.
  14. Aug 25, 2018 at 7:02 AM
    #834
    SuperBad
    Dallas, TX
    Truck stuff
    Stock bump stops. First shop set it to almost 6 and it drove like crap on the highway, it was actually kinda scary to drive with the caster that high. After a second alignment by a shop that actually knows what they are doing the caster is a little over 3.
  15. Aug 25, 2018 at 7:13 AM
    #835
    cnstaco
    CO
    17 DCSB OR
    I’m at 3.5 with wheelers super bumps and a similar lift(cmc and plastic trim). I can get it to rub even when wheeling. 4.5” back spacing and 0 offset?
  16. Aug 25, 2018 at 7:14 AM
    #836
    cnstaco
    CO
    17 DCSB OR
    Nice truck btw.
    SuperBad likes this.
  17. Aug 25, 2018 at 7:30 AM
    #837
    SuperBad
    Dallas, TX
    Truck stuff
    I'll have to see how it does when i'm out wheeling. I've only been out once with the new tires so far and that was before the second alignment. I have a wheeling trip planned in a month so I'll see how it does and figure out what else needs to be done.
    Thanks
  18. Aug 26, 2018 at 7:22 AM
    #838
    DavidT
    DavidT Well-Known Member
    Pensacola, FL
    Horsepower decals
    What lift you running
  19. Aug 29, 2018 at 1:23 PM
    #839
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    Been thinking about saying f'it and going with the puck+block set up... any complaints?
    Biggums likes this.
  20. Aug 29, 2018 at 1:26 PM
    #840
    Biggums
    Biggums Well-Known Member
    Jade
    SoCal
    Do you off road at all or often? If so, I wouldn't recommend it. It it's just for show and you do a majority of street driving, then yes.
    GillyLink likes this.
