Show your 285/75/16 and 285/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spewed, Jan 14, 2017.
  1. Nov 7, 2019 at 12:29 PM
    #1441
    Shawnj0301
    Shawnj0301 Well-Known Member
    2016 MGM TRD Off-Road
    285/70 at3w
    ClassyTacos and VR812 like this.
  2. Nov 7, 2019 at 4:36 PM
    #1442
    Canadian Joe
    Canadian Joe Well-Known Member
    Joe
    Ontario
    2016 Tacoma trd off-road ,access cab,MT
    SCS rims 285's OME lift
    here's a couple more
  3. Nov 8, 2019 at 5:10 PM
    #1443
    RJwildcat
    RJwildcat Well-Known Member
    RJ
    2021 and 2025 Tacoma Off Road DCLB 4WD
    Nice truck. Quick question for you. I just got the same tires (KO2s and size) and noticed them a lot noisier than my takeoffs (ko2s 265/70/17). How is your road noise?
  4. Nov 8, 2019 at 6:08 PM
    #1444
    maximum
    maximum Well-Known Member
    Thank you. I have no idea how quiet the stock tires are. Replaced my factory wheels/tires with 275/70/17 hankook dynapro at 10 miles. Comparing the two, the K02 is just a tad louder. Honestly, I don’t even notice the road noise. E
  5. Nov 11, 2019 at 11:41 AM
    #1445
    NaluTaco
    NaluTaco No Ka Oi
    JIMI
    OAHU
    2016 TACOMA 4X4 SPORT
    TOYTEC BOSS COILOVERS, 1.5 BLOCK ON REAR AXLE, 275-75-17 BFG KO2, CUSTOM TONNEAU COVER
    Do you have a 1" body lift on your taco?
  6. Nov 11, 2019 at 12:23 PM
    #1446
    Sungod
    Sungod Well-Known Member
    St Augustine
    16 or 17 refers to the wheel diameter. Obviously a 16" tire mounts on 16" wheel and same for a 17. The difference in the over all height is in the calculations. A 33x11.50x16 will be the same height as a 33x11.50x17. Reason being is that you are measuring the actual dimensions. Euro-metric tires started in the 60s and replaced the alpha numeric sizing of the 70s. This has essentially become the tire measurement standard across the globe. You have to do some simple math to determine the actual size of the tire. The first number in a 285/70R 17 represents the section width. It is 285mm from shoulder to shoulder. The section height or sidewall height is determined by the second number which is represented as a percentage of the section width. So to get the sidewall height you multiply the section width in this case 285mm by 70%. That gives you 199mm of side wall. Well that really doesn't do you a lot of good because the wheel diameter is measure in inches.
    You can start all over with good old US measurements. Let's just take that 285 and divide it by 25.4 that will give us a section width in inches. You should get 11" of width. These numbers are nominal so we just round it. You then take that 11" and multiply it by 70%. That gives you 7.85 of sidewall. Well you need to double that since you have two and you might as well add your 17" wheel diameter and you end up with 32" of height. So your 285/70R 17 is really a 33x11x17. Switch that to a 285/70R 16 and you end up with a 32x11x16.
    Just to confuse this even more. The difference in lift you get from a 17 vs a 16 is a half inch because your radius is 1/2 the diameter.
    oldirtywalker likes this.
  7. Nov 11, 2019 at 12:41 PM
    #1447
    akmetal
    akmetal New Member
    2020 TRD OR DCSB Cement
    Too many good examples in this thread. Someone told me 285/75/17 would fit on stock suspension but that's obviously not the case
  8. Nov 14, 2019 at 7:50 PM
    #1448
    SAPR53
    SAPR53 Well-Known Member
    2019 TRD Offroad
    King 2.5" Ext resi with compress adjust Front and Rear ICON RXT Leafs ICON Tubular Delta Joint UCAs Xenon HD LED Low Beam Swap Baja Sports Wide Cornering Fogs Interior LED AVS In-Channel Extang Solid Fold 2.0 Tonneau
    Just got some Nitto Ridge Grapplers and SCS Stealth 6's installed today, zero rubbing, except on the mudflaps which had to go bye bye.
  9. Nov 26, 2019 at 12:41 AM
    #1449
    @Dustyblacktaco
    @Dustyblacktaco New Member
    Joe
    17 Tacoma trd off road
    Screenshot_20191206-102315_Instagram.jpg 2017 tacoma trd offroad
    Toyo open country m/t 285 75 17
    Pro comp la paz 2 tone rims
    Sway a way 2.5 coil overs in the front with 2.0 in the rear
    Built right uca
    Duro bumps front and rear with a u bolt flip kit
    Ome medium leaf springs
    Cmc with some extra trimming
    Daddy_Firebird and VR812 like this.
  10. Nov 26, 2019 at 7:01 AM
    #1450
    curt85
    curt85 Member
    2017 Tacoma TRD Sport
    Do you have any sort of leveling kit here or just the bigger tires?
  11. Nov 26, 2019 at 12:10 PM
    #1451
    @Dustyblacktaco
    Joe
    Yeah the sway a way 2.5 coil overs in the front and the 2.0s in the rear
  12. Nov 29, 2019 at 7:05 AM
    #1452
    1taco2motos
    1taco2motos Well-Known Member
    Colorado
    19 DCSB mgm TRD OR 6MT
    Oh man, those grey rays look perfect on that red truck. Nice!
    Canadian Joe[QUOTED] likes this.
  13. Nov 29, 2019 at 7:11 AM
    #1453
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    Lift?
  14. Nov 29, 2019 at 7:41 AM
    #1454
    ZubZub
    ZubZub Well-Known Member
    Phoenix, Az
    2018 Cement Tacoma TRD Sport 4X4
    ReadyLift 3” Front 1” Rear SST Lift Kit 285/70/17 American Racing Wheels with Toyo AT 33”
  15. Nov 29, 2019 at 12:51 PM
    #1455
    Willtaco
    Willtaco I Love Tacos!!
    Will
    SoCal LA
    18 Tacoma TRD OR 4x4 DC/SB
    •Xenon LED lights •EGR channel window visor/Hood Protector •total chaos bed stiffener •TRD cold air intake. •30” Rough country light bar •King’s suspension and springs •Camburg UCA/ replaced with JBA UCA •Method wheels •285/70/R17 Falcon wildpeak •slimeline bumper •All pro rock sliders •All pro skid plate •winch Plus a few more goodies and That’s all I have to say about that..
    No. 3”
    NaluTaco[QUOTED] likes this.
  16. Dec 8, 2019 at 1:18 AM
    #1456
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    I know this spot :cheers: where did you buy your ome aal? 20190904_000451-01.jpg285/70 here
  17. Dec 8, 2019 at 2:05 AM
    #1457
    Crhudson
    Crhudson Member
    2017 Tacoma SR dlcb 4x4
    285/70/17
    Jasonstacoma, DevilTaco4 and ERod27 like this.
  18. Dec 8, 2019 at 3:25 AM
    #1458
    Canadian Joe
    Joe
    Ontario
    We did a job in St Catharines a couple of years ago and stopped there on the way one day,
    I get my OME stuff at Just Jeeps ,:anonymous:
    sorgon82[QUOTED] likes this.
  19. Dec 19, 2019 at 11:30 AM
    #1459
    potthoffw
    potthoffw Well-Known Member
    Will
    Austin, TX
    2017 TRD OR
  20. Dec 19, 2019 at 2:36 PM
    #1460
    Goncalves_Taco
    Goncalves_Taco Well-Known Member
    2017 Black Tacoma TRD Sport
    285/70/17 w/ the 4-Runner TRD rims on BFG KO2's
    arnette64, VR812 and TacoMan408 like this.
