Show your 285/75/16 and 285/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spewed, Jan 14, 2017.
  1. Jan 4, 2020 at 5:33 PM
    #1481
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    maybe they just drive in a straight line?
  2. Jan 4, 2020 at 5:39 PM
    #1482
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    I very much so agree.
    GillyLink likes this.
  3. Jan 4, 2020 at 5:40 PM
    #1483
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    A lot depends on tire offtset and what not. I couldn't figure out if I would rub or not with -12 offset and 4.53 backspacing...I opted to get the CMC done first, then got my tires put on and only had to trim a little plastic, nothing bad. Too many people say no rub, tons of rub..etc. Too many factors to determine if I would rub or not (without CMC).
  4. Jan 4, 2020 at 5:49 PM
    #1484
    Anderson5290
    Brandon
    Corona, Ca
    I have stock wheels with 1 inch spacers due to my spindle gussets. There is no way possible if you have the factory bump stops/ factory amount of up travel it won’t rub somewhere. I get the fact that some rub more than others but there will always but some rubbing with big tires. Maybe some people don’t notice. I mean I was driving down the freeway the other day and a guy in a Corolla was next to me, his tire was literally bouncing off the ground and I could see the guy fuc*ing shaking and he didn’t have a clue haha.
  5. Jan 4, 2020 at 5:54 PM
    #1485
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Looks so good. Love the gunmetal wheels.
  6. Jan 5, 2020 at 7:18 AM
    #1486
    Tacotwo
    Tacotwo Active Member
    Hey, no I didn't run hub centric spacers or the rings. No issues so far.
  7. Jan 5, 2020 at 7:25 AM
    #1487
    Socialrafa
    Socialrafa Well-Known Member
    2020 Sport 4x4 DCLB cement
    What kind of shell is that on your truck?
    Willtaco likes this.
  8. Jan 5, 2020 at 8:00 AM
    #1488
    Canadian Joe
    Canadian Joe Well-Known Member
    Joe
    Ontario
    2016 Tacoma trd off-road ,access cab,MT
    SCS rims 285's OME lift
    It's a custom ordered ARE DCU , you will not find that model I don't think anymore on their website . When I ordered mine there was no photos on their website only a written description. I am pretty sure they will still make them though .
  9. Jan 6, 2020 at 5:13 PM
    #1489
    SubieRuby
    SubieRuby Well-Known Member
    kevin
    Northern VT
    19 Tacoma TRD Offroad
    Thanks! Yeah seriously no rub, even with a flex test. It is because I have a skinny wheel with a high offset. 17x8 +4. My old truck rubbed bad on the same tires with a 16x8 -25 and 3inch lift.
  10. Jan 8, 2020 at 11:41 AM
    #1490
    N8Dizzle
    N8Dizzle Well-Known Member
    Nate
    Sumner
    2020 AG TRD PRO MT
    Cooper S/T Maxx 255/85/16
    What lift are you running?
    fiftyxp likes this.
  11. Jan 8, 2020 at 11:42 AM
    #1491
    Bunkin
    Bunkin Member
    2007 Tacoma
    I'm looking at going with new Nitto Ridge Grapplers. Trying to figure out if I should do 265 70 17 or 285 70 17. Wheels will be +0* 8.5" wide. I'm planning to do 5100's on the front gaining around 2" and maybe some rear suspension but not decided yet. Will I clear the 285s???
  12. Jan 9, 2020 at 9:18 PM
    #1492
    TheTurk
    TheTurk Well-Known Member
    Kendrick
    California, Central
    2019 TRD OR
    CMC?
  13. Jan 9, 2020 at 10:14 PM
    #1493
    DevilTaco4
    DevilTaco4 Well-Known Member
    Folsom, CA
    2017 SR Access 5MT
    yes
    TheTurk[QUOTED] likes this.
  14. Jan 10, 2020 at 5:36 AM
    #1494
    Sungod
    Sungod Well-Known Member
    St Augustine
    Are those the PTR20-35110-G4 wheels? I have been wanting those badly, but they seem to run about $300 more than the regular gun metal wheels with the red TRD center caps.
  15. Jan 11, 2020 at 4:43 AM
    #1495
    SubieRuby
    kevin
    Northern VT
  16. Jan 11, 2020 at 8:58 AM
    #1496
    CHOE4X4
    CHOE4X4 New Member
    WInston
    2019 Cement Tacoma TRD OR
    Are you running wheel spacers?
  17. Jan 11, 2020 at 10:57 AM
    #1497
    Anderson5290
    Brandon
    Corona, Ca
    yes bora 1 inch wheels spacers front and rear. I have JBA HD uppers control arms and TC spindle gussets so they were absolutely needed.
  18. Jan 13, 2020 at 7:40 AM
    #1498
    Sungod
    St Augustine
    Kolter45 likes this.
  19. Jan 13, 2020 at 8:38 AM
    #1499
    tacodnr
    tacodnr Well-Known Member
    They have a 4mm back spacing as well
  20. Jan 13, 2020 at 11:02 AM
    #1500
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    idk how they do it either I went and took measurements with my 265/75/16s and I would rub all over the place, and by my guesstimates it looks like a lift would make it worse.
