Show your rims and tires
Discussion in 'Wheels & Tires' started by MedlinAround, Apr 9, 2011.
  1. Mar 30, 2019 at 9:48 PM
    #961
    kennethalan
    kennethalan Well-Known Member
    Michigan
    Inferno TRD Off-Road 4x4
    King Total Chaos Dakar SCS Ray 10 315/75-16 STT Pro
  2. Mar 31, 2019 at 7:25 AM
    #962
    nics574
    nics574 Active Member
    Jared
    2017 DCSB sr5 4x4 quicksand
    Bfg k02, air dam delete, method nv 305s on the way!
    kennethalan[QUOTED] likes this.
  3. Mar 31, 2019 at 7:25 AM
    #963
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
  4. Apr 11, 2019 at 1:13 PM
    #964
    S550ilver
    S550ilver Well-Known Member
    Bartlett, TN
    2019 Tacoma Double Cab TRD Off-Road
    ICON Stage 5 Lift, 18x9 Fuel Shok, Nitto Ridge Grappler 285/65/18 tires
    What brand size are these? And what is the width and offset? I may look into these for mt 08 2WD. They look great!
  5. Apr 11, 2019 at 2:06 PM
    #965
    Babybluetaco
    Austin
    09 5 lug
    There ion wheels. They don’t directly fit. I had to sand the caliper a hair and I mean a hair to clear. There 16x8 they only come in one offset. 31x10.50-16
  6. Apr 11, 2019 at 2:08 PM
    #966
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    285x70x17 Pirelli Scorpion MT. 17x8.5 Procomp lapaz. 4.5 BS 0 offset.
  7. Apr 14, 2019 at 7:32 AM
    #967
    Poky
    Poky Member
    Gio
    Va
    2013 tacoma base
    Stock
    Here is mine with MSR 16 x 7 and the tires are Mastercraft
    magicroy and rblalliance like this.
  8. Apr 14, 2019 at 4:48 PM
    #968
    slow TURD I4
    slow TURD I4 Well-Known Member
    SD
    2018 DCSB 2.7
  9. Apr 28, 2019 at 9:00 PM
    #969
    i/o
    i/o Active Member
    Richard
    San Antonio Texas
    2013 Limited Double Cab PreRunner Pyrite Mica
    Nitto Ridge Grapplers 285/70/17 with Pro Comp 69 17" -6 offset
  10. Apr 30, 2019 at 7:11 PM
    #970
    reefclimber
    reefclimber Well-Known Member
    Jose
    NC
    14 TRD Sport DCLB 4x4
    Predator step rails, remote-start
    Im looking at getting some 285 tires. Do you know if they will fit stock? What did you have to do?
  11. Apr 30, 2019 at 7:17 PM
    #971
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    16x8 -12 offset SCS Ray10 Matte Grey
    285/70R16 Nitto Trail GrapplerIMG_20181027_134545.jpg IMG_20181027_134522.jpg
    Kolter45, Tacooffroad and Toddaz like this.
  12. Apr 30, 2019 at 7:26 PM
    #972
    Snobord28
    Snobord28 Member
    2014 Tacoma prerunner
    C9D96DE8-20BB-4A6D-A8CF-024CBB85636C.jpg Fuel boost rims on nitro terra grapplers g2 275/65/r18
    Tacooffroad and RocRan26 like this.
  13. Apr 30, 2019 at 8:22 PM
    #973
    Toddaz
    Toddaz Member
    2017 Inferno Trd Off Road 4x4
  14. Apr 30, 2019 at 8:23 PM
    #974
    Toddaz
    Toddaz Member
    I have the same wheels but not sure how much lift I will need to run same size tires as you. How much lift do you have and is there any rub? TIA
  15. Apr 30, 2019 at 9:31 PM
    #975
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    So these are 32 inch tall 285s. They're the same height as 265s but a little wider. If you have 265s right now you may just need a little bit more plastic trimming, if any. If you want to run 33 inch tall 285s like most people on TW, you'll have to do a CMC and some more trimming to fit at "full stuff."
    I have 5100s set at 1.75 inches in front, stock height rear. I had to trim quite a bit of plastic just to fit 265/75R16 M/Ts at full stuff, and these didn't rub any worse than 265s for me.
    Toddaz[QUOTED] likes this.
  16. May 1, 2019 at 10:05 AM
    #976
    Tacooffroad
    Tacooffroad Member
    South Saint Paul, MN
    2023 Tacoma SR5 Double Cab
    Currently Stock with the exception of BFG KO2’s. 265/75R16
  17. May 1, 2019 at 7:09 PM
    #977
    Dawgs1125mbsr
    Dawgs1125mbsr Well-Known Member
    TRD PRO Wheels. Wrangler A/T Adventure tires
    Kolter45 and RocRan26 like this.
  18. May 1, 2019 at 7:11 PM
    #978
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Got my winter wheels taken off the truck today, so while I was at Firestone for it, I asked them to mount the tires on the SEMA wheels that I picked up from the TRD sale last month.
    Kolter45 likes this.
  19. May 1, 2019 at 7:30 PM
    #979
    Toddaz
    Toddaz Member
    Thanks. I appreciate the info . Nice truck.
  20. May 5, 2019 at 1:22 AM
    #980
    TacomaOC714
    TacomaOC714 Well-Known Member
    2015 Tacoma TRD OR 4x4 silver sky metallic
    @SinCityTaco22 Are those the Six Shooters in Gunmetal fron FN Wheels?
