Showing ABS & Emergency Brake light?!
Discussion in 'Technical Chat' started by ChamYota, Sep 29, 2012.
  1. Oct 3, 2012 at 9:14 AM
    ChamYota
    ChamYota [OP] Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    I'll just go to a AutoZone or something and have them pull codes so i know whats what.
    I'll report back after ^ has been accomplished.
    Thanks for the tip Mike
    -Cam
  2. Oct 3, 2012 at 9:18 AM
    Tacolover443
    Tacolover443 Well-Known Member
    Kyle
    Haverford, PA
    07 TRD OR DCSB BSP
    Satoshi, color match grill, 2 Hella 500ff's, rear TSB, yellow "Taco", OEM all-weather floor mats, OEM TRD seat covers, Ultra-Gauge, bed linered rear bumper, Plasti-dipped rims, DuraTrac's,
    There are still codes being thrown, the Scanguage just cant pick it up. Go to Autozone, its free and they can clear the codes. My brothers Snap-on code reader has picked up things that my Scanguage didn't.
  3. Oct 3, 2012 at 9:21 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    do they both still turn on every time you crank the truck?. . . every once in a blue moon i'll turn on my truck and those lights turn on. i turn it off, crank it back up and they're gone. :cool:
  4. Oct 3, 2012 at 9:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Did you pop the cover when you checked the fluid level?
  5. Oct 3, 2012 at 11:09 AM
    ChamYota
    Cam
    Ah this must be the case. After my lab (4:30) i'll run by autozone
    no :( i've cranked up/off about 8 times since friday
    Yep. Its clear right? its on the F which must be full :cool:
  6. Oct 3, 2012 at 4:46 PM
    ChamYota
    Cam
    So I went to autozone. No codes popped up. We diconnected the battery and nothing. I'll have to take her to the stealership :(
  7. Oct 3, 2012 at 4:57 PM
    Tacoma Mike
    Southern Maine
    Yeup... Most places like autozone only have code readers for the engine ecu.
  8. Oct 3, 2012 at 6:16 PM
    ChamYota
    Cam
    I suspected as much unfortunately. But every option except for the stealership has been used Friday she's going in there....
  9. Oct 9, 2012 at 12:22 PM
    ChamYota
    Cam
    49$ to check for codes. Ridiculous
  10. Sep 4, 2013 at 1:21 PM
    [eric]
    [eric] Well-Known Member
    Eric
    Bend, OR
    2005 Tacoma TRD OFF Road
    What were the results or solution to this problem? The same thing is happening to my truck now
  11. Sep 4, 2013 at 2:45 PM
    ChamYota
    Cam
    Oh, i never got it scanned. it's been litterally a year now and nothing's changed, it behaves normally and the brakes hasnt acted up once. I just ignore it and drive normally. Eventually i'll get it checked out but for now i'll pocket the 50$ and drive on.
  12. Sep 6, 2013 at 7:18 AM
    pcabinatan
    pcabinatan Well-Known Member
    Avondale, Arizona
    K&N Intake, 35w 6K HID's, Plastidip badges
    did you check the harness that plugs into the ABS sensors on the brakes themselves?
    I was driving to Payson a week after i bought my truck and those lights turned on andwhen i got to my area i was going crazy looking for a bad fuse, fluid levels etc. Luckly i decided to just go under the truck and my right rear harness had come undone, plugged it in and the lights turned off
  13. Sep 6, 2013 at 8:14 AM
    ChamYota
    Cam
    you know what the dealership said something about a loose harness....
    After i get out of class, im gonna go under my truck and search for said harness. Where should i look?
  14. Sep 6, 2013 at 8:26 AM
    BamaToy1997
    Bill
    Navarre, FL
    Not trying to sound like an ass here, but why do you think that $49 is a ridiculous charge? You come to my shop, I take my time to connect my $2000 scan tool to your vehicle and read the codes. Then take my time again to explain these codes and suggest where to go from this point. Should I just simply do that for free? See, those scan tools that the parts stores have are like mentioned, only designed for engine codes. They are cheap, simple code readers. The ABS and body system codes require a much more expensive tool for this. I am sorry, but for a new customer that I have no idea if they are going to want the repairs done or simply want me to tell them the codes, or clear them, I am charging you fair shop rate and time. Nothing ridiculous about that. you wouldn't do YOUR job for free, would you?
    KenpachiZaraki likes this.
  15. Sep 6, 2013 at 8:39 AM
    #35
    ChamYota
    Cam
    I think it's ridiculous simply because i didnt want to pay that price at that time(over a year ago). I have since ignored the lights and to the advice of a member who had the same problem, i am going to check to see if anything got loosened. If this happens to be the case, then i just saved a tanks worth of gas money and am one happy owner.
    To be fair, you made great points, i admit i am a bit naive when it comes to this stuff as i want to be able to do things on my own, just the kind of kid i am. I am aware that the code readers that the dealer had may have very well pointed to the issue immediately and resolved it for the fee+additonal charges. I said screw it at that time and decided to let it ride. I've had ZERO problems whatsoever with my brakes, and the ABS system, maybe in part that my truck is a pavement princess at the moment and the ABS has never had to do it's job.
    I will check into the harness solution today and if that solves it cool, if not, then i'll keep on trucking.
    To answer your question, i wouldnt do it for free. I already admitted my faults. :)
    thanks for your advice though,
    If you did sound like an ass, it's none taken. Such is life that sometimes you gotta be spoken to in that manner.
  16. Sep 6, 2013 at 9:44 AM
    #36
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    Had the same lights come on and it ended up the tire rubbed a whole in that wire. Soldered them back together.
  17. Sep 6, 2013 at 9:48 AM
    #37
    ChamYota
    Cam
    where is this wire?
  18. Sep 6, 2013 at 9:58 AM
    #38
    whahahajr
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Sorry it runs from the frame to the tire abs sensor. On both front wheels. I think a new wire was not bad priced but the sensor was expensive. But it was just 2 wires in the loom and an easy fix.
  19. Sep 7, 2013 at 5:53 AM
    #39
    pcabinatan
    Avondale, Arizona
    You should see a thick black wire with a grey connector. It goes to the brake dust shield
  20. Nov 20, 2013 at 2:16 PM
    #40
    toddnicc
    toddnicc Member
    2007 stock
    Has anyone actually followed through.. or know someone who has,
    with the diagnosis to the ABS actuator and replaced it with a positive result?
