Shredded a wheel bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beefed_Taco, Apr 30, 2023.
  1. Apr 30, 2023 at 6:51 PM
    Beefed_Taco
    Beefed_Taco [OP] Member
    Kaden
    Wisconsin
    ‘09 Taco Sport
    Quick run down because some people hate reading, was replacing both CV axles after snapping my driver side at the hub a few months ago. Couldn’t for the life of me figure out how to remove the inner CVs so I headed out to Oreillys for a slide hammer and just shredded my passenger side wheel bearing. Few hours of work later and new CVs and wheel bearings are in on both driver and passenger sides but the passenger side sounds like it has a warped rotor and the ABS and tc light won’t turn off, could it be a bad ABS sensor?
  2. Apr 30, 2023 at 7:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The “sounds like a warped rotor” has me puzzled.
    You usually feel a warped rotor more than you hear it.
    I’d start with pulling the ABS code(s) and go from there.
  3. Apr 30, 2023 at 9:35 PM
    Beefed_Taco
    Kaden
    Wisconsin
    ‘09 Taco Sport
    Yeah I can’t get any more specific than sounds like, there’s something that rubs twice every rotation but I can’t see anything touching so that’s my only assumption.
    As for the codes my schools shop teacher has a real fancy obd reader that’ll figure out what’s really goin on with the abs there.
    TnShooter[QUOTED] likes this.
  4. May 1, 2023 at 12:05 AM
    TnShooter
    Deogee
    STOCK
    Did you happen to bend the backing plate when removing/installing the bearing?
    As for the ABS, I’d take a look and see if the sensor is plugged in?
    Did you remove the sensor?
    winkel and muddog321 like this.
  5. May 1, 2023 at 1:45 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Also if you did not unplug the sensor on the steering knuckle or clip on upper control arm you may have broken the wire(s) so yes plug an ABS code reader in or go to most auto stores and they do it for free. Call and ask if they can read ABS codes first as no ABS brake reading in some cheaper code readers.
    TnShooter likes this.
  6. May 1, 2023 at 5:58 PM
    Beefed_Taco
    Kaden
    Wisconsin
    ‘09 Taco Sport
    Excuse my immaturity but I’m all of 17 and learning here, how would I tell if I bent a backing plate. Is there a backing plate behind the steering knuckle? Many things I don’t know about suspension I just do the work.
    The sensor was not removed when I pulled anything out but I also was never really working close enough to it at any point to really mess with it in my mind. She’ll be going on the reader tomorrow to see, couldn’t get her into the shop today unfortunately.
  7. May 1, 2023 at 7:47 PM
    TnShooter
    Deogee
    STOCK
    The backing plate is the shield behind the rotor.
    The one that is between the bearing and spindle.
  8. May 2, 2023 at 12:55 PM
    Beefed_Taco
    Kaden
    Wisconsin
    ‘09 Taco Sport
    I’ll check tonight, I wouldn’t imagine so since the old came out super easy in a quarter million pieces and the new one slide right in no problem.
  9. May 2, 2023 at 12:59 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Backing plate, warped rotor, debris in there. Also those abs wires are some bullshit 36 gauge wire inside
    6 gearT444E, winkel and TnShooter like this.
  10. May 16, 2023 at 5:01 PM
    Beefed_Taco
    Kaden
    Wisconsin
    ‘09 Taco Sport
    I’m a while late but I’ve returned
    So I bought new pads, rotors, and a new abs sensor and installed them all in the few hours it takes and it’s all fixed.
    The outside passenger pad had a huge gouge in it and scratched up the rotor pretty good. I did end up taking out the wheel bearing again to remove the end piece of my abs sensor that half disintegrated upon my attempt at removal but I doubt that truly changed/solved anything.
    The wiring is definitely a little beat on that passenger side where the wheel bearing failed and the sensor only read 80% of the time and stops after hitting a decent pothole or sharp turns so that’s definitely up next after fixing this next new issue that’s arose.
  11. May 16, 2023 at 8:53 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Glad you got it fixed
