Shudder and "Jump" when A/C is cycling?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PapaBear, Mar 13, 2017.
Does your truck shudder and "lurch" forward when A/C compressor kicks in?
  1. Yes
    13 vote(s)
    68.4%
  2. No
    6 vote(s)
    31.6%
  1. Mar 13, 2017 at 4:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you have the brakes applied you can stand on the throttle till the engine stalls and it won't move.
    Suspect any 'lurch' you feel (which certainly can be real) is driveline slack being picked up. Making the body have some motion, but the actual wheels are not turning.
    If the wheels are turning based on AC idle step up, you either need to press the pedal a bit harder or fire your brake mechanic.
    As a ghetto fab solution you can either turn off the AC or put the vehicle in neutral at stops. :D
  2. Mar 13, 2017 at 4:22 PM
    imageomega
    imageomega Well-Known Member
    Jarrod
    Thought I'd been rear ended so many times when I was not used to this lurch "feature"... hah
    But truck should not actually move. Feels like it, but brakes hold while suspension allows flex. Push the pedal harder if you're actually moving...
  3. Mar 13, 2017 at 4:36 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Yeah. Sometimes it feel like someone rear ends your truck
  4. Mar 13, 2017 at 5:08 PM
    PapaBear
    PapaBear [OP] Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Um, the defroster has only ever been on once, I can assure you that, and that was one time when I went up to Mount Charleston and it was snowing heavily. Living in Vegas, the A/C is on about 85 - 90% of the time, more like 95% these last few years. Heater is only ever driving on cold nights during winter when it gets below freezing, but that's it. Yesterday my temp gauge read 105 in the sun at the Kobalt 400, mind you it had been sitting for long, and this entire week is high 80's with direct sunlight reaching 110 estimated.
  5. Mar 13, 2017 at 5:09 PM
    PapaBear
    Austin
    SIN CITY
    Exactly, thats why I dont want to actually bump someone in front of me because the A/C kicks in so hard it moves the vehicle under braking.
  6. Mar 13, 2017 at 5:23 PM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2007 TRD OR Prerunner DCSB
    The AC engages the clutch fan also, I was answering someone who said it happens when his AC is off.
  7. Mar 13, 2017 at 5:25 PM
    PapaBear
    Austin
    SIN CITY
    Ah got it, thought I saw my user name not his. :)
  8. Mar 14, 2017 at 5:06 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    That's strange man. Wonder why the truck is actually moving.
  9. Mar 22, 2017 at 12:20 AM
    Hot66ss
    Hot66ss Member
    Tom
    Los Angeles, CA
    07 PreRunner Stock
    I had this problem as well as sometime a little bump feeling when coming off the brakes at a stop light. Turned out it was the axle preloading due to weak leaf springs. never had the issues again after the TSB (recall) springs were installed.
