Shudder at 25-30 mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma300000m, May 15, 2024.
  1. May 15, 2024 at 11:14 AM
    Tacoma300000m
    Tacoma300000m [OP] Member
    2009 Red Tacoma 2wd
    08 Tacoma V6 AT. 305k Miles. When the truck hit 300k miles I did a transmission fluid change, just a drain and fill I did everything right. OEM fluid right amount of quarts right temperature. Only thing I did different was put two tubes of shudder fix in it because at first I thought it was the torque converter because of the shaking but it was just spark plugs. Truck has been running normal and shifting like butter when I drove it for 4000 miles but when it hit 305k miles I started seeing the shudder more and a little rough shifts here and there. I'm just trying to get feedback on what I should do. Should I change the fluid out again and put new fluid in including shudder fix but instead of 2 tubes I do 3 tubes. Then drive it around and see what happens or should I just pull the plug and buy a new torque converter. I have not check the u joint but I will check it this week and then come back with an answer.
    I appreciate all the help you guys can give me. Thank you.
  2. May 21, 2024 at 10:51 AM
    JRtaco03
    JRtaco03 New Member
    Jeff
    2003 Silver Tacoma
    I just bought a 2003, and it has a bad shudder sometimes... it is at higher speed though. I was advised by a mechanic to check the drive shaft middle bearing, which he claimed was common. I haven't even looked under it yet.
    Tacoma300000m[OP] likes this.
  3. May 21, 2024 at 11:07 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Center bearing would be a good start, maybe.
  4. May 21, 2024 at 8:39 PM
    Bman562
    Bman562 Well-Known Member
    SoCal, CA
    2005 Radiant Red Tacoma Sport DCSB
    '12+ Facelift, TRD Baja Bilsteins, SCS Ray10's, K02's...
    As mentioned before, center bearing and u joints..
  5. May 22, 2024 at 6:44 AM
    Tacoma300000m
    2009 Red Tacoma 2wd
    Yeah, I'm going to start with the center bearing and u joints first.
  6. May 22, 2024 at 6:47 AM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    mine had this problem around 70-80mph, would come and go.
    i replaced the tires, front hubs, had the driveshaft rebuilt and carrier bearing replaced, no go. I got so frustrated after all that that i just traded it in.
    talked to some guys at a local yota shop and they said its not uncommon with these transmissions, tq converter shudder. Maybe worth looking into.
  7. May 22, 2024 at 7:00 AM
    Tacoma300000m
    2009 Red Tacoma 2wd
    Yeah I'm thinking it's the torque converter but I'm going to replace the carrier bearing first and see what happens.
  8. May 22, 2024 at 8:09 AM
    Danner488
    Danner488 Well-Known Member
    2016 TRD Sport
    I had the TC shudder at 112K miles. A drain and fill fixed it for me.
    My TC issues was at the same speed range, but at 1200 - 1500 RPM when coasting because the transmission up shifted to save gas. I'd feather the throttle to maintain speed and the shudder would occur. If I accelerated harder the transmission down shifted and there was no shudder.
    There's a brake tap test to check for TC lock up. This post describes the brake tap test: https://www.tacomaworld.com/threads...sion-shudder-any-advice.772383/#post-27588697
    Also, if you have an automatic does manually shifting elevate the shudder?
    A coworker had identical symptoms. The dealer replaced a corroded diff breather valve, and it fixed it form him. They also replaced his diff and tranny fluids at the same time, so I take this with a grain of salt, but they said it was the valve causing the issue.
