Shudder at 5mph when accelerating.
Discussion in 'ToyTec Lifts' started by Jimirich, May 6, 2009.
  1. May 6, 2009 at 9:02 AM
    Jimirich
    Jimirich [OP] Well-Known Member
    Hawaii
    08 4x4 Dbl cab shorty O.R. pkg
    DTRL, Debadged, Donkey tethered in the bed that rips 142 db farts so I can piss off the neighbors and rattle the windows on my house when I'm parked in front.
    Hope you guys at Toytec are tuned in here.
    I just had my Ultimate Lift Kit installed and the truck has a shudder at 5mph when accelerating. 08 double cab 4x4
    I used the shims provided and they are oriented tall>>short/back>>front.
    The lift was professionally installed. Other than this issue the handling and ride is great. However, I can not yet use my truck for the intended purpose of the lift (offroading) because I feel this shudder is detrimental to the vehicle.
    I'll be calling if there is no response in a couple of hours.
    Thanks
  2. May 6, 2009 at 9:28 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    the shudder from the axle/drive agle will not kill u offroad. like i stated in the other post u made, get the carrier bearing drop and install it to further decrease the angle.
  3. May 6, 2009 at 11:55 AM
    Jimirich
    Hawaii
    Now if I have to go and order a carrier drop kit for my "Ultimate Lift Kit" Then I would not truly have purchased the Ultimate Lift Kit, would I? It would seem that I purchased the Incomplete Lift Kit, right? As far as I'm concerned if I have to add a carrier drop kit it should be free ad there is no mention anywhere on the Toytec website to the effect that adding the lift will then cause the truck to shudder, thereby requiring a carrier drop kit.
    Thanks for your input I do appreciate a response. I don't mean to be an ass but Its my suspicion the problem lies in the shims. I also believe that there should be no problen at all. The kit should install without any hangups.
  4. May 6, 2009 at 12:01 PM
    jhodge83
    SC
    17 XLT Sport
    it is different for each truck....u can do the same lift on identical trucks, but some get it and others dont. i think it has to do w/ the strenght of the leafs...i've gt a set of shims to put on my truck now and if they dont work, i'll be doing a CB drop as well
  5. May 6, 2009 at 12:02 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    The problem lies in the fact that some have these lifts installed without any shims and experience no shudder.
  6. May 6, 2009 at 11:08 PM
    Jimirich
    Hawaii
    I was told something similar by a coworker; That it could be the shims that are the problem. Apparently, Toytec prefers to have me call them rather than answer my questions through e-mail. I definitely prefer e-mail because there is no question about what may have been said.
    I'll call them tomorrow.
  7. May 8, 2009 at 10:28 AM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Shoot, sorry for the delay in my response... I've been a bit busy on this end..
    so here is the deal.. and I want to thank all those that helped me out and beat me to it, but they have stated it well.
    Because of all these inconsistencies, it is a struggle to make it perfect for each vehicle. But I will tell you what, you do bring up a great point. Maybe we should put the carrier barrier drop kit as an option, right there on the ordering page. So I will see if I can't get that added for easy ordering.
    Like they said, it would first be advisable to install the carrier barrier drop kit and then see what needs to happen next. I know the owner owns a new DC Tacoma and with all the 'stuff' on there, he still has a small shudder.
    Hope that helps, out..
    But you are welcome to call me, you can reach me at 303.255.4959 x2 or darrick@toyteclifts.com. You spoke of emailing us.
  8. May 8, 2009 at 11:24 AM
    jhodge83
    SC
    17 XLT Sport
    i had a shudder after my 3" leaf pack and i installed the toytec shims yesterday and it rides as smoot as stock on the takeoffs. i had to use these on my 07 as well to get rid of the shudder
  9. May 8, 2009 at 11:28 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    I just bit the bullet and spent the little $ extra and bought all the shims and drops. I have not regrets.
  10. May 18, 2009 at 11:30 AM
    Jimirich
    Hawaii
    Thanks for the reply Darrick.
    I had the 2.25-2.5 shim and then removed it. It actually made the shudder a little more prolonged. 5mph-10 mph
    You guys were kind enough to send me along a 1.5 degree shim (in transit) but I'm wondering now: if removing the shim made it a little worse, should'nt I try a bigger shim, like 3 degree?
    Richard
  11. May 18, 2009 at 11:59 AM
    ToyTec Lifts
    Rocky Mountains
    You can try that, we have found little difference between the 2.5 and the 3 degree shims...
  12. May 18, 2009 at 2:38 PM
    Jimirich
    Hawaii
    Thanks, then I guess no sense in trying 3 degree shims. I'll most likely try the carrier drop kit. However I have a different situation that concerns me more. Got a sound like a bad wheel bearing. Its some kinda thumping at low speeds. Waaahh! I'm not having fun right now.
  13. May 19, 2009 at 1:53 PM
    ToyTec Lifts
    Rocky Mountains
    right. Sorry to hear.
    but yes, I would DEFINITELY put the carrier bearing drop kit in for sure!
