Shudder at low RPM
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Grangis904, Feb 19, 2020.
  1. Feb 19, 2020 at 8:30 AM
    Grangis904
    Grangis904 [OP] Well-Known Member
    Jacksonville, FL
    2018 White TRD Pro
    My truck has had a shudder at around 1000-1500 rpms under light acceleration since day one. It kinda feels like when you let the clutch out too quickly on a manual transmission, that kind of jumpy, bucking sensation, but this is an automatic...From what I’ve seen on here it sounds like there’s quite a few of us on here experiencing the same issue. I’ve taken it into the dealership to have them tell me it’s normal, even had them submit a ticket to corporate. They hooked me up to tech stream and went for a ride with me only to tell me again it’s normal, and it could be a product of the fox suspension...Just curious who else is experiencing this, is it just an off road/ pro problem, or does it go down to the other transmissions/ trims such as sport, limited, sr? Also if anyone has figured out a fix I’d be forever grateful!
  2. Feb 19, 2020 at 12:01 PM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Mine has a distinct bucking at 1500rpm if i’m into the pedal - manual trans
    Was also told it was “normal” roll eyes
  3. Feb 19, 2020 at 12:29 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Maybe change over from Atkins to Otto cycle?
    Dfpftw likes this.
  4. Feb 19, 2020 at 12:35 PM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    It's "surging". Mine was pretty bad / consistent until I got the software update. There's a way to tell if you have the latest and greatest or not, the dealer may or may not be helpful...
  5. Feb 19, 2020 at 1:37 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Is your AT fluid full? A lot of guys complained about the underfilled tranny fluid from the factory.
    You are using top tier gas station right?
    gilligoon and TacomaUSA like this.
  6. Feb 19, 2020 at 2:30 PM
    chaotic_taco
    ATX
    2017 DCSB TRD OR MT
    The vast majority of gas stations in the US are "top tier". It's a voluntary trade association, basically.
    Junkhead[QUOTED] and ryan760 like this.
  7. Feb 19, 2020 at 2:54 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    We have quite a few ghetto ones.
    ryan760 likes this.
  8. Feb 19, 2020 at 2:59 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Did you get TSB done on your 2018? It will help with handling the issue.
    Junkhead likes this.
  9. Feb 19, 2020 at 3:00 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    My truck did this all the time at low rpm especially if on say a 1-2% grade. Was the reason I purchased OVTune and it hasn’t done that sense and shifts so much better. Granted there are bugs in OVTune for 2019 trucks that will be fixed when 2.0 final is released but overall I have no regrets. That studded the trans did made me think the darn thing would wear out prematurely if something wasn’t done about it.
  10. Feb 19, 2020 at 3:10 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    drive it with ECT on..
  11. Feb 19, 2020 at 3:11 PM
    Vlady
    Issy, WA
    OVTUNE 1.05 version induced the issue even more.
    Latest 2.0 is better and almost remove the shudder, but it still can be recognized under high load and low RPMs.
    The trick to avoid shudder is to remove the foot from the pedal and apply again. This will unlock torque converter and help to raise RPMs
  12. Feb 19, 2020 at 3:13 PM
    newdles
    Achmed
    Doesn’t fix the low rpm shutter 100%. Ect will hold the gear longer on acceleration. However once you’re in the taller gear and drop speed it won’t downshift without enough throttle angle to make it do so. So if you’re going to accelerate to say 50 mph and then slowly drop speed with light pedal it’ll still shutter. Ect does fix the majority of it though but also holds gears in a weird way when just doing normal everyday driving on a stock setup.
  13. Feb 19, 2020 at 3:15 PM
    newdles
    Achmed
    My truck has yet to do the same thing a single time since I installed it on my 2019. Only issue I experience now are seemingly tune related with the wide open throttle cutoff at around 6200 rpm and the short shift from 3-4 in moderate acceleration.
  14. Feb 19, 2020 at 4:54 PM
    Grangis904
    Jacksonville, FL
    2018 White TRD Pro
    Sorry for the late response, I do use top tier gas, 93 octane helps a bit but it’s still there. When I first got the truck I mostly felt the issue around 20-35mph, took it to the dealership and they applied a tsb (can’t remember witch one, but I’m currently 04a61). That helped for the 20-35mph range but seemed to push the problem up to the 40-55mph range. After a bit of driving the issue has come back at pretty much any speed if I’m feathering the throttle. Took it back to the dealership and had them check the transmission fluid, it was a half a quart low, didn’t help. I do have Ovtune, and it still does it across all tunes, stock, 1.05, 1.05.1, and 2.0 betas. As for the ect button, that’s what the dealer told me, I should just drive it with ect on all the time.
  15. Feb 19, 2020 at 10:37 PM
    AKGSD
    Joe
    Alaska
    Or maybe they could just f***ing design it properly, right?
    Canufixit likes this.
  16. Feb 20, 2020 at 9:44 AM
    Vlady
    Issy, WA
    It is strange to have a shudder at 25-35 range. TC isn't getting locked at these speeds. Do you get shudder under any engine loads?
    You can ask OV for a test file with TC always off and see if it removes. If not, something else is going on.
  17. Feb 20, 2020 at 11:29 AM
    Grangis904
    Jacksonville, FL
    2018 White TRD Pro
    It’s really just in the 1000-1700 rpm range, under light throttle, like when maintaining speed. I believe the 2.0 tune has a towing setting that has the tc always off, was gonna wait and try that rather than bother OVtune while he’s trying to get 2.0 finished up. Plus can’t expect him to solve all of Toyota’s problems for them...lol
  18. Feb 20, 2020 at 2:09 PM
    chaotic_taco
    ATX
    2017 DCSB TRD OR MT
    If the brand is in the list, the gas has the detergents in it. No matter what is going on in the bathroom, or with the sign attached to the bathroom key.
  19. Feb 20, 2020 at 2:31 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    By ghetto, i meant those stations were not on the list.
  20. May 5, 2023 at 6:11 AM
    Wastatehunter
    Wastatehunter New Member
    2018 Tacoma dclb trd sport
    Leveling kit 33x12.5
    Did you by chance figure out the issue I’m having very similar in my 2018
