Shudder feel on take off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ortacoma10, Oct 31, 2023.
  1. Oct 31, 2023 at 3:23 PM
    Ortacoma10
    Ortacoma10 [OP] Well-Known Member
    2010 Tacoma Trd Off-road 4x4
    10’ with 143k here - been noticing a very slight vibration/shake accelerating from stop to 10-15 mph then goes away as I speed up. Any ideas what to look for? TIA.
    Also, front wheels haven’t been balanced not sure if that could be a variable.
  2. Oct 31, 2023 at 4:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Possibly a u-joint?
    Ortacoma10[OP] and joba27n like this.
  3. Oct 31, 2023 at 4:40 PM
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    Agree with above, could be u-joint. It could be a lot of things, but those were the symptoms my 09 bad when one of mine popped at around the same mileage.
    Get under it with a good light and inspect each one, one of mine was visibly damaged. Had a local drive shaft specialist replace them all for not too much $$
    Ortacoma10[OP] likes this.
  4. Oct 31, 2023 at 5:39 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    2014 here. From 104k when I got it to present 128k, FWIW: mine does this... but only on initial medium acceleration, like from a light or a dead stop: never at speed or on a downshift. Going by the feedback entry history over time here: many of them do it: either early on or eventually. (2nd gens anyway) There is no sloppiness in my driveshaft u-joints.
    When it does it at all speeds or the whole truck shakes: address it: starting with the carrier bearing. Could be another 50,000+ miles from now... or never.
  5. Oct 31, 2023 at 5:58 PM
    Ortacoma10
  6. Oct 31, 2023 at 6:00 PM
    Ortacoma10
    You guys have been the 4th or 5th people to say Carrier bearings/u joints so I’m leaning to maybe that may be it either way I’ll get under and tug around a bit more. I notice when in 4hi from stop to 10-15 it doesn’t do it
    Williston likes this.
  7. Oct 31, 2023 at 8:02 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    CB tends to sag over the years and causes a change in driveshaft angles. These can lead to shudder on initial acceleration. U joint can also do it.
  8. Oct 31, 2023 at 8:03 PM
    lr172
    ‘11 DCLB 4.0 Auto
    Sorry but yanking on the driveshaft is not a definitive test. You cannot assess their health without removing them, unless they are really bad.
    Ortacoma10[QUOTED][OP] and vtown like this.
  9. Nov 1, 2023 at 6:19 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    10 bolts and drive shaft is off
    then inspect CB and ujoints for free movement
    Jimmyh and Ortacoma10[OP] like this.
  10. Nov 1, 2023 at 12:26 PM
    Icarus II
    Icarus II Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    My '07 is going in on Friday for the same symptom. Although, sometimes I can feel it cruising also.
  11. Nov 3, 2023 at 3:30 PM
    Emeffer
    Emeffer Active Member
    2015 tacoma prerunner v6
    3 2 leveling kit. 285/70/17 ko2s on 17x10 fuel beast
  12. Nov 3, 2023 at 3:30 PM
    Emeffer
    Could be axle wrap.
  13. Nov 3, 2023 at 6:25 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Is the truck lifted? If so what kind of lift and how much?
  14. Nov 3, 2023 at 6:29 PM
    Ortacoma10
    Yeah could be, gonna hook my GoPro
    no complete stock
    Fischer76 likes this.
  15. Nov 4, 2023 at 10:08 AM
    Fischer76
    Fischer76 Member
    Could also be low on tranny fluid. A lot of tacomas came under filled from the factory. Especially if you have the tow package and transmission cooler
  16. Nov 4, 2023 at 10:12 AM
    Ortacoma10
    Got fluid done 15k miles ago
  17. Nov 4, 2023 at 9:26 PM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    I've been dealing with the same problem for years. 2 days ago I decided to drain the transmission, open it and replace the filter, then waited for the right temp and made sure it was level. Drove the whole day and no change, so I added lubeguard instant shudder fix and the problem is gone... I couldn't believe it !!!!! I used 2 little 2oz because I lost almost half of the first one pouring it through the fill hole, then I used a funnel that flexes. I drove 180 miles and up and down hills and in traffic and it drives great..
  18. Nov 5, 2023 at 3:53 AM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    Done! It was the rear U joint.$230.00 out the door.
  19. Nov 5, 2023 at 5:27 AM
    Ortacoma10
    That’s awesome man I’m really thinking that’s the culprit to my problem. Gonna just replace all u joints and carrier bearing while it’s all apart if it is
