Shudder in drive train while coming to stop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Mar 31, 2016.
  1. May 24, 2016 at 6:34 PM
    #241
    Chris.taco.2016
    Chris.taco.2016 Well-Known Member
    2016 Tacoma trd sport mgm dclb
    I did the ecgs fix for the front diff and it fixed the hmm hmm hmm vibes when driving and decelerating but the vibes like a rumble strip shaking sensation now worse than stock cause of 3 inch lift are still there and really bad also bit of a takeoff stuffer shimmy truck did all of this before lift albeit lot less noticeable guy at my work did shims on his 2014 and said his vibes are gone.. Nothing done to carrier bearing which I thought would be it so take that for what it is I'm tempted to throw in some 3 degree shims and see... Maybe stack some washers to drop Carrier if that doesn't work.
    JoeRacer302 likes this.
  2. May 24, 2016 at 6:51 PM
    #242
    Spiker
    Spiker Well-Known Member
    Don
    2016 Tacoma OffRoad Double Cab Inferno
    My coming to a stop shudder/15-25 MPH vibe TOTALLY goes away with 200-300 pounds of shit in the back. Smooth as silk. I'm gonna throw several bags of mulch back there and keep it there until Effin 'yota fixes it.......
    bucktowntaco and Danielnc06 like this.
  3. May 24, 2016 at 7:02 PM
    #243
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
  4. May 25, 2016 at 6:43 AM
    #244
    Bossman14
    Bossman14 Well-Known Member
    2016 white Tacoma TRD OffRoad access cab
    Stock
    Its not the front driver side needle bearing, although is has very similar characteristics as the 2nd gen needle bearing issue.
  5. May 25, 2016 at 2:01 PM
    #245
    niterider
    niterider Active Member
    Norm
    '07 Sport Taco
    Stereo
    mine didn't do it until I put in 3" OME lift & 285/17's. doing a center bearing in the next few days while lowering it.. can see it move around a lot. my truck is a 2007 I just lifted
  6. Jul 27, 2016 at 6:11 AM
    #246
    davidsp101
    davidsp101 Well-Known Member
    David
    Columbia, SC
    2017 TRD OR 4x4
    What are the torque specs for the U-bolts? Dealer is blowing me off so I figured I'll check them myself.
  7. Jul 27, 2016 at 6:16 AM
    #247
    davidsp101
    David
    Columbia, SC
    2017 TRD OR 4x4
    Have you found a solution to the hard downshift from 2nd to 1st?
  8. Jul 27, 2016 at 6:28 AM
    #248
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Been in contact with him. He posted in the poll
  9. Jul 27, 2016 at 6:34 AM
    #249
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    52 ft/lbs
  10. Jul 27, 2016 at 7:02 AM
    #250
    smitty99
    Scottsdale
    Correct I can't remember the last time mine did it now. 13k mi and preTSB
  11. Jul 27, 2016 at 7:27 AM
    #251
    davidsp101
    David
    Columbia, SC
    2017 TRD OR 4x4
    Ditto - love the update when it comes to highway driving, but it still doesn't resolve the fact that sometimes I can literally let off the brake approaching stopped traffic and the truck will more or less stop itself from the downshift.
  12. Jul 27, 2016 at 7:42 AM
    #252
    smitty99
    Scottsdale
    So far the downshift is not as pronounced for me. This could change as the transmission starts to relearn and "outsmart" itself
  13. Jul 27, 2016 at 10:04 PM
    #253
    Contra472
    Contra472 Well-Known Member
    2016 Tacoma DCSB 4X4 OR
    I've gone through all the other driveline threads....I would say the majority of us experiencing the 15-25mph vibration have the Off Road model....
    Is the OR model more susceptible to this defect?
  14. Jul 29, 2016 at 6:49 PM
    #254
    DarkSky
    DarkSky Well-Known Member
    Oregon
    2016 SR5 Double Cab V6 Auto 4X4 Barcelona Red
    I had the T-SB-0077-16 performed today and insisted they grease the u-joints even though the service advisor insisted there are no zerks on the u-joints. The repair order states the u-joints were greased. Wow imagine that. A service advisor who doesn't know as much as we do here on this forum.
    Anyway now with the TSB and greased u-joints I no longer have the vibration and jerk when coming to a stop.
  15. Aug 11, 2016 at 8:02 AM
    #255
    Hellapeno
    Hellapeno Well-Known Member
    Austin
    2016 TRDOR
    Choice Goodies
    wisdom
  16. Aug 11, 2016 at 8:36 AM
    #256
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Why not something less smelly like sand?
    Just saying. Driving around with a cloud of sour milk smell coming out of your truck is going to be awful.
  17. Nov 30, 2016 at 3:35 PM
    #257
    Scratch190
    Scratch190 Member
    @Bossman14 I have the exact same issue on a 2017 Tacoma with less than 1500 miles on it. I isolated it to the front drive-line as well by using a ziptie on the front drive line u joint yoke to the frame cross member. Did you ever get a resolution to this issue? I took mine to the dealership today and they are suggesting the needle bearing fix which is clearly not the issue if the problem goes away once the transfer case and differential is warmed up. Mine only exhibits this behavior when the vehicle is cold, and the colder it is the more pronounced the issue is. However if you drive the vehicle on the freeway for 10 minutes or operate in 4wd and warm things up the issue goes away. It was not noticeable in 70 degree weather, but I live in Utah and when the weather got cold that is when it surfaced. I believe its due to the viscosity of the oil in cold weather conditions causing the front drive line to "windmill" at a faster rate than under warmer conditions. Any info would be great.
    Thanks
  18. Nov 30, 2016 at 4:08 PM
    #258
    bucktowntaco
    bucktowntaco Well-Known Member
    New Orleans
    2017 MGM DCSB TRD Sport
    Mine has the rumble strip feeling during deceleration. Plan to have dealer check it when I bring it in for 5k service in a few weeks.
  19. Dec 1, 2016 at 8:34 AM
    #259
    Bossman14
    Stock
    yeah mine started at 500 miles and it started when it was cold, but after about 3000 miles it did it when it was warm, i replaced the needle bearing with the ECGS bushing and that helped a little but the vibe was still there. The noise goes away in 4-wheel drive, it also goes away when i zip tie the to front drive shaft to the frame just like you did. I also took the front drive shaft off and the noise went away. I then marked each yoke, one on the front diff and the one on the transfer case, after driving i noticed that the transfer case was the only one that spins (when driving in 2wd). So i have concluded that the transfer case is causing a viscous friction within and its causing the front drive line to turn with little force (little force bc it cant break the zip tie) which then turns the detached spider gears which are the problem, the tolerance are so loose with the spider gear its just plain sloppy in there. so i have a few options for fixes... One, leave the zip tie, Two change the oil in the transfer case so there is no viscous friction build up ( i plan to do this next i might go with redline gl-4 75-85w), Three replace the front diff third member with an arb locker ( 2000 bucks).
    But i am almost certain that the culprit is Toyota's large tolerance between the spider gears, i think thats why some trucks have it and some dont.
    if you find another solution please feel free to share
  20. Dec 1, 2016 at 8:42 AM
    #260
    Scratch190
    Scratch190 Member
    So what is Toyota telling you? Do you have a Toyota customer service case open that they are tracking? I opened one yesterday which I am going to pursue, but I am not sure if anything will come of that....
