Shudder in drive train while coming to stop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Mar 31, 2016.
  1. Apr 2, 2016 at 8:08 AM
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    Mine does it at 25 while decelerating.
  2. Apr 2, 2016 at 8:18 AM
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Let's figure this one out. It feels to me like it's coming from the driveline. Feels similar to my second generation driveline vibes. Thoughts?
  3. Apr 2, 2016 at 8:22 AM
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    I have it too braking from 20. Anyone have a go pro they can mount near the front diff?
  4. Apr 2, 2016 at 8:24 AM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Mines been back at the dealership since last Thursday @ 7:00 am. I bought on 3/12 and it is doing this. Currently, the rear diff is getting replaced because it failed at 400 miles. They are going to see what, if any, effect this has on this described vibration and go from there. A toyota engineer is involved and they are documenting it. I have a thread started that I update when I find out info too.
  5. Apr 2, 2016 at 8:28 AM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Can you link here? Many thanks, B.
  6. Apr 2, 2016 at 8:29 AM
    bulldog
    SW MO
    2023 Pro
  7. Apr 2, 2016 at 8:43 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Did they check to see if the u-joints had lube?? Ask the engineer to check.
  8. Apr 2, 2016 at 8:45 AM
    bulldog
    SW MO
    2023 Pro
    My rears did not. I fixed that on the day I drove it home. I did not do the fronts and they still have not been done, but they are going to go over everything before I get it back. They are going to ride along before I take it back and I'll crawl under and check the paint on the fronts.
  9. Apr 19, 2016 at 11:46 AM
    Bossman14
    Bossman14 Well-Known Member
    2016 white Tacoma TRD OffRoad access cab
    Stock
    I had the exact same problem, the noise would go away when i engaged 4wd so i thought is could be the needle bearing but i then zip tied the front driveline and the noise went away completely, i think it is caused by the front diff fluid, meaning there is a viscous coupling going on even tho the add is not engaged, it was a problem with the 2003 tundras, they even put it in the owners manual.
    gearcruncher likes this.
  10. Apr 19, 2016 at 12:12 PM
    gearcruncher
    Canadain bumper technician
    Seems to be a large complaint with both the manual transmission as well as the automatic . There have been a few guys asking me about this issue and we were in the process of diagnosing it .
    Shut the truck off in nuetral at 30 mph and let the truck coast to a stop . Do not use the brakes .
    If you still feel the vibration / shudder , you definitely have the symptoms
    Turning your truck off eliminates your engine and transmission
    I agree with
    Bossman14
    Where abouts do we place the zip ties ?
    Kenster_66
    JoeRacer302 likes this.
  11. Apr 19, 2016 at 1:00 PM
    Bossman14
    Stock
    Yea I had the vibration when coasting in neutral and when in drive (2wd), it was worst on cold mornings, I assume it was due to the front diff fluid being thicker, and I took a long zip tie and went through the front u-joint and then through a hole in the frame and make it snug.
  12. Apr 19, 2016 at 2:04 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Oh, you are keeping it from spinning at all. What about if you want to use 4wd? Are you going to pull over and cut the zip tie? Or gun it in 4hi in hopes to snap it off hahha
    Sounds like if it stopped completely then it is either a balance issue or drag issue like you said with the viscous coupling.
  13. Apr 19, 2016 at 2:24 PM
    Contra472
    Contra472 Well-Known Member
    2016 Tacoma DCSB 4X4 OR
    Just picked up my new truck with 8 miles on it last week. Drove off the lot and braked at the stop light and immediately noticed a rumbling/vibration in the truck as I stop. Basically always present around the 15-20mph range. Will let dealer know on my next visit. V6 DCSB OR Auto. Build date 4/2016 baja
    Didn't expect this on a new vehicle =(
  14. Apr 19, 2016 at 2:29 PM
    Bossman14
    Stock
    yea its a skinny zip tie and when i engage 4wd it breaks right off. I am thinking its also because its new, the gear tolerance is very tight and the fluid between the gears creates friction, maybe it has to get broken in, the truck only has 500 miles on it.
    Graycoma likes this.
  15. Apr 19, 2016 at 5:01 PM
    #35
    Graycoma
    Graycoma Member
    2016 DCSB TRD OR
    I just did this. It made a big difference. Thank you.
  16. Apr 19, 2016 at 5:14 PM
    #36
    bulldog
    SW MO
    2023 Pro
    What kind of said zip tie are your using? All I have is big ones..........plus I'm pretty dumb. Any pic's of where/how you did this?
    Lawfarin likes this.
  17. Apr 19, 2016 at 5:31 PM
    #37
    Kenster_66
    Kenster_66 Well-Known Member
    Greensboro, NC
    2016 Silver SR5 4x4 Dbl Cab Auto
    I have been dealing with this since I bought my 2016 SR5 4x4 Dbl cab, 4 weeks ago. Been to the dealer three times;
    1st - (500 Miles) Balanced Tires, hooked it up to the techs computer, all checked out OK.
    2nd - (1200 Miles) Took the Service Adviser for a test drive, both of us felt the "rumble strip" vibration coming to a stop. ECT makes it less noticeable, but it's still present. I was told to wait for a TSB for software update on shift points.
    3rd - (1600 Miles) Transmission Fluid checked, after leaving it overnight, 3 techs agreed it was at the correct level, told to call Customer Service
    Customer Service has "Opened a Case" and I have a "Case Number"... heard back today, they are contacting the dealership and are hoping we can have a positive resolution....
    Standing by... hoping for a "Buy Back" lemon law issue... Not happy!
  18. Apr 19, 2016 at 5:32 PM
    #38
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    Yea, mine too, sometimes worse than others. Usually it's light and barely noticeable, but sometimes bad enough that it makes the dash rattle a bit. I'm going to bring it up at the 5000 mile service.
  19. Apr 19, 2016 at 5:32 PM
    #39
    Graycoma
    Graycoma Member
    2016 DCSB TRD OR
    I just used some small plastic zip ties I had on hand. I had to put three of them together because they were short. I went through the front drive shaft, forward most u-joint then straight down through the holes in the rail below it and cinched it up. Kind of a quick job just to see if it would work.
  20. Apr 19, 2016 at 5:33 PM
    #40
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I have this in my 2014 4Runner
