shudder, intermittent & annoying AF....HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chiloquin_Car_Care, Jul 26, 2020.
  1. Jul 26, 2020 at 11:49 AM
    Chiloquin_Car_Care
    Chiloquin_Car_Care [OP] homie dont play that
    Oregona
    2021 voodooblue DCSB 4x4 3.5l v6
    nada....maybe a license plate one day & BA bumpers
    need some help
    here is the issue-
    major shudder with moderate to hard braking (most noticable when braking at 50-70mph)
    & if Im going down hill, its really nuts....I have pulsate the brakes to limit the shudder
    & even more weird is some times it does it, sometime not
    but lately its seems like the problem is getting worse & more persistent
    note- Ive changed the front pads & rotors (TWICE!)....so its not warped rotors
    any idea's or suggestions on things to check in the front end/steering sytem?
    I have nearly 374k miles on my taco & its a 2013 4x4
    thanks yall!
  2. Jul 26, 2020 at 12:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is the shudder in the steering wheel, pedal, or the whole truck?
  3. Jul 26, 2020 at 12:26 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Don’t hard brake at 70mph
  4. Jul 26, 2020 at 12:30 PM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    Check your inner and outer tie rods. Check your steering rack for play. These can cause this condition.........
  5. Jul 26, 2020 at 12:32 PM
    TnShooter
    Deogee
    STOCK
    With 374k on the truck, I’d inspect all the suspension components.
  6. Jul 26, 2020 at 12:37 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Definitely a good place to start
  7. Jul 26, 2020 at 6:57 PM
    Chiloquin_Car_Care
    Oregona
    Definitely in the steering wheel
    & Slightly on the floor board
  8. Jul 26, 2020 at 6:59 PM
    Chiloquin_Car_Care
    Oregona
    Will do
    If this is the issue
    Is it best to replace the inner & outer rods
    Or just replace the whole steering rack?
  9. Jul 26, 2020 at 7:05 PM
    Bishop84
    Bishop84 Well-Known Member
    Most high mileage tacomas need racks, they leak into the boot and usually have play on the inner tie rods.
    It's not an easy DIY job.
    I would check all before replacing it.
    TnShooter likes this.
  10. Aug 19, 2020 at 7:24 AM
    Chiloquin_Car_Care
    Oregona
    Was not steering or suspension
    Driver side issue, super tight/unlubed caliper pin (top pin only)
    Passenger side issue- sticky caliper or cockeyed wheel bearing...figuring that out tomorrow
    Island Cruiser likes this.
  11. Aug 22, 2020 at 11:43 AM
    Chiloquin_Car_Care
    Oregona
    Changing out the wheel bearing now
    Party time
