Shudder / rotation restriction w/sharp turns 20-35mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 15TacomaVet, Jun 25, 2021.
  1. Jun 25, 2021 at 8:52 AM
    15TacomaVet
    15TacomaVet [OP] Member
    Jerid
    '15 Tacoma V6spd Off-road
    Steel bumpers w/winch plate F&B, 3" lift, dual side tool box canopy
    This might have already been covered. Recently did a 3" Bilstein lift/level & put 285/75r17's on. Now i get this "grab" occasionally that either tries to pull me off the road or into the other lane. Most commonly happens between 20-35mph but has happened @ around 60mph. Sometimes i can expect it & other times it's hit/miss. The brake pedal is usually hard when it happens & there's a rotational drag/vibration (almost a grind) from the front end that is a long intermittent just before it locks up. At first i thought my tires were sucking up my mudflaps & triggering the AUTO LSD/traction control. Took those off & talked to Toyota to disable T/C. Didn't fix the issue. Drives fine in the city (no occurances). Uphill backroads a softspot for Toyota? I doubt it. Maybe bearings? CV? Front diff? Any help is appreciated & I'll try to answer any questions as best I can.
  2. Jun 25, 2021 at 9:12 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Did this issue arrive before or after the lift?
  3. Jun 25, 2021 at 9:16 AM
    TheOnlyPajooned
    TheOnlyPajooned Well-Known Member
    Don
    The 'Couve, WA
    2012 DCLB Sport
    she got big shoes bro
    My 35's do this too - it's likely catching your inner fender/wheel well
    just my 2c comparing your tire size to mine
  4. Jun 25, 2021 at 9:49 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Just check all is tight... LCA bolts ect. If you did not do the work, then it could be anything. Also verify sway bars are not hitting anything.
  5. Jun 25, 2021 at 9:59 AM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
  6. Jun 25, 2021 at 10:03 AM
    15TacomaVet
    Jerid
    After lift.
  7. Jun 25, 2021 at 10:05 AM
    15TacomaVet
    Jerid
    Checked inside of tire for rub scars, all the little stick tabs are still in place all the way around. Sound more mechanical (not quite grind but metal-metal rub).
  8. Jun 25, 2021 at 10:10 AM
    15TacomaVet
    Jerid
    Work was done by a pro shop, took it back and they retorqued everything & gave me the specs so i could check their work if i wanted, i did. Everything is tight. Bushings look good all around, sway-bar clearence checked out, alignment checked & rechecked.
  9. Jun 25, 2021 at 10:12 AM
    TheOnlyPajooned
    Don
    The 'Couve, WA
    2012 DCLB Sport
    Gotchya, and chance of a video? or some audio recording? there's a lot of moving parts around there; GL with it!
  10. Jun 25, 2021 at 10:16 AM
    15TacomaVet
    Jerid
  11. Jun 28, 2021 at 9:20 AM
    15TacomaVet
    Jerid
    Reset the VSC. Helped a lot, specially with general driving. Didn't eliminate the whole problem, but did let me gather more info. The grab is noticably softer now and ran live diagnostics on the drive home, each grab had a corresponding ABS acuation. Idk if that was a result of the grab or if it's part of the cause. Bad bearings is what i keep leaning towards but i don't get any play from the wheel when it's off the ground... I really do appreciate all the help from everyone.
    LC7 likes this.
  12. Jun 30, 2021 at 8:32 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    VSC is still acting up. That is what activates the ABS it thinks you are loosing control and is attempting to correct it. You may want to do the VSC Calibration again.
    EDDO likes this.
  13. Jun 30, 2021 at 8:58 PM
    toytaco112
    toytaco112 Sup
    Cedar Park, TX, US
    2012 Tacoma DBLCB 4x4 short bed
    King 2.5 Extended travel coilovers, JBA UCA's Deaver stage 2 leaf pack, All pro Aluminum replacement front with 9500lb smittybilt winch, cheap ebay rear replacement, 285.75x16 BFG All- terrains on Method NV wheels, Air ride bags light bars, rock lights bumber light bar And the list goes on..
    Following… have a similar issue been dealing with for sometime…
  14. Jun 30, 2021 at 9:55 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Recalibrate VSC on even level surface with yourself seated in the vehicle and wheel straight.
    Jimmyh likes this.
  15. Jul 1, 2021 at 9:23 AM
    LC7
    Far Nor Cal
    And don't move or breath. Like an x-ray. :D
  16. Jul 1, 2021 at 12:02 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    Touche! Haha I actually tried 3 different parking lots before I found an evenly graded one which helped immensely. All the trucks I lift with VSC are always reset. Some trigger the abs at different intervals so it's always good practice to reset after a lift.
  17. Nov 21, 2021 at 9:35 PM
    15TacomaVet
    Jerid
    Update: vibration/shudder troubleshot down to 2 culprits, bearing (most likely) or an issue with the axle (least likely as issue would likely have to be in the knuckles of the axle. Did bearing & axle swap & will be test driving the vehicle tomorrow. I'm anticipating a "problem solved" result. We'll see.
  18. Nov 22, 2023 at 5:53 PM
    Emeffer
    Emeffer Active Member
    2015 tacoma prerunner v6
    3 2 leveling kit. 285/70/17 ko2s on 17x10 fuel beast
  19. Nov 22, 2023 at 6:07 PM
    Emeffer
    Did you ever figure this out? Mine does the same thing. Only when im in the mountains. Dry pavement, low speeds on turns. Bad Wheel bearing triggering speed sensor was my first thought even though i cant feel any play in it when i jack it up. I have 6inch lift on 2wd prerunner. Drives me crazy. Also have bad vibes 40 to 70 on pavement after driving down bumpy trails that seem to disappear after i finish driving for a bit then start driving again.
