Shudder/Vibration while braking.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Baja Oscar, Apr 4, 2019.
  1. Apr 4, 2019 at 1:49 PM
    Baja Oscar
    Baja Oscar [OP] New Member
    1999 Tacoma SR5 Pre Runner
    Almost all of the internet posts regarding this issue claimed that brakes were the source of the problem. I don't think so! Here are the specifics: my 99 2WD V6 Automatic shudders and vibrates when braking hard. Appears to be coming from the back of the truck, cannot feel it in the brake pedal or steering wheel. This has been an issue for so long (10 years or more) that I cannot remember when it started. The problem has persisted despite tire rotations and replacements. I have recently replaced front pads and rotors, rear shoes and drums. Since I never use the emergency brake (which adjusts the rear brakes) the rear shoes looked like new, but I replaced anyway. After auto adjusting the rear brakes (repeatedly setting the emergency brake over and over again) the shuddering got much worse. It occurs if I stop without using front brakes by pulling on the E-brake at 20 - 30 mph (haven't tried at higher speed). Visual inspection of rear suspension shows no obvious problems. Anyone able to help?
    GQ7227 likes this.
  2. Apr 4, 2019 at 2:08 PM
    rj15tacoma
    rj15tacoma Well-Known Member
    did u use oem parts for the drums? sometimes aftermarket stuff is not perfectly shaped, so that could cause a bumpy braking experience.
  3. Apr 4, 2019 at 4:44 PM
    Baja Oscar
    Maybe I need to get my "new" drums turned.....?
  4. Apr 4, 2019 at 4:52 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    So you messed with the brakes and the problem got worse, but you don't think it's the brakes?
    jeg0005 likes this.
  5. Apr 4, 2019 at 6:34 PM
    rj15tacoma
    I would double check those drums, they can be picky
  6. Apr 5, 2019 at 5:21 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this is interesting, I was recently checking out a similar '99 PRErunner 3.4 for my nephew that was on 'sale' for 5k @ 200k miles, I test drove it around the lot and the very first thing I noticed were the brakes were extremely grabby from what I was ever used to in mine
  7. Apr 5, 2019 at 9:43 AM
    Glamisman
    Glamisman Well-Known Member
    there is a possibility that the drums did not seat flat on the axle hub due to rust or maybe they sat cocked and you tightenend the lug nuts. Changing the rear shoes should not have altered the brakes unless the shoes you bought are junk. In the old days shoes needed to be arced to the drum diameter by a machine that removed lining material so that the new shoes fit right. Modern shoes should be pre-arced so that the leading and trailing edges of the shoes are a smaller diameter so that they self seat.
  8. Apr 5, 2019 at 1:27 PM
    Falkor1
    Falkor1 Well-Known Member
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    2,000 Tacoma rear axle with E-Locker.
    Your rear drums might be over adjusting causing your shoes to lock up your rear end. Jack up the back and see if your tire can spin freely without the parking break on. My shuddered like crazy and it was because the parking break wasn’t adjusted properly.
    Edit: also if you changed the rear shoe you should use oem shoes and replace all the springs, cause they loose their strength over time.
