shudder when shifting to drive from standstill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Divezonescuba, Jan 4, 2025.
  1. Jan 4, 2025 at 10:48 AM
    Divezonescuba
    Divezonescuba [OP] Member
    2013 4 door tacoma
    Hello. I have a 2013 Tacoma automatic with the 6 cylinder 4.0 and 425K miles. Yesterday, I noticed a shudder when I shift from neutral to drive from a standstill.
    The transmission fluid has been changed recently.
    No codes.
    Any ideas?
    Thanks.
  2. Jan 9, 2025 at 6:42 PM
    Divezonescuba
    2013 4 door tacoma
    More information.
    if I am on a level road, I can put the Tacoma in neutral without my foot on the brake without it moving. If I then move the transmission from neutral to drive, it shifts smoothly with no shuddering.
    I can also shift from drive to neutral without shuddering.
    Could this possibly mean that the problem is actually with the brakes or is something going on.
    Thanks.
  3. Jan 10, 2025 at 3:23 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Let's keep it simple to start. Did it shudder before the fluid was changed? What kind of fluid was put back in? Who changed it - you, or some mechanic? At 425K miles has the fluid ever been changed before or is this the first time? If you changed it or if you have access to the old fluid, does it smell burnt?
  4. Jan 10, 2025 at 4:19 PM
    Divezonescuba
    2013 4 door tacoma
    Thanks for the help.
    I changed the fluid myself using the service bulletin procedure. It was the Toyota WS transmission fluid. I don't recall the specific mileage when it was changed, but I don't think that the shudder has anything to do with that since there was some time separation. It was definitely not burnt, just a little darker.
    I have subsequently checked the brake light switch. I saw somewhere that a malfunctioning brake light switch could display those symptoms. But it is working, so it is probably not that either.
    Since the shudder started, I have also changed the brake pads. They were due, but the shudder is still there with the new brake pads, so that did not make a difference.
    The shudder does not seem to be related to the transmission, as it only happens when I shift from neutral to drive with my foot on the brake. If I shift from neutral to drive without my foot on the break, it does not shudder.
  5. Jan 10, 2025 at 4:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you're certain you properly fill the trans, look for vacuum leaks. Like the hose to the brake booster or the check valve.
