Shudder while gunning it from a stop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDoggydog, Nov 10, 2016.
  1. Nov 10, 2016 at 4:14 PM
    TRDoggydog
    TRDoggydog [OP] Member
    2012 TRD Prerunner
    2012 Prerunner Automatic 190k miles
    Feel a shudder when taking off in first gear from a stop. This only happens with engine under full load, WOT, flooring it. It seems to go away after 1st gear or letting up. It's not a huge deal, I rarely gun it like this from a stop and I don't feel any vibrations or hear anything out of the norm otherwise.
    Trans mount is intact and solid. U joints feel solid, no sign of deteriorated needle bearings/dust/play. Center carrier bearing also seems OK, no significant play. The output on the back of the trans is the only spot that seems to have play, though it is minimal and I have read this is normal. I've also read that seemingly solid U joints could still be the problem.
    Help?
  2. Nov 10, 2016 at 4:15 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Ive been told its axle wrap, ill wait for a confirmation though.
    eccracer104 likes this.
  3. Nov 10, 2016 at 4:15 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    My guess would be axle wrap if your driveline parts are solid.
  4. Nov 10, 2016 at 4:23 PM
    TRDoggydog
    2012 TRD Prerunner
    Meaning? Leaf springs unseated? U bolts loose? Sorry I'm noob-ish. Thanks.
  5. Nov 10, 2016 at 4:25 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Axle wrap is usually felt right after letting off the brakes. The tension is released and it gives a bump feeling, kinda like being rear ended.
  6. Nov 10, 2016 at 4:29 PM
    ManBeast
    Zach
    Orange Park FL
    My 98 yukon does that
  7. Nov 10, 2016 at 4:33 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    So to make sure I'm understanding what you're feeling correctly, is it like the rear end is hopping when you're hard on the gas from a stop?
  8. Nov 10, 2016 at 5:07 PM
    TRDoggydog
    2012 TRD Prerunner
    I have ex
    That's pretty accurate. More of a shudder or vibration than a hop though. I very, very rarely feel a very, very slight bump when letting off brakes at a stop. I have felt this way more pronounced on my previous 06 Tacoma. But that one didn't shudder on hard acceleration from a stop like this one.
  9. Nov 10, 2016 at 5:16 PM
    moondeath
    Pa, Gardners
    Ive also experienced the acceleration shudder, only under full throttle from a stop. I would say it has something to do with some of the notorious Tacoma driveline vibrations. On mine I know its nothing to worry about. Another words its not a worn out part.
  10. Nov 10, 2016 at 5:18 PM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    I think this is considered normal. Mine has done it since new at anything over 3/4 throttle in first gear. Even does it in 2nd gear at low speeds if I floor it. Not much, but I can notice it. I believe it's due to the shitty leaf springs that bottom out in normal driving around town.
  11. Nov 10, 2016 at 6:11 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    It could be a mix of axle wrap and the torque from the driveline causing vibrations. The axle rotates under load changing the angle of the driveshaft, that mixed with our weak springs just makes the whole thing unhappy. Do a little searching, I know I remember seeing a thread about "axle wrap solved" or something along those lines. It was an aftermarket helper leaf that adds a little stiffness to the rear to help reduce those vibrations.
  12. Nov 29, 2016 at 4:34 PM
    TRDoggydog
    2012 TRD Prerunner
    Following up
    I realigned my carrier/support bearing and that seems to have fixed the shuddering. I didn't use an angle finder but just eye balling it I could see the shafts weren't in line with the trans and diff. It's nice to be able to fully enjoy the truck, and goose it and not have to worry about bad vibes!
    ManBeast likes this.
