Shudder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Knucklehead_Taco, Aug 17, 2021.
  1. Aug 17, 2021 at 6:42 AM
    Knucklehead_Taco
    Knucklehead_Taco [OP] You said cut the "BLUE" wire righ…
    California (Left Coast)
    2009 Tacoma 4x4 TRD Off-Road (4 door Crew Cab)
    4 inch lift - 20" Wheels M/T Tires - 4.0L VVTi V6 -
    So, I know this happens when you put lift kits on Tacoma‘s, but has anybody fixed the shutter you get when you take off after putting on a lift kit? I have already put a shim kit on the center carrier.
    I’m just curious what anyone has done that actually fixed it
    lynyrd3 likes this.
  2. Aug 17, 2021 at 6:57 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Return it to stock. A whole lot of engineering went into the suspension. Not so much lift kits.
    Sprig and wisco kid like this.
  3. Aug 17, 2021 at 7:24 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Might be axle wrap. Did you use blocks in the back? New leaf springs?
  4. Aug 17, 2021 at 7:31 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Trac bars work for alot of people, only down side is clearance if you offroad.
  5. Aug 17, 2021 at 7:50 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I added a 1.5" AAL (Headstrong progressive) and got some shudder. I also added the OME carrier bearing drop spacer. It helped a little but i still have a slight shudder from take-off. Only thing i can think of to do left is an axle shim. But my shudder is so minor i might just leave it how it is.
  6. Aug 17, 2021 at 8:03 AM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Yes but stock is boring and let's face it the Tacoma looks like a "grandpa truck" in its stock form. Hundreds of thousands of Tacoma owners, including myself, are running trouble free with their lifts and heavy mods you just have to do it right.
    3X4X4, boogie3478 and Junkhead like this.
  7. Aug 17, 2021 at 8:20 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    You can try lots of stuff... Try measuring your driveline angles. Then you'll know what you need instead of guessing. My guess is you need like 2° axle shim.
    lynyrd3 likes this.
  8. Aug 17, 2021 at 1:12 PM
    Knucklehead_Taco
    :argue::argue::argue:Well, I plan on installing the OME shims this weekend. The OME carrier spacers seemed to work a little bit.
    How much give does the carrier have? When the carrier is bolted in tight, i can move the joint up-down-left-right about 1/2” to 3/4”. That seems like too much play, especially when taking off?
    I think it shouldn’t move at all?
  9. Aug 17, 2021 at 1:15 PM
    Knucklehead_Taco
    If I installed the lift, I could probably figure it out, but I am fixing someone else’s stuff… I have no idea what exactly they did to it
  10. Aug 30, 2021 at 4:31 PM
    lynyrd3
    Bill
    East Central Upstate NY
    I have the dreaded shudder also . Lifted 2.5 -3” . OME carrier shim also . Im about to order up a 1/2” shim for the driver side lean. I have the front coil spring spacer but it doesn’t do much . . Not sure if I should add the other tapered shims to the rear . I need to have my drive line angles measured . What I really want is the Tom Woods one piece drive shaft :spending:
  11. Aug 31, 2021 at 6:44 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Tons of people have reported the take off shake on their STOCK suspension Tacomas. My did it with stock suspension and it still does it with a 1 inch lift block.
    lynyrd3 likes this.
  12. Sep 3, 2021 at 10:23 AM
    motorhead310
    motorhead310 Well-Known Member
    Pomona , Ca
    2006 Taco Pre-Runner
    My Tacoma shuttered too. Especially when accelerating from a stop. I threw a bunch of money at the problem (new drive shaft, new carrier bearing, dropped the carrier bearing). It ended up being the f***ing transmission fluid! It was old and breaking down. This issue is well documented on this site. I just wish I read about it before dropping money. I ended up taking it to the dealer, paid $300 for a full flush. Shutter was GONE.
    igno1tus and lynyrd3 like this.
  13. Sep 3, 2021 at 7:58 PM
    3X4X4
    3X4X4 Well-Known Member
    JR
    KS
    2006 Indigo Ink Blue TRD O/R
    Snug Top, Toytec Ultimate Lift, SPC control arms, N-Fab light bar with Hella DL, Yakima rack, factory locker, Cooper AT3 265X75X16, TRD exhaust and front skid
    My 06 shuttered at stock height and it shudders less once lifted. I spent a lot of time setting it up after the lift. No shims, carrier drop. The solution in due course is a TW shaft. However, Toyota, post lift, repaired my drive shaft under warranty and it shudders even less now and that was like 30,000 miles ago. I think I leave well enough alone. I just finished a 6,000 mile trip and have done several long distance tows of our boat. I think it is okay. When it is not, TW time.
    lynyrd3 likes this.
  14. Sep 22, 2021 at 2:47 PM
    Knucklehead_Taco
    UPDATE:
    So I found the shudder... It has NOTHING to do with the suspension, lift, or driveline... I changed the plugs to brand new NGK Iridiums and it takes off smooooth. I guess whoever installed the new plugs "F'd" something up (Maybe a coil) and my MPG went from 15 to 24.6 immediately.
    When the coils heat up there is a slight shudder, so I will be replacing them as well.
    WHOODATHUNKIT
